    Keyboard shortcuts stopped working 2015
    31 Posts 11 Posters 16.9k Views 11 Watching
    • JQLJ Offline
      JQL
      Try resetting your shortcuts in the shortcuts panel. I've seen that happen to a lot of instalments and it makes all defaults work. Start adding custom shortcuts only after this.
      www.casca.pt
      Visit us on facebook!
        Tommy Point
        Resetting the shortcuts worked! Thank you so much CASCA. Now I can stop banging my head off the wall. SketchUcation is such a great resource.
          Tommy Point
          Also, for future reference, to reset Shortcuts, on the SU menu bar, go to Window > Preferences > Shortcuts > Reset All.
          Attention Required! | Cloudflare
          (help.sketchup.com)
          • KathrynGK Offline
            KathrynG
            Hoping someone sees this since I am not using 2015 but 2016 but did not think I should create another thread.
            I just upgraded to a new 27" iMac, and using SU 2016. Everything worked perfectly for the first couple of weeks, and then yesterday for no apparent reason my shortcuts stopped working? Frustrating having to keep going to the tool bar, so how can I fix this please?
            "With SketchUp - Rome could have been built in a day!"
              rv1974
              KathrynG, it's a well known bug. Unfortunately SU shortcuts don't work in 27" space.
              • KathrynGK Offline
                KathrynG
                Hmmm... that's weird, because they did for the first two weeks that I had the new computer - flawlessly, and then yesterday - boom, just stopped. I also just went to my preferences and added some new ones, such as putting back the space bar for the selection tool and Command B for the orbit tool and a couple of others and they seem to be working?
                I will have to keep an eye on it, and see what happens. Thanks for responding.
                • KathrynGK Offline
                  KathrynG
                  Yup - just went back to check and all the new ones that I added are working just fine.
                    rv1974
                    πŸ˜† I was kigdding. Look.. How 27" diagonal could influence shortcuts?
                    • KathrynGK Offline
                      KathrynG
                      Don't kid... I'm gullible. Or at least on these forums I am, since compared to everyone else here I am undoubtedly the dimmest, and have gone through my life having no confidence in any of my abilities. Ergo - thinking that everyone else knows more than me. Don't know that I grasp the inner workings of the abyss of technology, I just skim the surface, and thought that maybe it had something to do with the whole construct of the 27", not just the size of the monitor. Actually... I also kind of thought that maybe you were just a bobo too πŸ˜‰ because some of the answers one gets on these forums are definitely just roll your eyes moments, even for me. πŸ˜„ Cheers! Can't even find the darn emoji for sticking out tongue - I rest my case, sheesh.
                      • JQLJ Offline
                        JQL
                        What a nice display of fair play! Cheers Kathryn!
                        www.casca.pt
                        • hellnbakH Offline
                          hellnbak
                          I very much agree. Well done, well said, Kathryn!
                          • KathrynGK Offline
                            KathrynG
                            Reaching out to hellnbak and JQL please. As Charlie Brown would say - "RATS!" or 'GOOD GRIEF!" I set up my keyboard shortcuts, and was happy to do so as I assigned keys that made more sense to me personally for each tool that I use the most.
                            Working great, and then SU crashed. (Does that quite a bit with me - usually when I try to render my model using my well loved LightUp.) Frustrating, but thank goodness for the auto-save feature. Once I restart SU though, all those carefully set up keyboard shortcuts that I assigned are history. What am I missing here?
                            Thank you both in advance for your help. Keyboard shortcuts do absolutely speed up work flow and I am lost without them.
                              slbaumgartner
                              Kathryn, I fear that (to paraphrase Simon and Garfunkel) when they're gone, they're gone. Unless you had a backup. To protect yourself in the future, the Window->Preferences->Shortcuts panel has import and export buttons you can use to create a copy in a safe place.
                              • KathrynGK Offline
                                KathrynG
                                Thank you, I will do that. I just did not understand why though after all these years of being a Newbie SU user πŸ˜‰ and never having them go AWOL before that they have started doing this?
                                No point whining anymore - will just do as you suggest and move forward.
                                Ta ever so much. πŸ˜„
                                • BoxB Offline
                                  It sounds like you really need to find the root of the problem.
                                  If it only happens after using Lightup then that needs exploring.
                                  More info and testing may solve it, but not being fluent in Mac or lightup I can't add anything else.
                                    driven
                                    Kathryn,
                                    it may well be Autosave that's crashing LightUp...
                                    if it kicks in during any intensive process it can bring SU to it's knees...
                                    ⌘S is one of the best shortcuts to use religiously
                                    • 2 / 2
