    [Plugin] 2D Tools
    791 Posts 178 Posters 770.7k Views 177 Watching
    • josephkim626J
      josephkim626
      I can't possible understand everything that you described, but there is no urgency in this. So, I wouldn't mind letting your genius brain do its magic.
      I've also noticed upon undo with fillet tool, it adds extra undos in case of fillet radius value change. I do not know if that was an intended behavior, but I find it a bit odd. Maybe that's something that ties with your methodology?
      Thank you TIG. πŸ‘
        Here's v7.0 http://sketchucation.com/pluginstore?pln=2Dtools
        It's made into an extension.
        The Fillet tool now sidesteps the issues from some 3rd-party plugins EntitiesObservers.
        Also general future-proofing.
        • josephkim626J
          josephkim626
          Beautiful TIG!
          I will try it out as soon as I can!
          I thought you were gonna sleep on it πŸ˜‰
            Going to sleep now !
            πŸ˜‰
              Here's v7.1 http://sketchucation.com/pluginstore?pln=2Dtools There are several minor coding tweaks to try and work around a reported MAC issue [with my LayerWatcher!]...
              Feedback appreciated...
                Here's v7.2 http://sketchucation.com/pluginstore?pln=2Dtools There are several more coding typo fixes to try and work around a reported MAC issue [with my LayerWatcher!]...
                  Here's v7.3 http://sketchucation.com/pluginstore?pln=2Dtools The tool that used to set up the main tools' commands has been recast as a simple class instance, to avoid issues with MACs caused by having a tool activated as SketchUp initially loads...
                  • I
                    ivreich
                    Hi TIG
                    I've found a new bug with v7.3 of this plugin when running SU 2016...
                    When creating 2D fillets , the resultant geometry no longer shows as pure arcs, but exploded edges. Have attached a screenshot.
                    There are no ruby console error messages, and it works fine in SU 2015.
                    Cheers!
                    Joel
                    Exploded edges, with some strange selection behaviour (2 selected at the same time with a single click)
                      The 2d fillet's creation was changed to avoid problems with the new Observer regime in v2016.
                      This is the first reported issue.
                      I just retested it [v7.3 with v2016] very extensively and I got a perfect arc for the fillet every time...
                      But obviously that change looks like the probable cause of your glitch...
                      Does it occur every time for you ?
                      Do you have many other plugins loaded which might have skewed entities observers etc ?
                      Can you please post a simple SKP, with before and after examples of what you are seeing...
                      • I
                        ivreich
                        Hi TIG
                        I'm not sure how to check if my other plugins conflict with 2D tools, but I've attached a SU 2016 file showing what I get when I try to fillet 2 edges with the plugin. It occurs every time with SU 2016, but works fine with SU 2015 (for me).
                        Hope this helps!
                        Cheers,
                        Joel
                        SU 2016 file
                          Very weird. I just opened your SKP file and selected the fillet. It's not exploded and reports as an arc with a radius which it wouldn't do if it was or had been exploded.
                          Click on the picture.
                          Edit: Even weirder is that I get the same exploded arc when I run the 2D Fillet tool on the other corner. And notice one segment remains highlighted when I click on the others with Select. No modifier key was being held. Entity Info reports edges selected not an arc.
                          Click.
                          • I
                            ivreich
                            Yup that is very weird. But the second image you described is exactly what happens whenever I try to run the fillet tool on SU 2016...one edge remains consistently highlighted and the curve reports as a series of edges...not an arc.
                            Cheers
                            J
                              OK
                              I can see it happening too 😲
                              It the two picked Edges form a Face, then the Fillet is an Arc.
                              It those Edges have no Face then the Arc is getting exploded into weird bits !
                              All my tests were on faced-edges - which is supposedly the more awkward process !
                              I'll investigate - I'll announce the update as soon as I find the problem - and fix it...
                                Here's v7.4 http://sketchucation.com/pluginstore?pln=2Dtools
                                The Fillet tool is changed for compatibility with all + >= v2016
                                [important when its fillets are NOT applied onto a faced area]
                                Also the Fillet tool now helpfully highlights selected lines etc.
                                • I
                                  ivreich
                                  Brilliant, Thanks TIG
                                  Cheers,
                                  J
                                  • JQLJ
                                    JQL
                                    I noticed I cannot change linetype. It says right click for options but right click shows a context menu without any 2D tool entries.
                                    www.casca.pt
                                    Visit us on facebook!
                                      To [re]set the Line-Style you have to right-click in 'open space', otherwise the right-click activates the default context-menu...
                                      • JQLJ
                                        JQL
                                        Does it count if you are inside a group/component, with hide rest of model turned on and click on empty space there.
                                        The first entry actually says "close group" and then I have some context menu options as you say.
                                        www.casca.pt
                                          @JQL
                                          You're right - after all of these years !
                                          There is no context-menu when right-clicking in empty space in the model entities context, but there is when inside an edit mode...
                                          You can of course set the 2dLineStyle when in the model entities context and that will be used in the edit context.
                                          Or use the default 2dLineStyle on one piece and then select it and edit its 2dLineStyle, resetting the selected's 2dLineStyle that way...
                                          It also occurs in the '2dHatch' tool, when trying to reset the 'PATT' !
                                          This is clearly quite unsatisfactory - so I'll look at how I might fix it...
                                          • JQLJ
                                            JQL
                                            @tig said:
                                            @JQL
                                            LOL it's all your fault! I was working inside sectioncutface group!
                                            After your release of the latest SectionCutFace, where XY axis are parallel to section planes (I only requested it, it's your fault you developed it πŸ˜„), I've been rethinking my workflow for doing more stuff in sketchup than in LO. This includes linework of course and your dashed lines came to mind. I knew they were there but hadn't used them before...
                                            As you're diving into this again, have you ever tought of drawing a sequence of lines for your dashed lines instead of faces?
                                            That would allow us to use styles to control thickness instead of having a fixed face width, and it would allow us a bit more control on scenes displayed at multiple scales inside LO.
                                            (I would personally have a hard time with it as I'm using profiles to control width but...)
                                            www.casca.pt
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 39
                                            • 40
                                            • 34 / 40
