<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem installing rubysoft '3d Doors Windows Frames' plugin]]></title><description><![CDATA[<p dir="auto">Hi ,<br />
I get the error as shown in the attachment when I open sketchup. Even the plugins that I have recently loaded do not work. I think this could be because of some faulty plugin that I have installed. I have uploaded also a list of plugins that are there in my computer. Please help</p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/HTo0_errors.JPG" alt="list of errors" title="list of errors" class="img-markdown  img-fluid" /></p>
<hr />
<p dir="auto"><img src="/uploads/imported_attachments/CMCt_listofplugins.JPG" alt="list of plugins" title="list of plugins" class="img-markdown  img-fluid" /></p>
]]></description><link>https://community.sketchucation.com/topic/151460/problem-installing-rubysoft-3d-doors-windows-frames-plugin</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 08:16:12 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/151460.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Nov 2015 13:28:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem installing rubysoft '3d Doors Windows Frames' plugin on Thu, 26 Nov 2015 14:45:13 GMT]]></title><description><![CDATA[<p dir="auto">To see if that script is the generator of the issue [and not a 'clash'], please disable the file "../Plugins/RS_Window.rb"<br />
Use the SketchUcation PluginsManager, or simply change it manually to "RS_Window.rb!", so that when SketchUp restarts it doesn't load the file.</p>
<p dir="auto">I then suggest you get in touch with the author directly...<br />
<a href="http://www.rubysofthelpdesk.eu/upload/index.php" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.rubysofthelpdesk.eu/upload/index.php</a><br />
The RBZ version in the PluginStore is 3.0.0 and your list says you have 4.1 !<br />
I suspect he's not publishing here any more - since 18 months...<br />
Also, please note the PluginStore's older version doesn't actually include a file named "../Plugins/RS_Window/RubyWindow_DatCol_Class.rbs" or "../RubyWindow_Load.rbs" - which seems to be the issue makers...<br />
So it's hard to comment further...<br />
These seemingly key files are also scrambled as RBS so it's also hard to see what they are doing...<br />
The author must help you...</p>
]]></description><link>https://community.sketchucation.com/post/1496278</link><guid isPermaLink="true">https://community.sketchucation.com/post/1496278</guid><dc:creator><![CDATA[TIG]]></dc:creator><pubDate>Thu, 26 Nov 2015 14:45:13 GMT</pubDate></item></channel></rss>
