    SketchUp 2016 is here....
    162 Posts 59 Posters 35.8k Views 59 Watching
    • david_hD Offline
      david_h
      Yeah! what he said! πŸ’š
      So.. .I didn't explain it well . .as I figured I wouldn't. All I meant was that if you have a structure of nested components--a nice feature for me would be to have a control on the visibility of said components when editing so that when instead of "hide rest of Model" you get can see all or some of the other components in the tree but not the rest of the model. For example . . if I have a component B in Model A I can work on Nested F component but maybe only see E or D not everything else?
      A>B>C>D>E>F
      There. That should make it much more clear right? πŸ˜’
      Now I feel bad cuz I hi=jacked this thread. I'll shuddup now.
      • pmolsonP Offline
        pmolson
        I have been using 2016 for a few days now, and I have no complaints.
        I do have a question though.
        Is there a way to dislodge the layers dialog box from the default Tray. I like the tray, especially with autohide enabled, but I would like to get the layers dialog out of there and float it wherever I want.
        I tend to have a lot of layers and the tray forces me to awkwardly scroll up and down to access.
        Paul
          kaas
          @pmolson said:
          Is there a way to dislodge the layers dialog box from the default Tray. I like the tray, especially with autohide enabled, but I would like to get the layers dialog out of there and float it wherever I want...
          Create a new tray just for the layers and drag it off the docked position (double click).
          Window-manage trays-new etc
          • pmolsonP Offline
            pmolson
            Thank you!
            • pmolsonP Offline
              pmolson
              I created the new trays as you instructed and it worked great.
              A follow up questions if you don't mind.
              in the image below I am showing my newly created trays docked on the right side under the default tray.
              I like it because when I access the new trays I get a full length dialog box allowing me to see a nice long list of layers or components at a glance. or I can dislodge it and drag it onto another screen.
              When I opened a new drawing the new trays were not there. Are they really drawing file specific?
              is there a way to set them to be part of my standard template file?
                kaas
                @pmolson said:
                ...When I opened a new drawing the new trays were not there. Are they really drawing file specific?is there a way to set them to be part of my standard template file?
                Strange, I just tested it and when I open a new session they are in the same position where I left them when I closed SketchUp.
                Not sure whats happening here. Maybe a rights-issue?
                • JQLJ Offline
                  JQL
                  If you have two sessions open and close one that has the desired layout AND THEN close one that is incorrect, when you open sketchup the last one is the one saved, so it's the incorrect layout.
                  You should set things up with A SINGLE sketchup instance open and it should save correctly.
                  www.casca.pt
                  Visit us on facebook!
                  • pmolsonP Offline
                    pmolson
                    Worked like a charm.
                      bsfranza
                      hey guys, quick question - where can i set maxium texture size? before version 2016 there was unter windoe/model info/rendering the possibility to use max texture size!!
                      would be very nice if this was there in 2016 too - maybe it is but i cant find it:/
                      • cottyC Offline
                        cotty
                        It is (and was) here: preferences -> OpenGL
                        my SketchUp gallery
                          bsfranza
                          found the solution - ... sorry πŸ˜ƒ i must sleep i think
                            pipingguy
                            Not sure how to hide trays, like Paul did, so just their tabs are displayed. All I can manage to do is dock them with the help of those blue and white arrow glyphs that pop up when I drag a tray around the screen.
                              spadestick
                              Brad Schell and Joe Esch need to start up a new company. They had a huge following, they sold out, they retired, and they should be tired of retiring by now and do something meaningful like come up with a better Sketchup!
                              • H Offline
                                Heaps
                                How about SU for the iPad Pro ?
                                • pmolsonP Offline
                                  pmolson
                                  create your new tray -( window-new tray ) then follow prompts.
                                  once you have your new tray floating on your screen do the following.
                                  You can then click the little staple thing again to undock it when you want to, and just double click it and auto hide it again to put it back.
                                    pipingguy
                                    thanks!
                                    (Isn't it fun using a mouse to write words on a clipping tool's screen cap?)
                                    One thing I noticed with the materials tray - when you strike the B key, the tray does not automatically pop open.
                                      kaas
                                      @pipingguy said:
                                      ...One thing I noticed with the materials tray - when you strike the B key, the tray does not automatically pop open.
                                      Did you bind the B key to the tray-toggle?
                                      • pmolsonP Offline
                                        pmolson
                                        Go to windows / preferences / shortcuts
                                        add the letter of your choice.
                                        I noticed many of the old default shortcuts to have gone missing in 2016
                                        • JQLJ Offline
                                          JQL
                                          [attachment=0:1ihgs1kq]<!-- ia0 -->b.JPG<!-- ia0 -->[/attachment:1ihgs1kq]
                                          If any of you hit the reset button the default buttons will be back up, even if you have none set.
                                          www.casca.pt
                                            CalypsoArt
                                            I have not installed 2016 yet. However, I've just read this thread and there much talk about the LO styles "Tray" in SU. This has me very apprehensive. (I do not like the tray system of LO.)
                                            I have a Dual 30" monitor set up. In the software packages I use, my Right monitor is for the actual work screen, and the Left has all my panels open. e.g components, materials, layers etc. Am I understanding correctly that the trays can only be docked to main work space (my Right monitor) and I can't move them to the second monitor? As it is, I don't expect much from Trimble. But really, for me anyway, the trays are a backward step.
                                            • 7 / 9
