    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 219.1k Views 79 Watching
    • ppoublanP Offline
      ppoublan
      @oxer said:
      The the funny thing is that I haven't installed LightUp, for this reason I don't know why these components are created when you place a new tree, perhaps another plugin is the guilty. ❓
      EDIT: I have seen in Components Window >Edition the path for these Components --> C:/Program Files/SketchUp/SketchUp 2014/Tools/lightup/components/pointlight-v1.6.skp
      I work on Mac and this path in OS X doesn't exist.
      Sketchup UFO mysteries πŸ˜„
      Maybe I left some unpurged components with some leaves components definitions. Need to load all one by one to test...
      • OxerO Offline
        Oxer
        πŸ˜„ Yes, that is the error, leaves components files unpurged πŸ‘
        • ppoublanP Offline
          ppoublan
          "never let a bug, Oxer will point it"
          Added to the todo list.
          • OxerO Offline
            Oxer
            πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ It's my problem I'm very perfectionist. πŸ˜†
            See the flower13 it has another layers too.
              Tubeman55
              Hi there,
              I am looking for a talented power user of 3D Tree Maker who can support me with creating some trees and plants for professional use. I am willing to spend some dollars for your effort.
              Please drop me a line if you are intested and give me some background information about you.
                lema
                Tell me how to make a dense and clipping like this:
                http://shkolazhizni.ru/img/content/i112/112798_or.jpg
                http://voodland.com/images/stories/virtuemart/product/acer-platanoidies-globosum1.jpg
                Inside the leaves do not want to not load.
                • deaneauD Offline
                  deaneau
                  hi, i have found a good site for leafes and other think.
                  (nobacks.com)
                  Maple Tree Leaves - Image Gallery
                  (www.3dmd.net)
                    garystan
                    Hi everybody :
                               Is there a Tree Maker plugin for Sketchup 8 ?  And where do I get it ?  The ones that I DID find are for Collada.
        garystan
                      sob80sup81
                      Hello,
                      Is this plugin still actively supported by the developer? I purchased a license expecting to get a more comprehensive library of trees and grass but after keying in the license, no change of tree collection from the free version.
                      • LOAML Offline
                        LOAM
                        @sob80sup81 said:
                        Hello,
                        Would also like to know this as it doest work in SU2017
                        • Bob JamesB Offline
                          Bob James
                          • jujuJ Offline
                            juju
                            @bob james said:
                            [attachment=0:1xmppw8w]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1xmppw8w]
                            works fine here in SU2017 as well
                            • LOAML Offline
                              LOAM
                              @juju said:
                              @bob james said:
                              [attachment=0:1aq04ju1]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1aq04ju1]
                              It loads fine as per your image but try the following;
                              • Make a tree
                              • Reconfigure it, using right click, reconfigure
                              • Change tree parameters *
                              • Redraw tree using updated parameters **
                              • You will notice that many of the sliding bars are listed as NaN
                                ** Redraw does nothing after changing any of the parameters 😞
                              http://i.imgur.com/Udv6s2S.jpg
                              • OxerO Offline
                                Oxer
                                Error in Ruby Console to load a tree:
                                Error; #<NoMethodError; undefined method `treetemplatename' for nil;NilClass>
                                /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1141;in `webtosu'
                                /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1117;in `block in initialize'
                                /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `call'
                                /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `find_support_files'
                                /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `populate'
                                /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1137;in `webtosu'
                                SketchUp;1;in `call'
                                OSX 10.11.6 & SU2017
                                • LOAML Offline
                                  LOAM
                                  I've had an email back from ppoublan to say he is hoping to get this fixed in the new year.
                                    karllarsen
                                    @loam said:
                                    @juju said:
                                    @bob james said:
                                    [attachment=0:2vnsbkfz]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:2vnsbkfz]
                                    • Make a tree
                                    I am having the exact same problem.
                                    Less is more.
                                      Jorgensen
                                      has anyone got this to work with su2017?
                                      thanks
                                      jorgensen
                                        karllarsen
                                        It sure would be nice to know if this will ever work or its just a lost-cause?
                                        Less is more.
                                          I don't really have a need for it but I just installed it now because of your post. It seems to work fine for me. It makes trees like it says on the box.
                                            Works fine for me inside Su2017 Make ! β˜€
                                            Make your change(s) then Right Click on the selection / Context Menu 3D Arc Studio Tree/ Redraw.
                                            Free version
                                            3DArcStudio Tree Maker Sketchup Plugin can be downloaded for free from this site. The free version gives you access to all features, except you are not granted the right to sell or distribute trees created with the plugin, you will get one message each time you change configuration and little time to wait before the tree starts drawing, and you will not get access to all the tree templates included in the full version. If you like this plugin, you can get a licence for 10 euros that will remove those limits.Possible with the free version
                                            Time was 5 s πŸ˜‰
                                            Rendered with the free SimLab Composer Light! maxi 1920 * 1080 πŸ˜‰ (a KeyShot like)
                                            Can reload quasi any format of files! πŸ‘
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
