    Selecting all components within a component
    13 Posts 5 Posters 593 Views 5 Watching
      LARV
      If I have a component made up of several other components, is there a way to select everything within that main component? Let´s say I would like to change the colour of everything inside this component of components without having to manually go into each individual one and make the change.
        Use the Outliner ?
        It's possible to make multiple selections within the same context [+Ctrl]
        • sdmitchS Offline
          sdmitch
          unless file_loaded?((__FILE__))
          	UI.add_context_menu_handler do |menu|
          		sel = Sketchup.active_model.selection
          		if sel.first.is_a?(Sketchup;;ComponentInstance)
          			menu.add_separator
          			menu.add_item('Colour Nested Components') {
          				sel.first.definition.entities.grep(Sketchup;;ComponentInstance).each{|ci|
          					ci.material=Sketchup.active_model.materials.current
          	file_loaded((__FILE__))
          http://sdmitch.blogspot.com/
            LARV
            @tig said:
            Use the Outliner ?
            Where do I find the outliner tool?
              LARV
              > 			menu.add_separator
              > 		end
              > 	end
              > end
              Yes, that looks about right, but I don´t understand what you´re getting at? The "Colour Nested Components" doesnt show in my right-click-list. Is it a plugin? I can´t seem to find it in the plugin store
                @larv said:
                @tig said:
                Use the Outliner ?
                Have you looked at the Window menu?
                • sdmitchS Offline
                  sdmitch
                  > > 			menu.add_separator
                  > > 		end
                  > > 	end
                  > > end
                  Yes it is a "plugin" and needs to be loaded or copied to the Plugins/Extensions folder
                  Colour Nested Comps.rb
                    LARV
                    > > > 			menu.add_separator
                    > > > 		end
                    > > > 	end
                    > > > end
                    Thanks I will try it 👍
                    EDIT: I put the file in the pluginsfolder, restarted sketchup, but its not there when I right-click on a group or component containing other groups or components.
                      LARV
                      @tig said:
                      Use the Outliner ?
                      OK, thanks I found it. It seems to be an easy way to select different groups within a model, but I didn´t find a way to select everything and change the colour.
                      I think SDMitch plugin tip is just what I need! Going to check that out
                      • sdmitchS Offline
                        sdmitch
                        It doesn't appear in the context menu because, as written, it only recognizes right clicks on components which what you asked for. Also, it will find only components in the component selected. Do you want it to treat groups and components equally?
                          LARV
                          Yes, that would be great. When dowloading models there´s often a mixture of groups and components.
                          Personaly I cant really tell the difference between the two and usually just click on "make component".
                          • N Offline
                            numerobis
                            Global Material Changer
                            http://sketchucation.com/forums/viewtopic.php?p=96863#p96863
                              LARV
                              Oh man... I HAVE that plugin, been using it alot, but I never noticed the "ANY" (=all) selection. So thanks alot! perfect
