SketchUp 2017 Wishlist
SCENES
- Manage scenes as Utiler would manage layers.
UV MAPPING
- Better UV mapping features
- Specially UV unwrapping
A publicly listed roadmap of development would be nice.
Just an idea. Not a biggie. What if you could find (and / or) open any layout file which references a SU file --from within the SU file.
Useful! -
Also I would like to see trays for Mac just as in Windows. It MUST be possible to clean up the UI! Same for LayOut. Every session requires clearing up all the windows.
@numerobis said:
- import improvements
- better texturing tools
- multicore support (yes, this is the way processors evolve now - since a few years)
- high poly support
- faster ruby script execution! (it's just a joke, that you have to watch a counter when you round some edges, where another app can do this instantly...)
- faster explode or copy/paste
- disable/configure snapping
- an advanced camera without these unbelievable stupid huge frustums and guide lines (clipping problem?) or simply a camera with numerical input for the target hight (or simply the same value as the eye level if a flexible value is too much )
- a usable, more direct or intuitive version of dynamic components with usable stretch and move options like in dynamic blocks in acad for instance
- a camera that can use/display shift parameters of the camera in render plugins
These should be feasible right?
@numerobis said:
- Quads
- sub-D modeling
- better proxy display modes for referenced objects of external renderers - not only a box
- non destructive and parametrical modeling using a modifier stack or node graphs. Maybe we'll see a ruby... this seaems to be to only way this program will evolve in the future (as always).
Modulus operator in Dynamic Components. Please. It would make some of my formulae infinitely less complicated.
I wish there was a tool that will facilitate the creation of floors from sketches of lines, like revit
What's a modular operator?
One of these: https://en.wikipedia.org/wiki/Modulo_operation
(I still have no idea)Doesn't Simfonia Animation Tools have a modulator function so you can create wave signals (possibly completely unrelated).
Wishlist for SU 2017:
- FEA (just kidding, but not really)
- To incorporate this into the software: http://sketchucation.com/plugin/803-coastalconcepts_editflag
- Some way to not have segments in arcs
- STL export
- +1 for publicly listed roadmap of development
- Regarding the nesting of layers - isn't this effectively BillyBob's [url=http://sketchucation.com/forums/viewtopic.php?t=53906:36c9x8qg]Layers Panel Plugin?[/url:36c9x8qg]
@ashscott said:
@utiler said:
[*]Regarding the nesting of layers - isn't this effectively BillyBob's Layers Panel Plugin?[/list]
The problem is that jiminy had to come up with so many workaround methods to create Layers Panel, that even he got confused and eventually stop supporting it, in order to have time to create skatter.
I believe he'd gladly welcome a native solution to this...
I'd say JBB-Layers Panel is as usefull to me as it is to you!
I'm impressed that he even got it to work as someone who was teaching himself Ruby as he went.
I cannot say how useful it has been using Layers Panel in conjunction with scenes to create complex construction documents in Layout.
I arrange every view I need as a scene in sketchup with the appropriate layers on/off (some models have 30+ layers so doing this without Layers Panel is extremely error-prone), send to layout, place the scenes, dimension and add notes, export, build.
Its standard functionality in photoshop etc yet does NOT add any unnecessary complexity to a new user
EDIT: Grammar
Iยดve just copy pasted my little wish from the SketchUp 2016 Wishlist
I want an improved 2D pixels export - regardless of the width/height-size of my currently used SkUp viewport. (As if I would adjust the output resolution within any render plugin)
I want that other SkUp users with their own viewport sice can export exactly the same file resolution as I do. Interacting by repeating the same output results with other users would be so much easier ...Even if there is a plugin for that, SkUp should at last be able to do this "out of the box"
I'd very much indeed.
I'll soon make it completely open-source, so that anyone can update it, even try to make money out of it, whatever.
Guys, Trimble Won't improve anything you wished here, since we are only 0.0001% of the market...haha.
But Plugin authors are the best here! Thank you all for the great plugins! -
Speaking of which, I'd pay someone to clean up Layers Panel and make it as robust as possible - I just can't pay enough to make it worthwhile - on the other hand, if there were a number of us willing to pay...
You could start a kickstarter or similar
