    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 647.1k Views 71 Watching
    • G
      Garry K
      Thank you Keith,
      1. Fixed a small fonts issue. Small fonts were being ignored.
      2. Added corner sink cabinet. No sink stretcher but you can omit the sink top. Drawer fronts do not have drawer boxes.
      3. Added a rule so you can choose to omit kicks.
      4. Fixed a bug in calculating an outside corner cabinet return hanger. Problem showed up when hanger thickness is different than case thickness.
      A new version will be posted later today.
      • G
        Garry K
        Version 1.0.12 is ready for download
        • K
          ktkoh
          Gary version 12 worked very well. The small font made the form fit my portable screen and the no toe kick option worked as expected. Thanks.
          Now one other thing I have noticed but not commented on is the license. When I use the windows/preferences/extensions to up date to a new version I do not have a license available. I have tried loging out at cab32 where I got the down load but I the program still will not ask for or find a license. To run a new version I have been removing the gkware32 files from the plugin directory and then reinstalling the up dated version and then at the first use a login form is shown and after I login the program finds the license and shows the days remaining for the trial.
          Keith
          • G
            Garry K
            Keith,
            I've looked into the license thing and see what is happening. The installer is overwriting your config.txt file. Next version I will change this to preserve your config.txt file.
            For now you should be able to run check license from the menu.
            Then enter in your userid and password.
            • G
              Garry K
              Thanks to Keith on finding bugs and making feature recommendations.
              Keith I will extend your trial by a month for your participation in the beta program.
              Version 1.0.13 is now available. License purchase options are now on my web site.
              1. We now have CabMakerPro and CabMakerGold. You will automatically get a 7 day trial for Gold even if you have purchased a Pro license. At the end of the trial you will automatically down grade to the Pro version. If you are licensed then it will show as licensed.
              2. No longer overwriting config.txt file.
              • G
                Garry K
                Version 1.0.14 is now available
                1. Mostly internal changes.
                • G
                  Garry K
                  Version 1.0.15 next week.
                  1. I've changed the Edit Configuration to have true false drop downs
                  2. Adding drop downs for material color / textures
                  3. Now if you want to pare down the colors and or textures - you can edit the colors.txt file and store it in the config folder. You can also organize it any way you want.
                  4. I'm also now working on a manual for cabmaker.
                  • G
                    Garry K
                    There are 140 internet colors so I would edit the colors.txt file.
                    It also contains the wood textures.
                    The internet colors change the labels background color. So far choosing a texture does not.
                    • FrederikF
                      Frederik
                      Excellent, Garry...! šŸ‘
                      This sure is one of the more advanced plugins for SU...!
                      A great and a "must have" extension for anyone working with cabinets for kitchens and wardrobes...
                      Cheers
                      Kim Frederik
                      • FrederikF
                        Frederik
                        This makes a lot more sense... šŸ‘
                        BTW... Do you plan to make sliding doors...?
                        It would be ideal for wardrobes...
                        And how can I make drawers without handles, but where there's a small slant to open the drawers, like in the attached images...?
                        Cheers
                        Kim Frederik
                        • G
                          Garry K
                          Sliding doors are on my radar. Also for Door Maker a sliding door would be good for pocket doors and good for closet doors instead of just bifolds.
                          • G
                            Garry K
                            I've added a new rule which allows you to choose either the front or back left hand corner as an insertion point. Uppers insertion point is the top of the cabinet and Base cabinets is at the bottom.
                            • FrederikF
                              Frederik
                              Garry,
                              You haven't answered my second quenstion...
                              @frederik said:
                              ...how can I make drawers without handles, but where there's a small slant to open the drawers, like in the attached images...?
                              Cheers
                              Kim Frederik
                              • G
                                Garry K
                                I can put it on the wish list. If other people are interested in a feature like this then it is possible - but it is not currently on my todo list.
                                • FrederikF
                                  Frederik
                                  Thanks...
                                  Cheers
                                  Kim Frederik
                                  • G
                                    Garry K
                                    I've found a bad bug - don't press escape or use the x to exit the form - it can cause sketchup to freeze. I will fix this shortly.
                                    Here is the context help that I am considering. Anyone have an opinion?
                                    Shelf Width Adjustment currently has the focus.
                                    • G
                                      Garry K
                                      Version 1.0.15 is ready.
                                      The help is not complete and so far I've only put 15 of the context graphics together.
                                      I just wanted to get it out there because of that bug.
                                      • FrederikF
                                        Frederik
                                        It looks great...
                                        Does it mean that when you select something, the image in the right corner will change and the arrow will point at the object selected - or is it a more "interactive" preview, where you see the arrow changing position...?
                                        Cheers
                                        Kim Frederik
                                        • G
                                          Garry K
                                          1 - png file for each parameter. It is already starting to slow down more than I had hoped for.
                                          This in itself will be over 100 graphic files and will take the better part of a week to do. I'm not going any farther at this point.
                                          No English text on the graphic images. Better this way for different languages. Also I will paste these all into the manual. A bit more technical information will be available in the manual.
                                          • G
                                            Garry K
                                            I am now over 100 graphic images for context help. I will try to wrap this up tomorrow and push out another version. I also found and fixed a bug with the applied finished panels.
                                            With your input, this post could be even better šŸ’—
                                            • 31
                                            • 32
                                            • 4 / 32
