    How? Roundover All Edges Of Cube
    33 Posts 4 Posters 6.5k Views 4 Watching
    • T
      TurninMan
      Ok. The component resize trick makes a lot of sense.
      Here's another problem though in the execution of the follow me tool.
      Where do I place the profile in my scenario? My method so far has been to draw the quarter round in a square, rotate all of that vertical, delete the vertical unwanted line, then move this by the point that used to be at the top corner of the square, to the inside of the "cube".
      This makes selecting the face that needs to follow the top edge, very difficult, even with "X-ray" turned on...
      This make sense?
      • cottyC
        cotty
        I've read your text three times but ... maybe you can help me with some images?
        my SketchUp gallery
          Notice in Cotty's screen shot the vertical edge on the profile is centered on the yellow square. Set yours up that way, too. If you do that, there should be no internal edges of faces to delete.
          Also notice how he left separation between the purple and yellow faces as I did in the video I linked to. Follow Me is both additive and subtractive. The additive part is what you want in this case. If you draw the profile in contact with the face of the path shape, there'll be a hole in the bottom of the resulting round-cornered box. You can also delete the face inside the path shape prior to running follow Me, too. You really only need the edge for the path, after all.
          • T
            TurninMan
            Sorry guys, my popup blocker kept me from seeing any images.
            I see what I'm doing wrong. You are starting with the flat face/path and creating a profile that actually creates the rounded cube.
            I was starting with the flat face/path, then push/pull it up to a form, then applying the profile to that form.
            What I'm really trying to create is a rectangular piece 14" x 30" x 3/4" thick, that has a 1/8" roundover on all edges.
            So here's what it looked like just after placing the profile in position:
              The process would still be similar to what we've been describing. In fact, to make it easy, start with a 14 x 14 square and draw a 3/4-in.-tall profile with 1/8 in. radius corners. Basicall the same as what Cotty shows but less tall and with smaller radius corners. Make the component and copy it. Scale the copy up and run Follow Me as in the video. Close and delete the big copy.
              When you return to the original copy, open it for editing, expose hidden geometry with View>Hidden Geometry. With the Select tool, drag a left to right selection box around one end of the shape. Get the Move tool and move it away from the opposite end making sure you stay on axis. Type 16 and hit enter. (16" + 14" = 30", right?)
              There are other ways to do this like creating what is effectively a donut and then skinning over the hole but that requires deleting a bunch of unneeded edge and can be more work.
              • T
                TurninMan
                So the profile would be 3/4" tall and 7" wide?
                  Yes.
                  Stand by for a PM.
                  • T
                    TurninMan
                    Maybe one more tip...
                    I've been drawing up the square, then putting squares in each corner, then drawing the arc for the roundover, editing it to the right radius with entity info, then deleting the unwanted lines. Is there a faster way to round off each corner?
                    • cottyC
                      cotty
                      Newer verions allow to use a double click in the near of a corner to repeat the last rounding...
                      click to animate
                      my SketchUp gallery
                      • T
                        TurninMan
                        I've followed the directions, but I'm still getting screwy results.
                        So here's some screen caps. The first is the setup. I've got a 14x14 square with 1/8" rounded corners as the base, and a 3/4" x 7" profile with the right end dead center of the square about 2" off the base.
                        When I go to extrude, I get this message that the extrusion doesn't begin and end on the profile, and then all the corners are open...
                        • T
                          TurninMan
                          OH! Guidelines, of course! That alone will speed up the process.
                          But I can't seem to get the darn thing to do a tangent corner round to save my life. Sketchup is balky in my hands...
                          • cottyC
                            cotty
                            @cotty said:
                            • scale up your model to prevent the holes
                            Again?
                            my SketchUp gallery
                            • T
                              TurninMan
                              Hey... Be nice. I'm a slow learner... 😎
                                Did you see my PM to you?
                                • T
                                  TurninMan
                                  Well @#!%$!
                                  I made the profile and square a component. Then I scaled it up 100. Then I extruded. It looked great. Then I saved... and then it looked like this:
                                  • T
                                    TurninMan
                                    I didn't know I had a PM, because I'm not sure where the flag shows up. But I answered it.
                                    • T
                                      TurninMan
                                      So I tried the corner rounding trick in Version 2014, and I can get as far as the tangent arc, but don't see how to get it to crop...
                                        Don't fight it anymore. I'll show you soon.
                                        • cottyC
                                          cotty
                                          I don't think 2014 is a newer version πŸ˜‰
                                          my SketchUp gallery
                                          • T
                                            TurninMan
                                            Ha Ha! πŸ˜† It's a lot newer than V7 and V8!
