    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 573.0k Views 71 Watching
      Garry K
      Thanks to Keith on finding bugs and making feature recommendations.
      Keith I will extend your trial by a month for your participation in the beta program.
      Version 1.0.13 is now available. License purchase options are now on my web site.
      1. We now have CabMakerPro and CabMakerGold. You will automatically get a 7 day trial for Gold even if you have purchased a Pro license. At the end of the trial you will automatically down grade to the Pro version. If you are licensed then it will show as licensed.
      2. No longer overwriting config.txt file.
        Garry K
        Version 1.0.14 is now available
        1. Mostly internal changes.
          Garry K
          Version 1.0.15 next week.
          1. I've changed the Edit Configuration to have true false drop downs
          2. Adding drop downs for material color / textures
          3. Now if you want to pare down the colors and or textures - you can edit the colors.txt file and store it in the config folder. You can also organize it any way you want.
          4. I'm also now working on a manual for cabmaker.
            Garry K
            There are 140 internet colors so I would edit the colors.txt file.
            It also contains the wood textures.
            The internet colors change the labels background color. So far choosing a texture does not.
            • FrederikF Offline
              Frederik
              Excellent, Garry...! šŸ‘
              This sure is one of the more advanced plugins for SU...!
              A great and a "must have" extension for anyone working with cabinets for kitchens and wardrobes...
              Cheers
              Kim Frederik
              • FrederikF Offline
                Frederik
                This makes a lot more sense... šŸ‘
                BTW... Do you plan to make sliding doors...?
                It would be ideal for wardrobes...
                And how can I make drawers without handles, but where there's a small slant to open the drawers, like in the attached images...?
                Cheers
                Kim Frederik
                  Garry K
                  Sliding doors are on my radar. Also for Door Maker a sliding door would be good for pocket doors and good for closet doors instead of just bifolds.
                    Garry K
                    I've added a new rule which allows you to choose either the front or back left hand corner as an insertion point. Uppers insertion point is the top of the cabinet and Base cabinets is at the bottom.
                    • FrederikF Offline
                      Frederik
                      Garry,
                      You haven't answered my second quenstion...
                      @frederik said:
                      ...how can I make drawers without handles, but where there's a small slant to open the drawers, like in the attached images...?
                      Cheers
                      Kim Frederik
                        Garry K
                        I can put it on the wish list. If other people are interested in a feature like this then it is possible - but it is not currently on my todo list.
                        • FrederikF Offline
                          Frederik
                          Thanks...
                          Cheers
                          Kim Frederik
                            Garry K
                            I've found a bad bug - don't press escape or use the x to exit the form - it can cause sketchup to freeze. I will fix this shortly.
                            Here is the context help that I am considering. Anyone have an opinion?
                            Shelf Width Adjustment currently has the focus.
                              Garry K
                              Version 1.0.15 is ready.
                              The help is not complete and so far I've only put 15 of the context graphics together.
                              I just wanted to get it out there because of that bug.
                              • FrederikF Offline
                                Frederik
                                It looks great...
                                Does it mean that when you select something, the image in the right corner will change and the arrow will point at the object selected - or is it a more "interactive" preview, where you see the arrow changing position...?
                                Cheers
                                Kim Frederik
                                  Garry K
                                  1 - png file for each parameter. It is already starting to slow down more than I had hoped for.
                                  This in itself will be over 100 graphic files and will take the better part of a week to do. I'm not going any farther at this point.
                                  No English text on the graphic images. Better this way for different languages. Also I will paste these all into the manual. A bit more technical information will be available in the manual.
                                    Garry K
                                    I am now over 100 graphic images for context help. I will try to wrap this up tomorrow and push out another version. I also found and fixed a bug with the applied finished panels.
                                      Garry K
                                      Version 1.0.16 is now available
                                      1. Fixed issues with finished panels
                                      2. Added 150 + graphics for context sensitive help. Still need more.
                                        Garry K
                                        I've now been asked by a number of people for various types of "handleless cabinet doors" as well as for extruded handles. So it appears this will be on my radar.
                                        I believe the best way to work with these is to add them into a folder called "handle profiles" and then to provide an optional handle texture.
                                        Handless - no handle texture. The handle will become part of the door and take on the door texture.
                                        Extruded - has handle texture. The handle is added as a separate part such as an aluminum extrusion.
                                          Garry K
                                          Well I'm 70 pages into writing the documentation for cabmaker.
                                          I'll be real happy to get back into programming.
                                          1. My next task will be to add inset doors. All you do is set the protrusion in the rules to a negative value which equals the thickness of your doors.
                                          2. Then I'm going to add in face frame construction. I would like a bit of feedback. What I am thinking is to add a frame material to the material tab so we can independently specify thickness. I'm thinking we almost need a "Frame" tab where we can specify the various options. Stile Width, Rail Width, Bottom Rail Width, Stiles between door pairs, Rails between drawers. Double drawers above double doors and Stile overhang.
                                          Anyone have any thoughts on this?
                                            Garry K
                                            Version 1.0.17 is now ready for download.
                                            Documentation is finished - 83 pages
                                            Fixed a couple of bugs
                                            With your input, this post could be even better šŸ’—
                                            • 31
                                            • 32
                                            • 4 / 32
