[Request] - Component's options report
I found a way to convert the inches, but the problem with counting components still remain. Any idea how to include this into the report?
Still hoping...
Since your example is written in 'Cyrillic' [?] it's hard to understand... Ddo you find the details of a component and also want to show a total number of it in the report - like on the Entity Info window ?
You need to find its definition and then its instances and count them, the format the html/csv to include the 'count' - something like...ss=model.selection ents=ss.to_a ### OR ents=model.entities ### OR ents=model.active_entities defns=[] ### to become a list of used definitions ents.each{|e| if e.class==Sketchup;;ComponentInstance defns<< e.definition if not defns.include?(e.definition) end#if } counts=[] ### to become a collection of definitions [by name] and their instance counts [as a string] defns.each[|d| counts<< [d.name, d.instances.length.to_s] }- note it's untested!
You now have an array of selected [or all used] definitions by name, paired with the total of their instances....
So to output it to the Ruby Console use something like...
counts.each{|e| puts e[0]+"\t"+e[1] }I'll leave the formating of the csv / html lines etc to you or others.............
Thanks so much! I made a component in English to show what I mean:
The report is a real mess and in inches, but I managed to clean it up in Excel.
So you are almost sorted
I did need a plugin to creat a simple list of components with: LenX, LenZ, LenY, Material, and Name
Not the boundinbox, because sometime in the draw the component could stay in angle different that axes.
Please need help, Could give a good Cookie to your jar.
Will use this to report list of furniture components to outside software that will calculate price.
Need SAP!
Best Regards
Celio -
I'm thinking of creating a report writer that allows you to pick, choose and specify the order of columns in a csv report. The report definition can then be given a name that you can choose from a pick list when running subsequent reports.
Any one interested?
I'm really interested in this!
I would like to help as well but I'm a complete beginner
If there is enough interest then I would jump into it -- otherwise this is on a back burner.
Any one interested?
Would it also allow us to convert the columns names?
I mean, my contractors aren't much interested in LenZ, but they could very well relate to height.
Could we also Combine values?
LenX | LenY | LenZ columns, could be merged into a single Dimensions Column and each LenX, LenY and LenZ value would then turn into something like 1.5m X 2.0m X 0.005m?
EDIT: Oh and if unit conversion would be there too...
Column names would be handled by my translation layer.
You could convert English translation (which is normally just a template) to what ever you want.
Normally with my plugins I try to honor the units that the user has set up for the model.Yes - Sketchup stores data a certain way. BUT I Am a big fan of metric - so I honor it and convert into mm.
I'm sure you'd pull off something very good...
