    [Plugin] FreeDXF Importer
    148 Posts 41 Posters 180.8k Views 41 Watching
      SGC
      @tig said:
      Yes, make sure that your IE Internet Options settings for Javascript etc are not overly strict...
      Can you get other web-dialogs to work OK ?
      I wanted to update this - I do not have problems with other dialogs. Infact, this same plugin works fine in my SU13. My work around has been to revert back to my SU13, call up the plugin, import, save, and open in SU14. So I can't imagine the dialog box error coming from IE if the same plugin works through a different version of SU.
        rsa
        @jim said:
        Yeah sorry. Splines are added incorrectly as straight lines between points. I just have not figured out how to handle splines in the dxf yet.
        It may help to convert the .dxf to an older version using this: http://www.opendesign.com/guestfiles/TeighaFileConverter
        Hi Jim,
        I let myself to modify draw_spline methods.
        I used bezier curve instead of lines for drawing splines.
        Curves can be edit by "su bezier" plugin πŸ˜„
        If you interested I happy to send you code.
          Jim
          @rsa said:
          Hi Jim,
          Yes of course. That would be great! Thank you.
            Jim
            Updated to version 0.9.0 with support for SPLINE entities thanks to rsa.
            Splines are added to the model as Bezier curve objects, and are editable through the right-click menu.
            Update available through the SketchUcation Plugin Store.
              tweyermann2
              THANK YOU SO MUCH!! I HAVEN'T BEEN ABLE TO FIND A PLUGIN THAT WORKS SINCE SKETCHUP 2015 REMOVED DXF SUPPORT FOR THE FREE VERSION. THANK YOU!!!!!!! πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
              • W Offline
                wootton
                Does version 0.9.0 work with SketchUp 2015 free version? I'm currently using v0.8.2 with SketchUp 2014 (works great, thanks!)
                Tom Wootton
                  Jim
                  Yeah, 0.9.0 works on 2015 Make.
                    abbis
                    Hi All,
                    Can anyone please assist. I am working on a MAC, (OS X 10.8.5), I have Sketchup Make 2014 installed, and I have installed the FreeDXF v0.11.1
                    I am trying to import the attached .dxf file. (which is an export from a GIS program). The file opens easily in CAD lt2011 as well as in vector programs such as Illustrator.
                    When I first attempted to import the file nothing happened in sketchp. With the ruby console open I get the following error:
                    Error: #<Errno::ENOENT: No such file or directory - /volumes/projects/x training/buildinglines_saveas.dxf>
                    /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:54:in initialize' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:54:in open'
                    /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/dxf2ruby.rb:54:in parse' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:252:in import'
                    /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:219:in do_import' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/freedxf.rb:112:in block in do_options'
                    /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in call' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:82:in block in trigger_event'
                    /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in each' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/events.rb:78:in trigger_event'
                    /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:357:in event_control_callback' /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:311:in callback_handler'
                    /Users/abbijoustra/Library/Application Support/SketchUp 2014/SketchUp/Plugins/jf-FreeDXF/SKUI/window.rb:269:in block in add_callback' -e:1:in call'
                    Can anyone help?
                    Many thanks!
                    dxf file I have attemped to import
                      Jim
                      Is your filesystem set to case-sensitive?
                      Either way, try version 0.11.2 I just uploaded to the PluginStore.
                        driven
                        @abbis said:
                        Error: #<Errno::ENOENT: No such file or directory - /volumes/projects/x training/buildinglines_saveas.dxf>...
                        copy the file to your Desktop rather than using a mounted volume...
                        also, do you have TeighaFileConverter.app installed?
                        Jim, the new versions working well on my mac...
                          Jim
                          Thank you for verifying, John.
                            abbis
                            Ah!
                            Thank you very much John! The mounted volume seems to have been the issue. I can import the file fine now. Thanks Jim, I will install the 0.11.2 and give that a try shortly.
                              mgate
                              First of all, thanks a lot for your plugin, Jim.
                              Just a query about the Teihga converter.
                              The dwg import option doesn't work (with SKU 2015 Make and latest FreeDXF v.0.11.2).
                              The Teigha has been installed in the default folder, and works fine. However, in SKU when I try to import a dwg file, that format is not available in the dialog box (only the "Cad files" option for dxf files), as if the plugin doesn't grab the converter.
                              Does anyone solved the same issue?
                              Many thanks in advance for your help.
                                driven
                                are you importing from the Extensions or File menu item ?
                                  mgate
                                  through the Extensions (the dwg format is not available in FreeDXF Importer plugin)
                                  I looked into the Ruby file "teigha.rb". Is it required an additional file or library called "fileutils"? If so, that file is missing inside "jf-freedxf" folder.
                                  require "fileutils"
                                  module JF
                                    module FreeDXF
                                      module Teigha
                                        # Teigha Command Line Format is;
                                        #   Quoted Input Folder
                                        #   Quoted Output Folder
                                        #   Output_version {"ACAD9","ACAD10","ACAD12", "ACAD13","ACAD14", "ACAD2000","ACAD2004", "ACAD2007","ACAD2010"}
                                        #   Output File type {"DWG","DXF","DXB"}
                                        #   Recurse Input Folder {"0","1"}
                                        #   Audit each file {"0","1"}
                                        #   [optional] Input file filter (default;"*.DWG;*.DXF") (Use File.basename(filename))
                                         if Sketchup.platform == ;platform_win
                                            EXE = "C;/Program Files (x86)/ODA/Teigha File Converter 4.01.0/TeighaFileConverter.exe"
                                         else
                                            EXE = "/Applications/TeighaFileConverter.app/Contents/MacOS/TeighaFileConverter"
                                  In my WIN 8.1 Pro, the Teigha sofware is installed in the default folder too:
                                  Cheers!
                                  • hdpvH Offline
                                    hdpv
                                    I have some update!
                                    Suforyou
                                    http://www.sketchupforyou.com
                                      driven
                                      @mgate said:
                                      through the Extensions (the dwg format is not available in FreeDXF Importer plugin)[
                                      You can select a .dwg or a .dxf file and it should import...
                                      that's in the SU Ruby folder, so it's already available from there...
                                      have you tried it with 'Ruby Console' open to see if there are any error messages?
                                      the other thing to try is doing the conversion directly in TeighaFileConverter, if it fails there you may get a reason given...
                                        Jim
                                        Actually, I don't think fileutils is needed. I think I was going to use some methods in fileutils to search for the Teigha converter on the disk drive, but haven't got back to it.
                                        You can remove or comment out the line.
                                          mgate
                                          neither working if commented out the "fileutils" line.
                                          I have a folder with two files in dxf and dwg formats:
                                          snapshot of folder with dwg and dxf files
                                          Once opened the "FreeDXF v.0.11.2" pop-up window, there is only the dxf file (the dwg file is not available):
                                          snapshot of FreeDXF pop-up window
                                          Is there a problem with "extra extensions"?
                                          def self.select_file(extra_extensions = "")
                                                title     = 'FreeDXF Select DXF File'
                                                directory = nil
                                                # filename  = 'DXF|*.dxf|DWG|*.dwg||'
                                                filenames = "Cad Files|*.dxf" + extra_extensions + "||"
                                                file_path = UI.openpanel(title, directory, filenames)
                                                if file_path.nil?
                                                  return nil
                                                else
                                                  file_path.tr!('\\', '/')
                                                  @last_selected_file = file_path
                                                  return file_path
                                              def self.main
                                                 puts "\nFreeDXF debugging ON." if $JFDEBUG
                                                 extra_extensions = Teigha.available? ? ";*.dwg" ; ""
                                                 file_path = select_file(extra_extensions)
                                                 return if file_path.nil?
                                                 #file_path.downcase!
                                                 if file_path.end_with?(".dwg")
                                                    Teigha.dialog()
                                                    file_path = Teigha.convert(file_path)
                                                    if file_path.nil?
                                                       puts "dxf file was not created."
                                                       return
                                          Any idea how to solve?
                                          Another way is to convert dwg files manually with TeighaFileConverter, and then use FreeDXF plugin in SKU.
                                          Sorry to snoop around your codes 😐
                                            Jim
                                            This appears to be due to a difference between SketchUp 15 and SketchUp 16 UI.openpanel behavior.
                                            As a short-term work-around, can you try to enter a * then press ENTER in the filename dropdown to force all files to be listed?
                                            • 2 / 8
