    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 69.8k Views 40 Watching
    • KrisidiousK Offline
      Krisidious
      You know Whaat... You could do break off sister plugins. specialized?
      By: Kristoff Rand
        sherwood111
        Hello, has anyone received these error messages ?
        I drew a straight section of an few arbitrarily
        profiles .... crown105, crown106.
        (downloaded from the pb2 website)
        I experimented with extending and trimming to
        a perpendicular profile/face, etc.
        any thoughts on cause ?
        any ideas to remedy ?
        • W Offline
          Whaat
          [attachment=1:1bx1nwz4]<!-- ia1 -->trim_errror.msg.PNG<!-- ia1 -->[/attachment:1bx1nwz4]
          [attachment=0:1bx1nwz4]<!-- ia0 -->extend_errror.msg.PNG<!-- ia0 -->[/attachment:1bx1nwz4]
          In order to extend or trim a profile member, the end of the profile member must not have been modified. In other words, the ends need to look the same as they did right after the object was created. Re-building the member will re-create it so you can trim it again.
          • TommyKT Offline
            TommyK
            I do love this plugin. It so nearly feels native to SketchUp. For making geometry, it works great. I have a few suggestions to improve it though in the realms information (the "I" in BIM).
            1. Components over groups, please. Currently, PB creates groups from profiles. Groups are more limited in SU than components. For instance, you can't explore "Component Options" of a group. This would be useful for people who use Classifer.
            2. When using assemblies, it appears that PB deletes everything within the assembly group and redraws. This results in any layers or classifier information that have been assigned to the individual groups within the assembly to be lost whenever the assembly is rebuilt (when changing path, for example). Is there a way to retain each group (if it still exists), but alter the geometry within them?
            3. Profiles and assembly components are skp files, as you say. It would be great if these are imported into SU as components and the profile is made within the component that is imported. What this does is that any information within the component is preserved in the profile member. This includes component description, Classifier information etc etc.
            Other little thing:
            • when clicking to edit the profile of the profile member within a group (in the profile assembly window), it works the first time, but subsequent clicks to edit other profile members shows no change to the profile builder window. Strangely, right-clicking the window and selecting "reload" seems to work.
            Thanks for a great plugin! I would use it even more if it could do the information side of things.
            • utilerU Offline
              utiler
              Hi Dale, Happy New Year!
              A few queries re: building assemblies and where to use components or not.
              See attached images which I've added questions to each. Cheers, look forward to hearing back ASAP.
              Just Curious...
              • E Offline
                eselick
                Hi Whaat
                I'm wondering if you are aware of the problems that I and many others who are on Windows 10 are having when we try to download the Trial version of PB 2.
                A few seconds after the download dialog loads Sketchup crashes, usually with no error message or only a Windows, "this program has stopped working ..." message.
                All of this is quite fully documented at the Sketchup forum:
                http://forums.sketchup.com/t/extension-warehouse-download-attempt-crashes-su/18869/27
                Hopefully you can check it out and help get it fixed so that we can have a look at PB2.
                Elliot
                • W Offline
                  Whaat
                  @eselick said:
                  Hi Whaat
                  Elliot
                  Yes, thank you for the report. I am aware of the issue and the SketchUp EW team is working to help resolve this. I have made a change to the EW PB2 page. Please try again to see if the issue has been resolved.
                  Dale
                  • W Offline
                    Whaat
                    Hi utiler,
                    Thanks for the images. I am very aware of the issues you are facing. There is currently no easy way to do what you want. The workaround is to make the fence using two assemblies, one for the posts and another for the fence boards. The one with the fence boards must be created by clicking the center of each post. I am not sure if this makes sense. I hope to make this much easier in a future update.
                    • utilerU Offline
                      utiler
                      Thanks Dale, yes makes sense. I was just hoping to be able to push PB2 a bit that's all.
                      Cheers.
                      Just Curious...
                      • PixeroP Offline
                        Pixero
                        I'd love to be able to manually exchange a component somewhere and still be able to adjust the curve afterwards.
                        • W Offline
                          Whaat
                          Interesting idea, Pixero! Would you be able to describe a use-case for this feature? Thanks
                          • PixeroP Offline
                            Pixero
                            Here is a quick example of one case. There might be ways of doing some thing like this with different start and end components but I think this way would be easier for a lot of cases where you dont know the exact position until after its drawn.
                            • E Offline
                              eselick
                              I'm just getting started with this amazing and wonderful plugin.
                              My problem is that when I save my assembly and then reuse it a new model, one of the components, #2 "Corner" in the original, is missing in the saved Assembly.
                              Here's the original Assembly dialog from the skp where I created it followed by the one that's loaded from the Assembly browser:
                              http://s20.postimage.org/r5bksx08d/Original_Assemblywith_Corner_Component_Before.jpg
                              http://s20.postimage.org/gtz8098j1/Assembly_Missing_Component_After_Save.jpg
                              There are only 3 instead of 4 components in the second one.
                              Ideas?
                              • W Offline
                                Whaat
                                @eselick said:
                                Ideas?
                                Hello eselick,
                                Thank you for the report. Can you please do the following:
                                • Open the Ruby Console and check for error messages when you save and load the assembly.
                                • Send the assembly SKP file to mindsightstudios AT gmail DOT com for me to test
                                  rv1974
                                  I'm not sure in which topic it should be asked.. Luckily you're the author of both plugins (Profile Builder and Sketch UV.
                                  I applied tube SketchUV's tube mapping to the curb generated with PB.
                                  As you can see the vertical seams are distorted- they are not perpendicular to the 'U' path (I put the desired look above).
                                  Could you advice how to get the desired result with the present tools?
                                  And may be it's a good idea to have 'generate UV's' in the PB v.3?
                                  • W Offline
                                    Whaat
                                    Hi rv1974,
                                    Before you create the object using PB2, select the desired textured material from the drop-down list in PB2. Then, you should get your desired result automatically. SketchUV applies a different UV mapping scheme than PB2.
                                      rv1974
                                      Damn.. I actually use it but in this case it didn't popped up in my brain.
                                      You should emphasize this amazing feature in you promotions!
                                      Many thanks!
                                        rv1974
                                        Hm.. We've got problem on curved areas though.
                                        PB applies the same texture coordinates on every segment. 😢
                                          rv1974
                                          ..Meanwhile I found partial workaround:
                                          1.Select curved areas
                                          2.Apply tube mapping
                                          3.Triangulate to eliminate 100500 materials after export.
                                          Could this issue be addressed in future?
                                            Catalyst
                                            Thanks for this great plugin.
                                            When using the assembler inside a component, the assembler does not respect the component's axes.
                                            I'm using SU Pro 2016
                                            • 11
                                            • 6 / 11
