    Can one use the orbit tool with precision?
    28 Posts 7 Posters 4.4k Views 7 Watching
    • BoxB Offline
      I guess it'll be two years again for the next installment.
        djh
        One must have a spacemouse to constrain the rotation?
          djh
          @box said:
          Like this?
          Yes. How did you do it?
            slbaumgartner
            Drag exactly horizontally.
            • BoxB Offline
              My first gif shows me simply using orbit with the the middle mouse button. No tricks or fancy hardware. Just click and drag horizontally.
                djh
                Box, I have a Microsoft Wireless Mouse 5000. The middle wheel button doesn't do anything. I suppose that I need to get a different mouse. Thank you for your advice.
                • BoxB Offline
                  That begs the question, how long have you been using SU without a working navigation system.
                  You may only need to adjust the mouse settings. Find the settings for the mouse and set the wheel to Middle Mouse click or equivalent.
                    djh
                    I don't know. It still doesn't work for me. See attached.
                      Can you make the middle button do anything? Even in a different application? A while back I taught a SketchUp class in a school where they provided the computer. The Microsoft mouse they had required an awful lot of pressure to get that button to work. I wound up bringing in my own wireless mouse and using it instead.
                        djh
                        What mouse do you use?
                          I use Logitech mice on both my Mac and PC. Different models neither of which I can remember. The one I use on the Mac was the least expensive wireless Logitech mouse I could get locally. The other came with a wireless keyboard.
                          • BoxB Offline
                            Generally the cheapest simple three button scroll wheel mouse possible.
                            The more you pay the more the drivers can screw things up. The more the ergonomics can set the scroll wheel too far down to be an easy orbit without hitting the other buttons etc etc
                            • Jean LemireJ Offline
                              Jean Lemire
                              Hi folks.
                              I use a Logitech wireless mouse on my Mac. I did not install the driver that came with it. The Mac OS Mouse driver does the job very well.
                              If you use a driver, usually, you assign the scroll wheel as button 3.
                              Just ideas.
                                djh
                                Box, I got a new mouse. The middle button works, but I can't orbit precisely.
                                  djh
                                  ?Just click the left button,the right button, or the middle button?
                                    djh
                                    When I click using the middle button, it is not constrained. I can't keep the blue axis line at 12:00 6:00. I have a new mouse.
                                      Box wrote "the middle button".
                                      It'll be as constrained as your mouse movement is. There is no option to constrain orbit such that the vertical axis remains oriented at 12 and 6.
                                      Why is that important? The blue axis could only be oriented vertically on the screen if the camera is positioned so it is centered on the height of the model and the horizon line cuts across the screen dead center or if the camera is setting to Parallel Projection.
                                        djh
                                        Thank you Dave R and Box.
                                        In Coreldraw, one may constrain the vertical or horizontal movement by pressing Ctrl and dragging the mouse. Now, I realize that it's not really possible in SU. Though, one may approximate it if he has a very steady hand and by using the axis.
                                          slbaumgartner
                                          That's because CorelDraw is 2D! SketchUp is 3D. Orientation of axes is a whole different game when you are viewing a 3D space, especially when perspective camera is on.
                                          • 2 / 2
