    New version - Only render the Sky what is wrong?
    renderpluginsextensions
    13 Posts 6 Posters 3.7k Views 6 Watching
    • kaluK Offline
      kalu
      I try all and still have the same problem. I email chaos and see what they can do. In the mean time. I can keep try to see what is wrong.
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
      • andybotA Offline
        andybot
        does it still render blank when you render with material override? Then you may have some messed up geometry. Try deleting out any warehouse components first...
        • kaluK Offline
          kalu
          I fount he problem was a double side material that I never use and for some reason it was missing with some older geometry. Thanks for your help!. Corey from Chaos help me to fix the problem.
          Gonzalo.
          • andybotA Offline
            andybot
            Gonzalo.
            πŸ‘ Glad Corey was able to help. There does seem to be a bug in the current vfs 2.0 that the scene won't render if there are materials that are missing in Sketchup. There's been some posts about that in the chaos group forums.
            • andybotA Offline
              andybot
              I'm curious - did you try rendering with the material override? I'm curious if it was able to render that way.
              • TedVitale_CGT Offline
                TedVitale_CG
                It would do it no matter what, even if material override was enabled. Essentially Sketchup was inventing a fictitious material that didn't exist anywhere in the scene (weird little bug on SketchUps side). V-Ray just couldn't figure out what to do with it and would spit out an empty scene. It was very weird, but we've tracked down where it came from and have since fixed the bug. We will be releasing a patch that takes care of it very soon.
                Ted Vitale
                Owner | Creative Director
                http://www.voxl.vision
                • O Offline
                  Openspaces
                  Hello Guys,
                  Pardon me to barge into this, I have a similar problem.
                  But with mine, vray renders, and I put it to render again and I get the same blank frame buffer. But, if I shut sketchup down and back up again it renders fine again.
                  Any help with this will be appreciated.
                  • dkendigD Offline
                    dkendig
                    if you are able to send us the scene file, we could try to reproduce the issue on our end in a nightly build, where this issue has already been addressed. Alternatively, if you are interested in testing a nightly build on your machine, send me a PM.
                    Devin Kendig
                    Developer
                      lukeroach2011
                      Gonzalo.
                      how did you solve the problem .. please tell me very urgent. thanks in advance.
                        TedVitale_CG
                        @lukeroach2011 said:
                        Gonzalo.
                        Upgrade to the latest Service pack at http://www.chaosgroup.com
                        Ted Vitale
