    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
    • OxerO Offline
      Oxer
      ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„ It's my problem I'm very perfectionist. ๐Ÿ˜†
      See the flower13 it has another layers too.
        Tubeman55
        Hi there,
        I am looking for a talented power user of 3D Tree Maker who can support me with creating some trees and plants for professional use. I am willing to spend some dollars for your effort.
        Please drop me a line if you are intested and give me some background information about you.
          lema
          Tell me how to make a dense and clipping like this:
          http://shkolazhizni.ru/img/content/i112/112798_or.jpg
          http://voodland.com/images/stories/virtuemart/product/acer-platanoidies-globosum1.jpg
          Inside the leaves do not want to not load.
          • deaneauD Offline
            deaneau
            hi, i have found a good site for leafes and other think.
            http://nobacks.com/photos/nature/leaves/
            404 Not Found
            (www.3dmd.net)
              garystan
              Hi everybody :
                         Is there a Tree Maker plugin for Sketchup 8 ?  And where do I get it ?  The ones that I DID find are for Collada.
        garystan
                sob80sup81
                Hello,
                Is this plugin still actively supported by the developer? I purchased a license expecting to get a more comprehensive library of trees and grass but after keying in the license, no change of tree collection from the free version.
                • LOAML Offline
                  LOAM
                  @sob80sup81 said:
                  Hello,
                  Would also like to know this as it doest work in SU2017
                  • Bob JamesB Offline
                    Bob James
                    • jujuJ Offline
                      juju
                      @bob james said:
                      [attachment=0:1xmppw8w]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1xmppw8w]
                      works fine here in SU2017 as well
                      • LOAML Offline
                        LOAM
                        @juju said:
                        @bob james said:
                        [attachment=0:1aq04ju1]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:1aq04ju1]
                        It loads fine as per your image but try the following;
                        • Make a tree
                        • Reconfigure it, using right click, reconfigure
                        • Change tree parameters *
                        • Redraw tree using updated parameters **
                        • You will notice that many of the sliding bars are listed as NaN
                          ** Redraw does nothing after changing any of the parameters ๐Ÿ˜ž
                        http://i.imgur.com/Udv6s2S.jpg
                        • OxerO Offline
                          Oxer
                          Error in Ruby Console to load a tree:
                          Error; #<NoMethodError; undefined method `treetemplatename' for nil;NilClass>
                          /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1141;in `webtosu'
                          /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1117;in `block in initialize'
                          /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `call'
                          /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `find_support_files'
                          /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1171;in `populate'
                          /users/oxer/library/application support/sketchup 2017/sketchup/plugins/3darcstudiotree/3darcstudiotreemain.rbs;1137;in `webtosu'
                          SketchUp;1;in `call'
                          OSX 10.11.6 & SU2017
                          • LOAML Offline
                            LOAM
                            I've had an email back from ppoublan to say he is hoping to get this fixed in the new year.
                              karllarsen
                              @loam said:
                              @juju said:
                              @bob james said:
                              [attachment=0:2vnsbkfz]<!-- ia0 -->tree.PNG<!-- ia0 -->[/attachment:2vnsbkfz]
                              • Make a tree
                              I am having the exact same problem.
                              Less is more.
                                Jorgensen
                                has anyone got this to work with su2017?
                                thanks
                                jorgensen
                                  karllarsen
                                  It sure would be nice to know if this will ever work or its just a lost-cause?
                                  Less is more.
                                    I don't really have a need for it but I just installed it now because of your post. It seems to work fine for me. It makes trees like it says on the box.
                                      Works fine for me inside Su2017 Make ! โ˜€
                                      Make your change(s) then Right Click on the selection / Context Menu 3D Arc Studio Tree/ Redraw.
                                      Free version
                                      3DArcStudio Tree Maker Sketchup Plugin can be downloaded for free from this site. The free version gives you access to all features, except you are not granted the right to sell or distribute trees created with the plugin, you will get one message each time you change configuration and little time to wait before the tree starts drawing, and you will not get access to all the tree templates included in the full version. If you like this plugin, you can get a licence for 10 euros that will remove those limits.Possible with the free version
                                      Time was 5 s ๐Ÿ˜‰
                                      Rendered with the free SimLab Composer Light! maxi 1920 * 1080 ๐Ÿ˜‰ (a KeyShot like)
                                      Can reload quasi any format of files! ๐Ÿ‘
                                        PS But you right : Configuration Menu works not like inside Su2016! ๐Ÿ˜ฎ
                                        Seems some parameters are not responsive like "Number of truncs"...
                                        and more curious the 2 buttons Redraw and Draw Proxy!
                                        So it's a very good habit to keep old versions of SU! ๐Ÿ’š
                                          mwm5053
                                          I downloaded the plugin from Sketchucation store within SU just the other day and read the post about the difference between free and paid so I don't think that's the issue I'm having. The drop down list of templates shows none either for the trees or grass. May be some knows something I don't (which is entirely possible).
                                          2011 iMac
                                          SU 2015 Pro, 2017 Make
                                          V2 Twilight
                                          macOS Sierra 10.12.5
                                          • OxerO Offline
                                            Oxer
                                            The plugin does not work on SU 2017, try with SU 2016 or 2015.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 14 / 17
