    Tube coping template wrappers
    18 Posts 7 Posters 2.2k Views 7 Watching
    • kenK Offline
      ken
      I believe this is what he requires. However, if he is working with actual tubing, something less than 3" in dia. he should scale up.
      I do this procedure all the time to for Gulf of Mexico oil structures. I haven't found a plugin to accomplish this task. I do it the old hard way.
      1. Make vertical pipe, 360 segments, so I have good accuracy on the coped pipe.
      2. The cope pipe has segments to the amount of actual refence line I require. I alway make sure that the number of segments is always a whole number of degrees. As an example, 360 degrees divided by 50 would give you 7.2 degrees for each segment. That means there is one segment that is not whole. I usually use 36 segment, which gives me a segment for each 10 degrees.
      3. I use the plugin "flattery" to flatten out each segment. Note to see each segment, you will have to turn on hidden lines.
      There you are, the complete layout. I know it shouldn't be hard to make a plugin to do this, however, I don't have the skills. Wish you luck.
      Ken
        gregw
        it's been many years since I've used one,but we used to call them "pipe saddle templates". We would make a pattern out of sheet metal and then trace it onto a piece of paper.
        • I Offline
          Iceracer
          This is exactly what Im looking for. If there is no plug in for it I would give a go at making one if there is a tutorial on making plugins.
            Once you do the intersect faces routine, you can use Jim Foltz's Unfold plugin to lay the wrapper out flat. Or as Ken did, use the Flattery plugin.
            • I Offline
              Iceracer
              Ok I just looked at some ruby stuff way over my head....
              what the intersect faces routine?
                It's a basic native thing to intersect faces. Select the surface of the wrapper, right click on it and choose Intersect Faces>With Model to create the intersection. Make the pipe a component or group first so it doesn't get modified during the intersection process.
                • sdmitchS Offline
                  sdmitch
                  Here is a quick and dirty Plugin that duplicates Ken's process.
                  def tube_coping
                  mod = Sketchup.active_model
                  ent = mod.active_entities
                  sel = mod.selection
                  vue = mod.active_view
                  @vtd ||= 6; @htd ||= 4
                  val = UI.inputbox(["V Tube Dia;","H Tube Dia;"],[@vtd,@htd],"Tube Coping")
                  if val
                   @vtd,@htd = val; grp = ent.add_group; gent = grp.entities
                   cir = gent.add_circle(ORIGIN,Z_AXIS,@vtd/2,360)
                   fac = gent.add_face cir
                   fac.pushpull -@htd*2
                   opt = ORIGIN.offset(X_AXIS,@vtd).offset(Z_AXIS,@htd)
                   htc = gent.add_circle(opt,X_AXIS,@htd/2,36)
                   vts = htc[0].curve.vertices.map{|v|v.position}
                   hpt = []; del = Math;;PI*@htd/36
                   #vts << vts[0]
                   vts.each{|v| hpt << mod.raytest([v,X_AXIS.reverse])[0]}
                   opt = ORIGIN.offset(X_AXIS,@vtd*2).offset(Z_AXIS,@htd/2);lpt=opt.clone
                   cpt = []; cpt << opt
                   for i in 0...vts.length
                    npt = lpt.offset(Z_AXIS,vts[i].distance(hpt[i]))
                    cpt << npt; lpt.offset!(X_AXIS,del) if i<vts.length-1
                   cpt << lpt
                   ent.add_face cpt
                   grp.erase!
                  http://sdmitch.blogspot.com/
                  • kenK Offline
                    ken
                    Darn sdmitch your quick on the draw.
                    One problem with your plugin, I show a 90 angle just to simplify the drawing. However, the angle can be any reasonable angle.
                    So if you add an input for the angle it should be good to go.
                    Ken
                    • sdmitchS Offline
                      sdmitch
                      Ken
                      How is the angle measured? From vertical? What should the min and max angle be?
                      • I Offline
                        Iceracer
                        The angle should be calculated from a existing centerline in two steps possibly 1 -3 tubes intersecting then select the tube we want to cope to the node.
                        Sdmitch are you in the US?
                        • sdmitchS Offline
                          sdmitch
                          Yes I am.
                          Please post a sample model,version <= 2014, to play with.
                          Please describe just how you would envision how the plugin should work and make it "Coping for Dummy's"
                          • I Offline
                            Iceracer
                            Ill have to get it Tommoro I can snap a picture of the actual piece and send you a file tommoro if you need it. And I appreciate the coping for dummies. This is way out of my expertise.
                            • I Offline
                              Iceracer
                              Here is my dilema coping a single angle is not a issue but adding multiple tubes and then rotating and angling back makes it difficult and then coming in on the other end of the tube make it more interesting.
                              Mitch apparently I cant add a skp file here for you. send me a pm with a email and Ill send the joint to you so you can see it more clearly with all the angles happening.
