    Small swing arm desk lamp
    36 Posts 6 Posters 7.7k Views 6 Watching
    • Bryan KB Offline
      Small swing arm desk lamp.
      Push Pull is giving me some serious grief. It either won't move the face or it moves too far and I have to use scale to size it to where I want.
      Anyway, WIP just to get back into the flow of things.
      • Bryan KB Offline
        Ah, Figured it out. The Joint Push Pull suite has superseded the stock Push Pull. Works perfect in Joint Push Pull Normal.
        • Bryan KB Offline
          Still having problems with other tools not moving smoothly.
          • Bryan KB Offline
            Just had to fiddle with the settings. Working better now.
            • Bryan KB Offline
              More refinements. Lampshade coming.
              • HornOxxH Offline
                HornOxx
                I like these "step by step" posts very much - thanks for sharing this one and please continue πŸ‘
                never trust a skinny cook
                  Nice one.
                  • Bryan KB Offline
                    Thanks. I skipped a lot of steps but as most of it is simple cylinders, I didn't think each individual step was necessary.
                    • Bryan KB Offline
                      @mike amos said:
                      Nice one.
                      Thanks. This is mostly a project to get 2015 set up and running. This is the first time I've used 2015 to make a model, so I needed to tweek and configure the preferences and learn where some of the setting controls moved to.
                      You would not believe how long I struggled with the new arc tools. πŸ’š
                      • cottyC Offline
                        cotty
                        +1
                        my SketchUp gallery
                        • Bryan KB Offline
                          Switch and electrical socket stack detail.
                          • Bryan KB Offline
                            Not much to look at, but here is the lamp shade.
                            • Bryan KB Offline
                              Final detail.
                              • Bryan KB Offline
                                The little thin support rods for the shade were a pain. Who knew?
                                Next will be color and then final renders.
                                • Bryan KB Offline
                                  Reverse view
                                  • Bryan KB Offline
                                    Oops. Had the base scaled too big.
                                    • Bryan KB Offline
                                      Just noticed this. πŸ˜†
                                      • HornOxxH Offline
                                        HornOxx
                                        How can I join the dark side with a lamp ?!
                                        • Bryan KB Offline
                                          Use the shadows! πŸ˜†
                                          • cottyC Offline
                                            cotty
                                            Reminds me of https://astro.uni-bonn.de/~dfischer/dark_sucker_2.html
                                            πŸ˜‰
                                            my SketchUp gallery
