    Question: how to project texture as a bow ?
    13 Posts 4 Posters 1.8k Views 4 Watching
    • wimveW
      wimve
      Hello all,
      At the moment I am trying to model some old Dutch fortification building.
      It is amazing how skilled they where with the use of masonry.
      So I have a challenge I can't solve : to get the stone texture curved above windows and doors.
      Please look at the picture as an example. It is the curved row of stones above the door I mean.
      Does anybody have a idea how to solve this other then drawing every stone separate ?
      The model looks like this at the moment:
      3D Model
      In real live :
      Best regards,
      Wim
      Holland
      http://www.petromax.nl/DeBeer.html
      • massimoM
        massimo Moderator
        http://sketchucation.com/forums/viewtopic.php?p=578259#p578259
        • wimveW
          wimve
          Thank you for the fast answer.
          But I ran into another issue: I can't download the shown plugins.
          I get to the plugin store I see the plugin, I hit the "log in to get it" and nothing happends. Where do I have to log in again ?
          Best regards,
          Wim
          Holland
          • cottyC
            cotty
            Besides Thrupaint (see link by Massimo), quad face tools (Thomthom) or SketchUV (Whaat) would work here too.
            my SketchUp gallery
            • cottyC
              cotty
              There should be a popup window for the login, maybe it's getting blocked?
              my SketchUp gallery
              • massimoM
                massimo Moderator
                So these links are not working for you?
                http://sketchucation.com/pluginstore?pln=FredoTools
                http://sketchucation.com/pluginstore?pln=TIG_splitTOOLS
                this is also needed for Fredo's thrupaint
                http://sketchucation.com/pluginstore?pln=LibFredo6
                • wimveW
                  wimve
                  Thank you all.
                  Yes downloading is working now. For some ereason between reading here and opening the link I was logged off, that is why it said log in, what I didn't understand since I was logged in, as far as I knew.
                  But it worked.
                  Now I will try installing and working with them.
                  Best regards,
                  Wim
                  Holland
                  • wimveW
                    wimve
                    After some guidance of TIG.
                    Voila:
                    Many thanks to all.
                    Best regards,
                    Wim
                    Holland
                    • cottyC
                      cotty
                      Nice!
                      I've been here some time ago, it's an impressive fortress...
                      my SketchUp gallery
                      • ntxdaveN
                        ntxdave
                        I just drew an arch and then tried to paint it with bricks using Thru Paint. I understand how to scale the brick but I could not figure out how to make it follow the contour of the arch. Can someone enlighten me or point me to some documentation/tutorial that I can follow?
                        Making me feel kind of silly ❓
                        Press F1...thank me later
                        • massimoM
                          massimo Moderator
                          Have you seen the mini-tut I linked to in my first post?
                          • ntxdaveN
                            ntxdave
                            😳 I did not - installed the plugins and it all worked just fine.
                            Thanks for your reply - again learned another valuable tool from this forum πŸ‘ πŸ‘
                            • massimoM
                              massimo Moderator
                              πŸ‘
