Reset texture aspect ratio?
Is there a function in SU to reset the width and height of a textured material to match the aspect ratio of the bitmap?
I could not find any function that did this. Eventually did it via Ruby...
Same question.
I didn't see anything as I dug around. I noticed there is a texture size rest button, but it only works while you are editing the material. Once you stop editing, it forgets what the original values were. I'm not sure if that is a bug or a feature.
Ok - that's a new feature for my UV plugin then...
Was this ever implemented? It's something I face quite a bit.
Have you ever clicked on a single face with a texture applied with the right button?
Texture position?
Right click on texture position while working with it and hit Reset position. It will reset scale and rotation.
