    Google maps texture gets weird render
    renderpluginsextensions
    6 Posts 4 Posters 1.1k Views 4 Watching
      LARV
      Hello,
      I´ve used the Sketchup geograbbing tool to puzzle together a terrain of Mount Everest.
      When I render it in Vray the google map textures come out weird in places. I think this happens where the different grabbed maps overlap. If so, is there anything I can tweak to fix this?
      (When I click render it seems like an almost complete render is shown for 1-2 seconds before the scene starts to actually render, and it looks fine there, but not after the finished rendering)
      Thank you.
      AFTER RENDER
      BEFORE RENDER
      • V Offline
        valerostudio
        Z-Fighting. 2 faces sharing the same exact space. You seem to have overlapping terrains.
          LARV
          Yes, that was my guess too. Is there any way to fix it? It´s probably impossible to geograb to the exact pixel.
          • andybotA Offline
            andybot
            there's a plugin that trims overlapping GE terrain.
            http://sketchucation.com/forums/viewtopic.php?t=40627
              LARV
              Oh! I´ll try that. Thanks!
              • TedVitale_CGT Offline
                TedVitale_CG
                A way to quickly cheat if the terrain clipper tool doesn't work, is to lift one surface off of the other by a half inch or so. At that distance and scale you shouldn't be able to see the edge either.
                Ted Vitale
                Owner | Creative Director
                http://www.voxl.vision
