    Problem installing rubysoft '3d Doors Windows Frames' plugin
    2 Posts 2 Posters 587 Views 2 Watching
    • P
      pritam8888
      Hi ,
      I get the error as shown in the attachment when I open sketchup. Even the plugins that I have recently loaded do not work. I think this could be because of some faulty plugin that I have installed. I have uploaded also a list of plugins that are there in my computer. Please help
      list of errors
      list of plugins
        To see if that script is the generator of the issue [and not a 'clash'], please disable the file "../Plugins/RS_Window.rb"
        Use the SketchUcation PluginsManager, or simply change it manually to "RS_Window.rb!", so that when SketchUp restarts it doesn't load the file.
        I then suggest you get in touch with the author directly...
        http://www.rubysofthelpdesk.eu/upload/index.php
        The RBZ version in the PluginStore is 3.0.0 and your list says you have 4.1 !
        I suspect he's not publishing here any more - since 18 months...
        Also, please note the PluginStore's older version doesn't actually include a file named "../Plugins/RS_Window/RubyWindow_DatCol_Class.rbs" or "../RubyWindow_Load.rbs" - which seems to be the issue makers...
        So it's hard to comment further...
        These seemingly key files are also scrambled as RBS so it's also hard to see what they are doing...
        The author must help you...
