    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Corona Renderer for Sketchup
    extensions
    34 Posts 14 Posters 26.2k Views 14 Watching
      spadestick
      Good news! The Corona Team has begun Beta testing for Sketchup... It is going to be sweet ๐Ÿ˜„
      The unintuitive and slow VRAY is going to have some serious competition now.
        rv1974
        Great!
        Do you mean the Vray's (for SU ) slow development?
        • srxS Offline
          srx
          I bet you haven't tried Thea 4 SU.
          www.saurus.rs
            I am not sure that we can say Thea 4 SU is Intuitive! ๐Ÿ˜‰
            • soloS Offline
              It certainly is more intuitive than Vray IMO.
              Is Corona render CPU or GPU?
              • srxS Offline
                srx
                Well, you chose Presto engine and press button...Other settings are also very simple to do. You chose material from the browser and paint in SU. You set camera as you would set real camera. I really don't see anything more complicated than SU itself. And it is very fast interactive render inside SU window. GPU+CPU+network!
                Corona renders looks fine with CG stars on it's side. It has hi class promotion (lot of money for marketing), but I doubt it is faster than Thea, being CPU only...
                www.saurus.rs
                  spadestick
                  It's a high speed unbiased renderer. The quality is unmatched as shown in this attachment and the link to it here :
                  70mยฒ
                  Small apartment visualization done in 3ds Max and rendered in Corona.
                  Flickr (www.flickr.com)
                  It's not normal CPU based, and not the usual raytracing combined with global illumination. Normal CPU is super slow, it uses some special new algorithm to calculate something called Path Tracing. Unbeatable.
                  Here's a demonstration of the extreme power of Corona CPU rendering with scatter :
                    Seems scattering is the new paradigm of all today renderers! ๐Ÿ˜‰
                    http://getskatter.com/ here specially for SU! ๐Ÿ˜„
                      spadestick
                      srx, I don't believe a lot of money was paid or some "high class CG stars" are backing it as you put it. It seems many stumbled into it and almost all have come from the Vray background. That is why it still has a small and humble niche but steadily growing base, most of them seasoned Vray users - just like how Vray started small and pushed through to mainstream over the years.
                      One of the reasons why so many of these VRAY users make the switch is because they swear by the ease of use to get a very high quality render instead of pissing around with a thousand VRAY settings that have to be tweaked like crazy to come to something decent. Corona almost has the same Keep It Simple Stupid philosophy as Sketchup but with insane quality. It's hard to say that of VRAY. The beautiful thing is that they started like that and expanded on it. It is not like Windows 10, where they come up with an insane beast with layers upon layers of cancer on it and slap a new skin on it that is supposed to simplify things, but ends up making it slower and dumber.
                      Look, I don't own a copy or license of Corona, nor am I promoting it or helping them promote it. I love the ease of Twilight Renderer though though it is CPU based, and I believe I am fair when it comes to judgement of these rendering engines. I thought I would just settle with my bought versions of SU Podium, but that's history now after Twilight, which apparently is also based on Kerkythea. But this is all old tech and older algorithms, so I am a fan of better and improved algorithms that don't require people to buy fancy schmancy hardware and crazy GPUs to perform simple tasks.
                      With this remarkable algorithm I can now render from a lower end laptop to get the same speed and results as a souped up GPU machine with a GPU based renderer. I was super excited when this announcement was made and I formed a small part of that vote to make it happen.
                      Also a couple of long timer guys like Pilou and Solo kind of have seen me around in a past life, lamenting about the lack of adequate rendering quality and speed that most of the renderers seemed to produce. I gave up after purchasing Podium and stuck with that for awhile. Only the mid of this year I only ever heard of Corona and did the homework... and boy, has woken me up to the art of the render again.
                        spadestick
                        thanks pilou, you always find the strangest and coolest plugins! I suppose there is instancing with this Skatter function? Otherwise the model will break with so many polygons in Sketchup!
                        • soloS Offline
                          Very nice gallery images, in the right hands many render engines can create amazing results.
                          Path tracing is not new or unique, VrayRt uses it as well as Thea has a path tracing engine.
                          I am skeptical of any claims out there that challenge Thea on speed, not happened yet.
                          • srxS Offline
                            srx
                            @spadestick said:
                            spadestick, I see you mentioned Kerkythea, Twilight, but, somehow you missed Thea...so I advise you to try it. ๐Ÿ˜„ It has contemporary engine, works on CPU+GPU+network, inside Sketchup window, and it is very fast.
                            www.saurus.rs
                            • stefanqS Offline
                              stefanq
                              Look, I like what I see... nice images. I didn't tried it, but I believe all the users saying it's fast and simple. But, from my humble experience with rendering beautiful and believable images,you can't just have this kind of crazy beautiful output, from the engine alone. I see amazing materials as well, and boy, these can't be simplified. If the material editor is intuitive, simple, or at least similar with competition, then yes, it looks like a winner!
                                spadestick
                                You can't download it yet, but Beta testing is open and invite only. If someone can point me to a high quality modelled skp scene, I can use it to test it right out of the box - ie. press render immediately without any materials reflections or bumps set up (doesn't have that feature yet because the SU team on board is fresh and still sorting out these features I believe, and Corona has always tethered of the basic functions of Max / Blender including the material editors). Will post the results here, it normally displays the timings as well on my old and slow machine.
                                If you want to be a beta tester you can sign up on their forum which I won't link to from here.
                                srx, thanks I'm downloading the trial to try it out, and will feedback to you my thoughts and feelings on it.
                                • JQLJ Offline
                                  JQL
                                  That is impressive!
                                  You should really look at Thea! Really!
                                  www.casca.pt
                                  Visit us on facebook!
                                    peerman
                                    And the next step would be to also release it for the mac... I did download the corona benchmark and ran it under virtual box+win10. It was quite fast I must say. Ah well, still waiting for Vray 3 for SU.....
                                    iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
                                    • jiminy-billy-bobJ Offline
                                      jiminy-billy-bob
                                      By the way, Corona already supports Skatter ๐Ÿ˜„
                                      http://i.imgur.com/u9agUfg.png
                                        So skatter Power 2? ๐Ÿ˜‰
                                          cadmunkey
                                          This.
                                          GPU presto Thea absolutely crushes the competition.
                                          Plus surely output is only as good as the person using it, Corona won't suddenly make your bad texturing into superb renders.
                                          Same as any other renderer as far as I can tell, just another on the block to dilute the render pool. CPU only is a major flaw these days.
                                          • david_hD Offline
                                            david_h
                                            as Pete Said. . .in the right hands many render engines can create amazing results.
                                            With Thea. . .even a hack...er ahem .. novice.. . like me can get some pretty good results. Imagine what i can do in the hands of you Rendering wizards. Corona looks great too, but . I think its superpowers would be wasted on me.
