    Small swing arm desk lamp
    36 Posts 6 Posters 9.6k Views 6 Watching
    • Bryan KB
      Final detail.
      • Bryan KB
        The little thin support rods for the shade were a pain. Who knew?
        Next will be color and then final renders.
        • Bryan KB
          Reverse view
          • Bryan KB
            Oops. Had the base scaled too big.
            • Bryan KB
              Just noticed this. πŸ˜†
              • HornOxxH
                HornOxx
                How can I join the dark side with a lamp ?!
                never trust a skinny cook
                • Bryan KB
                  Use the shadows! πŸ˜†
                  • cottyC
                    cotty
                    Reminds me of https://astro.uni-bonn.de/~dfischer/dark_sucker_2.html
                    πŸ˜‰
                    my SketchUp gallery
                    • Bryan KB
                      πŸ˜‰
                      πŸ˜† πŸ˜† πŸ˜†
                        A bit of a blinder mate, pun intended. Nice one.
                        • Bryan KB
                          Thanks.
                          • Bryan KB
                            First coloring. Test render with Twilight next
                            • Bryan KB
                              First render in Kerkythea. Looks terrible. This is why I need the upcoming book.
                              • Bryan KB
                                Twilight wouldn't even give me an image after 20 minutes.
                                Kerky looks bad.
                                I am definitely doing something wrong.
                                • pbacotP
                                  Try downloading the file that they use for the Twilight test render. It has a lamp --although the shade for that one is glass. Might be a start. You might copy the materials and lighting or look at what they did.
                                  http://twilightrender.com/phpBB3/viewtopic.php?f=13%26amp;t=4443
                                  • Bryan KB
                                    Excellent suggestion pbacot! Thanks. I'll try that next.
                                    Here is the result of no emitter and straight sky. I need to figure out how to get rid of the banding on the background. This is High 7+ in Twilight. I will probably need to go even higher.
                                    • pbacotP
                                      nice. Add a gap at the swivel joint so you see it's not one solid piece.
                                      • Bryan KB
                                        Oddly enough, there is already a gap there. Something about the render is making it disappear.
                                        I am currently rendering it with Exterior Daytime Progressive.
                                        • Bryan KB
                                          Higher definition render from Twilight. If you look close, you can now see the gap in the elbow pivot.
                                          The lamp shade is also now the proper color. This is new lamp just purchased a month ago.
                                            Nice, I can see one of those going nicely with my current cardboard box furniture theme. You seem to be getting a decent grip of twilight too.
                                            • 2 / 2
