    SketchUp 2016 is here....
    162 Posts 59 Posters 40.1k Views 59 Watching
    • pmolsonP Offline
      pmolson
      Thank you!
      • pmolsonP Offline
        pmolson
        @kaas said:
        @pmolson said:
        Is there a way to dislodge the layers dialog box from the default Tray. I like the tray, especially with autohide enabled, but I would like to get the layers dialog out of there and float it wherever I want...
        Create a new tray just for the layers and drag it off the docked position (double click).
        Window-manage trays-new etc
        I created the new trays as you instructed and it worked great.
        A follow up questions if you don't mind.
        in the image below I am showing my newly created trays docked on the right side under the default tray.
        I like it because when I access the new trays I get a full length dialog box allowing me to see a nice long list of layers or components at a glance. or I can dislodge it and drag it onto another screen.
        When I opened a new drawing the new trays were not there. Are they really drawing file specific?
        is there a way to set them to be part of my standard template file?
          kaas
          @pmolson said:
          ...When I opened a new drawing the new trays were not there. Are they really drawing file specific?is there a way to set them to be part of my standard template file?
          Strange, I just tested it and when I open a new session they are in the same position where I left them when I closed SketchUp.
          Not sure whats happening here. Maybe a rights-issue?
          • JQLJ Offline
            JQL
            If you have two sessions open and close one that has the desired layout AND THEN close one that is incorrect, when you open sketchup the last one is the one saved, so it's the incorrect layout.
            You should set things up with A SINGLE sketchup instance open and it should save correctly.
            www.casca.pt
            Visit us on facebook!
            • pmolsonP Offline
              pmolson
              Worked like a charm.
                bsfranza
                hey guys, quick question - where can i set maxium texture size? before version 2016 there was unter windoe/model info/rendering the possibility to use max texture size!!
                would be very nice if this was there in 2016 too - maybe it is but i cant find it:/
                • cottyC Offline
                  cotty
                  It is (and was) here: preferences -> OpenGL
                  my SketchUp gallery
                    bsfranza
                    found the solution - ... sorry πŸ˜ƒ i must sleep i think
                      pipingguy
                      Not sure how to hide trays, like Paul did, so just their tabs are displayed. All I can manage to do is dock them with the help of those blue and white arrow glyphs that pop up when I drag a tray around the screen.
                        spadestick
                        Brad Schell and Joe Esch need to start up a new company. They had a huge following, they sold out, they retired, and they should be tired of retiring by now and do something meaningful like come up with a better Sketchup!
                        • H Offline
                          Heaps
                          How about SU for the iPad Pro ?
                          • pmolsonP Offline
                            pmolson
                            create your new tray -( window-new tray ) then follow prompts.
                            once you have your new tray floating on your screen do the following.
                            You can then click the little staple thing again to undock it when you want to, and just double click it and auto hide it again to put it back.
                              pipingguy
                              thanks!
                              (Isn't it fun using a mouse to write words on a clipping tool's screen cap?)
                              One thing I noticed with the materials tray - when you strike the B key, the tray does not automatically pop open.
                                kaas
                                @pipingguy said:
                                ...One thing I noticed with the materials tray - when you strike the B key, the tray does not automatically pop open.
                                Did you bind the B key to the tray-toggle?
                                • pmolsonP Offline
                                  pmolson
                                  Go to windows / preferences / shortcuts
                                  add the letter of your choice.
                                  I noticed many of the old default shortcuts to have gone missing in 2016
                                  • JQLJ Offline
                                    JQL
                                    [attachment=0:1ihgs1kq]<!-- ia0 -->b.JPG<!-- ia0 -->[/attachment:1ihgs1kq]
                                    If any of you hit the reset button the default buttons will be back up, even if you have none set.
                                    www.casca.pt
                                      CalypsoArt
                                      I have not installed 2016 yet. However, I've just read this thread and there much talk about the LO styles "Tray" in SU. This has me very apprehensive. (I do not like the tray system of LO.)
                                      I have a Dual 30" monitor set up. In the software packages I use, my Right monitor is for the actual work screen, and the Left has all my panels open. e.g components, materials, layers etc. Am I understanding correctly that the trays can only be docked to main work space (my Right monitor) and I can't move them to the second monitor? As it is, I don't expect much from Trimble. But really, for me anyway, the trays are a backward step.
                                      • BoxB Offline
                                        You can have multiple trays. They can be docked left, right, top or bottom, they can float and can be moved to other monitors. They can autohide or remain static.
                                        • Z Offline
                                          Zacchia
                                          I tried to use Trimble Connect, made a Login and tried to share a file. But allways when i "Trimble Connect - open or publish model just nothing happens. If i open Trimble connect there is "no Project". Did anyone tried this out?
                                          • N Offline
                                            nicolasnourry
                                            Obviously the people developing Sketchup doesn't use it at all, the same annoying bugs are still here, and the new features are just inexistent.
                                            This is so frustrating, puzzle games on iPhone have more improvements on each updates than Sketchup releases.
                                            SKP 2015 (14.1 really) was already poor in innovation but 2016 (14.2) just got a +1 to its current name.
                                            What have they been doing for 1 years, gathering crappy jpgs for the "new" textures ?
                                            I could post a full list of bugs and needed features, but they obviously do not care as many people already done that with no results.
                                            • 7 / 9
