    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 68.6k Views 40 Watching
    • W Offline
      Whaat
      @bob james said:
      If you search for Profile Builder 2 or profilebuilder2 on Extension Warehouse you get "Not Found"
      Thanks Bob, I am aware of this and so is EW. I have been told that a fix is in the queue.
      • Bob JamesB Offline
        Bob James
        I'm experimenting with making a Railroad wheel. What am I doing wrong?
        • kenK Offline
          ken
          Will, Bob, draw a centerline, everything on the sides of the centerline is going to spin around and create a circular part. So get rid of the both short ends, just need the smaller section.
          Ken
            Bob James
            Will, Bob, draw a centerline, everything on the sides of the centerline is going to spin around and create a circular part. So get rid of the both short ends, just need the smaller section.Ken
            Ken: Thank you for your response. Unfortunately, I don't understand.
            1. I draw a horizontal centerline first and then click on revolve? (that didn't seem to make any difference)
            2. What do you mean by the "short ends"?
            3. What do you mean by the "smaller section"?
            The complete wheel on the left of the previous post was created in the "normal" way: create a circle and follow that path with the profile (with no offset).
            What is "Offset" supposed to do? I assumed it would offset the profile axis of revolution.
            It makes no difference whether the "Revolve Profile" axis is drawn vertically or horizontally, it still revolves the profile around the axis shown in blue.
            • deaneauD Offline
              deaneau
              @Bob James
              try to use the rotation 90°
              wheel_new.skp
              Wheel.skp
              • kenK Offline
                ken
                Oops, my bad. I gave these instruction using Quick Lath Around Selected Axis. So I guess I have confused the issue.
                Note, I work with ACAD drawing of pipelines, flanges and other round parts. I use the plugin "Quick Lath around Selected Axis". I just copy over the lines, get the center line and presto, I have a flange, pipe whatever.
                I didn't mean to confuse the issue, sorry.
                Ken
                • deaneauD Offline
                  deaneau
                  here some samples
                  • facerF Offline
                    facer
                    A summary of some useful links:
                    Assemblies
                    http://profilebuilder4sketchup.com/category/assembly/
                    Profiles
                    http://profilebuilder4sketchup.com/category/profile-library/
                    Learn
                    http://profilebuilder4sketchup.com/learn/
                    Forum
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=61283
                      meaker vi
                      This plugin is AWESOME! Must buy for sure. I accidentally stumbled across it and knew I needed to purchase and install. Unlike many of the posts here and in the other PB threads I've noticed, I had no issues purchasing or installing (into skp 2015 pro), and have had no crashing with it. I do have some comments in no particular order:
                      A way to submit assemblies & profiles to someone would be nice. You say they can be found on the 3d warehouse, but I'm not sure how to find them other than using yours from your site.
                      No way to apply materials to a profile from within the assembly editor
                      No way to orient materials applied to profiles other than to create new materials (not ideal)
                      Some of the labels have obscure meanings. (Up/down offset is just elevation by another name?)
                      The profile/assembly search windows do not show folders (makes it tedious to organize profiles & assemblies by a type logical to me, and I'd prefer not to sort through thousands of profiles/assemblies every time I want to find one), and could use some extra navigation features (forward/back arrow).
                      The 'search' icon should probably be an 'open' icon
                      The way the preview is generated is obscure to me. Sometimes it focuses on what I'm editing, sometimes not, sometimes it just doesn't do what I want it to and I don't know why.
                      The "apply assembly attributes" and "edit member properties" buttons have the same iconography, but do slightly different things. Personally, I'm not sure the little popup window for profiles is useful, maybe replace it with a "apply profile attributes" (exactly the same as the assembly button) and add a button that brings the window back up as a kind of eyedropper tool allowing the user to select what profile (or maybe assembly!) attributes to eyedrop.
                      I'd be nice to be able to adjust the profiles used from within the assembly dialogue. Especially for their start points, rotation, etc.
                      A couple (non-breaking) glitches I've noticed:
                      Hitting enter on data entry in any box doesn't do anything. You need to switch to the next box to get the data to apply. - Especially important when building assemblies, as it's tricky to figure out whether I've moved something the correct distance.
                      Pushing the arrows on the profile in the assembly window on a loaded assembly allows you to go infinitely beyond the number of profiles in the assembly. I think it happens when you've selected a profile that exists in one assembly, load a new assembly with fewer profiles, and then try to cycle through them.
                      And some wishlist items:
                      It seems like this is so close to being able to do all things parametric. If it worked in 2 dimensions (instead of just linearly), I can see using it to generate any-height walls, windows, doors, etc. etc. (Right now, I'd need to make a new assembly for each window/door height. Not the end of the world, but more work than I'd like to do).
                      Making it so the tool can cut assemblies (possibly using solid tools) would make windows & doors very easy.
                      Allowing me to draw a thing using profiles and components and translate them to an assembly would be awesome.
                      (Sorry if this is a bump, but this seems to be the main thread)
                      • W Offline
                        Whaat
                        Wow, thanks for the great feedback, meaker! Really useful comments!
                        Assemblies and profiles are just SKP files. You can share them and upload them to 3DWH just like any other SKP file. If you have uploaded an assembly, let me know and I'll post it on my website.
                        Just click on the profile icon in the Assembler Dialog (just next to the Profile name) and you can edit all the properties of the profile, including material
                        True - not ideal
                        Up/down offset refers to the 'local up direction'. This is not the same as elevation if the path is sloped up or down. I had hoped that the hover thumbnails clarified this...
                        Yes - this is something I plan to improve in the next update
                        ..probably
                        The preview is actually a thumbnail that is created by SketchUp of the Assembly Component. It works most of the time but sometimes it does weird things and I am not sure why. Helpful hint: the orientation of the preview camera will match the current SketchUp camera view
                        Interesting...Perhaps some improvements could be made here.
                        See above - this can already be done.
                        Yes - this should be improved, Enter should apply the current setting.
                        Right - there are some issues here that need to be fixed.
                        Great suggestions, thanks! If you think of any more, please let me know.
                        • R Do not disturb
                          rv1974
                          Whaat, could you add random move\scale\rotate parameters (per axis)for profile\assembly members?
                          • W Offline
                            Whaat
                            Yes - that's fairly easy to do, but I would prefer not to add so many settings to the Assembler dialog for a feature that would be used fairly rarely by the average user (I assume). Besides, there are other plugins that can do this - it is an extra step by still much faster than doing it manually.
                            For example - are you familiar with this one?
                            https://extensions.sketchup.com/en/content/clf-scale-and-rotate-multiple
                            • R Do not disturb
                              rv1974
                              "640K ought to be enough for anybody"
                              The niche of parametric randomizer for SU is EMPTY and undoubtfully it's gonna be a huge blockbuster if you'd implement it.
                              Randomization is core feature in big brother plugins such as multiscatter, forestpro and railclone .
                              • KrisidiousK Offline
                                Krisidious
                                You know Whaat... You could do break off sister plugins. specialized?
                                By: Kristoff Rand
                                  sherwood111
                                  Hello, has anyone received these error messages ?
                                  I drew a straight section of an few arbitrarily
                                  profiles .... crown105, crown106.
                                  (downloaded from the pb2 website)
                                  I experimented with extending and trimming to
                                  a perpendicular profile/face, etc.
                                  any thoughts on cause ?
                                  any ideas to remedy ?
                                  • W Offline
                                    Whaat
                                    [attachment=1:1bx1nwz4]<!-- ia1 -->trim_errror.msg.PNG<!-- ia1 -->[/attachment:1bx1nwz4]
                                    [attachment=0:1bx1nwz4]<!-- ia0 -->extend_errror.msg.PNG<!-- ia0 -->[/attachment:1bx1nwz4]
                                    In order to extend or trim a profile member, the end of the profile member must not have been modified. In other words, the ends need to look the same as they did right after the object was created. Re-building the member will re-create it so you can trim it again.
                                    • TommyKT Offline
                                      TommyK
                                      I do love this plugin. It so nearly feels native to SketchUp. For making geometry, it works great. I have a few suggestions to improve it though in the realms information (the "I" in BIM).
                                      1. Components over groups, please. Currently, PB creates groups from profiles. Groups are more limited in SU than components. For instance, you can't explore "Component Options" of a group. This would be useful for people who use Classifer.
                                      2. When using assemblies, it appears that PB deletes everything within the assembly group and redraws. This results in any layers or classifier information that have been assigned to the individual groups within the assembly to be lost whenever the assembly is rebuilt (when changing path, for example). Is there a way to retain each group (if it still exists), but alter the geometry within them?
                                      3. Profiles and assembly components are skp files, as you say. It would be great if these are imported into SU as components and the profile is made within the component that is imported. What this does is that any information within the component is preserved in the profile member. This includes component description, Classifier information etc etc.
                                      Other little thing:
                                      • when clicking to edit the profile of the profile member within a group (in the profile assembly window), it works the first time, but subsequent clicks to edit other profile members shows no change to the profile builder window. Strangely, right-clicking the window and selecting "reload" seems to work.
                                      Thanks for a great plugin! I would use it even more if it could do the information side of things.
                                      • utilerU Offline
                                        utiler
                                        Hi Dale, Happy New Year!
                                        A few queries re: building assemblies and where to use components or not.
                                        See attached images which I've added questions to each. Cheers, look forward to hearing back ASAP.
                                        Just Curious...
                                        • E Offline
                                          eselick
                                          Hi Whaat
                                          I'm wondering if you are aware of the problems that I and many others who are on Windows 10 are having when we try to download the Trial version of PB 2.
                                          A few seconds after the download dialog loads Sketchup crashes, usually with no error message or only a Windows, "this program has stopped working ..." message.
                                          All of this is quite fully documented at the Sketchup forum:
                                          http://forums.sketchup.com/t/extension-warehouse-download-attempt-crashes-su/18869/27
                                          Hopefully you can check it out and help get it fixed so that we can have a look at PB2.
                                          Elliot
                                          • W Offline
                                            Whaat
                                            @eselick said:
                                            Hi Whaat
                                            Elliot
                                            Yes, thank you for the report. I am aware of the issue and the SketchUp EW team is working to help resolve this. I have made a change to the EW PB2 page. Please try again to see if the issue has been resolved.
                                            Dale
                                            • 11
                                            • 6 / 11
