    Component origin as inference point
    5 Posts 3 Posters 700 Views 3 Watching
      Mark ADDS
      Is this possible / does it exist?
      When I drag a component into a drawing the component's origin is the point of insertion. Once it is inserted, however, the component's origin point seems to no longer be available as an inference point. Am I correct about this?
      Thanks,
      Mark
      • Rich O BrienR Online
        Yes, you would need to place a construction point at the origin point to have a point for the move tool to infer.
        Or if you've added that component then just use your component library to bring in a new instance and delete the existing one if it is placed incorrectly.
          Mark ADDS
          Thanks Rich.
          I see no native capacity for a permanent construction (guide) point. Is that correct? When I create one w the tape measure tool, or by drawing a circle and then deleting it (as suggested elsewhere), there is nothing (no "point") selectable or that shows up as an entity.
          Thanks,
          Mark
            I use a plugin, Pen Tools+, to draw points.
            Not sure if SketchUp does it natively?
            • TIGT Online
              There are several tools to draw cpoints [aka guide-points] - including Rich's excellent PenTools.
              http://sketchucation.com/pluginstore?pln=Pen_Tools
              and
              http://sketchucation.com/pluginstore?pln=tt_guide_tools
              This simple snippet pasted into the Ruby Console adds a cpoint at all selected component-instances' insertion points.
              Naturally, you'll need to have Guides set to be visible to see these cpoints...
              Sketchup.active_model.selection.grep( Sketchup;;ComponentInstance ).each{|e| e.parent.entities.add_cpoint( e.transformation.origin ) }
