    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 573.0k Views 71 Watching
      Garry K
      Sliding doors are on my radar. Also for Door Maker a sliding door would be good for pocket doors and good for closet doors instead of just bifolds.
        Garry K
        I've added a new rule which allows you to choose either the front or back left hand corner as an insertion point. Uppers insertion point is the top of the cabinet and Base cabinets is at the bottom.
        • FrederikF Offline
          Frederik
          Garry,
          You haven't answered my second quenstion...
          @frederik said:
          ...how can I make drawers without handles, but where there's a small slant to open the drawers, like in the attached images...?
          Cheers
          Kim Frederik
            Garry K
            I can put it on the wish list. If other people are interested in a feature like this then it is possible - but it is not currently on my todo list.
            • FrederikF Offline
              Frederik
              Thanks...
              Cheers
              Kim Frederik
                Garry K
                I've found a bad bug - don't press escape or use the x to exit the form - it can cause sketchup to freeze. I will fix this shortly.
                Here is the context help that I am considering. Anyone have an opinion?
                Shelf Width Adjustment currently has the focus.
                  Garry K
                  Version 1.0.15 is ready.
                  The help is not complete and so far I've only put 15 of the context graphics together.
                  I just wanted to get it out there because of that bug.
                  • FrederikF Offline
                    Frederik
                    It looks great...
                    Does it mean that when you select something, the image in the right corner will change and the arrow will point at the object selected - or is it a more "interactive" preview, where you see the arrow changing position...?
                    Cheers
                    Kim Frederik
                      Garry K
                      1 - png file for each parameter. It is already starting to slow down more than I had hoped for.
                      This in itself will be over 100 graphic files and will take the better part of a week to do. I'm not going any farther at this point.
                      No English text on the graphic images. Better this way for different languages. Also I will paste these all into the manual. A bit more technical information will be available in the manual.
                        Garry K
                        I am now over 100 graphic images for context help. I will try to wrap this up tomorrow and push out another version. I also found and fixed a bug with the applied finished panels.
                          Garry K
                          Version 1.0.16 is now available
                          1. Fixed issues with finished panels
                          2. Added 150 + graphics for context sensitive help. Still need more.
                            Garry K
                            I've now been asked by a number of people for various types of "handleless cabinet doors" as well as for extruded handles. So it appears this will be on my radar.
                            I believe the best way to work with these is to add them into a folder called "handle profiles" and then to provide an optional handle texture.
                            Handless - no handle texture. The handle will become part of the door and take on the door texture.
                            Extruded - has handle texture. The handle is added as a separate part such as an aluminum extrusion.
                              Garry K
                              Well I'm 70 pages into writing the documentation for cabmaker.
                              I'll be real happy to get back into programming.
                              1. My next task will be to add inset doors. All you do is set the protrusion in the rules to a negative value which equals the thickness of your doors.
                              2. Then I'm going to add in face frame construction. I would like a bit of feedback. What I am thinking is to add a frame material to the material tab so we can independently specify thickness. I'm thinking we almost need a "Frame" tab where we can specify the various options. Stile Width, Rail Width, Bottom Rail Width, Stiles between door pairs, Rails between drawers. Double drawers above double doors and Stile overhang.
                              Anyone have any thoughts on this?
                                Garry K
                                Version 1.0.17 is now ready for download.
                                Documentation is finished - 83 pages
                                Fixed a couple of bugs
                                • FrederikF Offline
                                  Frederik
                                  Thanks, Garry...! šŸ‘
                                  I wonder why there's almost no-one posting replies in this thread...?!
                                  Your cabinet maker is a great plugin with lots of options...
                                  Perhaps it's because other users are having their own standards...??
                                  Cheers
                                  Kim Frederik
                                    Garry K
                                    Kim
                                    I am getting private replies which I keep private. Perhaps some cabinet makers etc. want to keep their techniques private !!
                                    That's ok with me and I respect it.
                                      ktkoh
                                      Gary here is video of the kitchen I designed for my grandson. On the last wall shown the end cabinet was made by using the Angle cabinet then replacing the blank front with a door and drawer from a base cabinet the width of the blank face.
                                      I have noticed that selecting save for rules and materials seems to make nothing happen. When starting a cabinet the save as results in window to name or select the file but not at the materials or rules tab.
                                      I like the help pictures shown now when working in the forms. Very Helpful.
                                      Keith
                                        Garry K
                                        Looks good.
                                        You can set Materials to "Save" and then go to Rules and set "Save" and then go to Cabinets tab - make some changes and create cabinet.
                                        I'm pretty sure you will find that the rules and materials were saved.
                                          Garry K
                                          I've added handless doors and an optional Overlay Counter.
                                          • utilerU Offline
                                            utiler
                                            Garry, probably a silly question at this stage but what is the difference CabMakerPro and CabMaker32?
                                            Just Curious...
                                            With your input, this post could be even better šŸ’—
                                            • 31
                                            • 32
                                            • 4 / 32
