    [Plugin] Contour Maker v1.6
    64 Posts 24 Posters 76.3k Views 24 Watching
      Goatboy, the version you have must be old because the last version of it was updated at the end of April of 2013 and it works fine in SU2014. Or you didn't install it correctly or in the right place. As Box said, don't migrate plugins. Install fresh copies. Get the SCF Plugin Store and install it automatically.
      • goatboyG Offline
        goatboy
        Yes, that did it. Also in the 2014 thread, Jim corrects some really incorrect instructions from Trimble on how to migrate plug-ins:
        @jim said:
        On Vista, Win 7, 8:
        C;\Users\<username>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
        On Win XP:
        C;\Documents and Settings\<username>\Application Data\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
        On Windows, we also load plugins from a user-independent support directory.
        On Win Vista, 7, 8:
        C;\ProgramData\SketchUp\SketchUp 2014\SketchUp\Plugins
        On Win XP:
        C;\Documents and Settings\All Users\Application Data\SketchUp\SketchUp 2014\SketchUp\Plugins
        This path is only loaded to the $LOAD_PATH array if the folder exists when on the user's machine when SU starts.
        but your way: the SCF Plugin Store is way better. Thanks!
          Where are the incorrect instructions?
          • goatboyG Offline
            goatboy
            Like in the 2014 help directions...
              So it does.. I sent a request for a correction.
                Get and install the latest version of ContourMaker from the PluginStore RBZ [Preferences > Extensions > Install...].
                http://sketchucation.com/pluginstore?pln=ContourMaker
                It is compatible with v2014.
                OR do it automtically from within SketchUp itself using the SketchUcation 'Plugin Store' AutoInstall capabilities...
                Either way the correct Plugins folder is found for you...
                • goatboyG Offline
                  goatboy
                  TIG: I hope you have already been gold-plated. When I read the methods others use to make contours, I am SO GLAD I found contour maker.
                  • KrisidiousK Offline
                    Krisidious
                    Will this be coming to 2015 with us TIG?
                    By: Kristoff Rand
                      Is there something that makes you think it doesn't work in SU2015? It certainly does work.
                        Krisidious
                        Didn't try... Saw the 2014 compatible and thought it would have said 2015 if it were, wondered if maybe since there are other plugins that do similar jobs if maybe it was not getting updated... Thanks for letting me know.
                        By: Kristoff Rand
                        • jujuJ Offline
                          juju
                          generally, if a script is SU 2014 compatible it will be SU 2015 compatible, AFAIK
                            It is compatible with all SketchUp versions from v8 upwards.
                            As far as I know all of my Plugins are...
                            If I get a report of an incompatibility, then I fix it; but usually I have anticipated the updates needed...
                            As was said, if a Plugin is v2014 compatible it will almost certainly be v2015 friendly too.
                            In the post where I said it was v2014 compatible, it was prior to the release of v2015...
                              @krisidious said:
                              Didn't try...
                              Why wouldn't you try it? you could have answered your own question.
                                Krisidious
                                Because I have like 4 plugins that do this... I was just wondering because it seemed rather clean and direct.
                                And thanks TIG, I've been shying away from things that don't say 2015 compatible. And very nice of you to update EVERYTHING... I can't say we could ever expect that of you, you have so many and you update other people's plugs too.
                                By: Kristoff Rand
                                • robintR Offline
                                  robint
                                  Tig thanx 10^6
                                  brilliant little tool, am using on GE to get a contour map, much less fiddly than making 100 intersecting planes method
                                  The contour lines are a little jagged so corners need to be softened. Whats the best way to do this? Tigweld, use Bezier?
                                  Come to think of it I haven't come across a tool that softens a 2d jagged line easily (like you can in adobe illustrator for example, any suggestions
                                  ps Ive been player with simplfy contour and convert to polyline/fspline etc, you can only do one line at a time, its all a bit hit and miss - and with 50 odd contours this will be massively time consuming
                                  with ca 1000+ extensions out there looking for attention, its all bewildering
                                  Any suggestions
                                  Cheers
                                  Robin
                                  As one door closes another one slams in your face
                                  • Y Offline
                                    Yashar11
                                    Hi TIG, when i install using extention manager it tells me that the version is unsigned?
                                    I am new to sketch up and using it to create contours on my farm plans, but I am not very computer savvy....please help
                                    thanks
                                    Scott
                                      Many older extensions and plugins report as 'unsigned' in the Extension-Manager dialogs in newer versions of SketchUp.
                                      This is not actually a problem if you set its Loading-policy to Unrestricted, then unsigned ones will still load and work.
                                      You should only get RBZ files from trusted sources, like SketchUcation's PluginStore, the Extension-Warehouse etc. If you do that, then the overly draconian loading-policies can be sidestepped.
                                      When SketchUp had the [not so bright] idea of 'signing' RBZ files, they failed to appreciate the extensive work needed by authors to process the hundreds of files that already existed [let alone any new ones!]. Many older RBZ files have simply not been processed yet, and probably never will - it doesn't mean there's anything wrong with them...
                                      Using signed RBZ files offers little real comfort to users anyway, since any authors can get their files signed, and there are no significant checks on the contents at all. The EWH ones are checked for good coding methods etc, but many authors, such and myself and Fredo, eschew publishing on the EWH, and prefer to use the nicer/kinder SketchUcation PluginStore, which actually predates the EWH anyway !
                                        JavadQaitouri
                                        Hey,I installed the file as an extension but it is unsigned, I can't use it, any tips?
                                          Its status as Unsigned doesn't mean you can't use it. If you have the loading policy set so it loads, it will work just fine.
                                          Which version of SketchUp are you actually using? Your profile shows 2020 Free/Make but there is no such version.
                                            JavadQaitouri
                                            I use 2020 can,t open it when it is unsigned.
                                            • 3 / 4
