    Housebuilder
    160 Posts 57 Posters 230.9k Views 57 Watching
    • gudio83G Offline
      gudio83
      click and hold mice left button when selecting lumber size. thats it.
      It will be great someone to add some new features in this plug-in (like add OSB / divide by panels...). its best plug-in for timber constructions for now. However it have many issues with windows and doors, but i make it manually.
        Kiwi007
        Thanks so much!!! This took me hours to solve - and then found your solution, wish you could upload this to the Ruby library - I am sure it would save a lot of pain for a lot of people.
        • gudio83G Offline
          gudio83
          it's on the server. See page 1 of this post
            I made a separate thread linking to the metric and imperial versions - go here - http://sketchucation.com/forums/viewtopic.php?p=564448#p564448
              Redranger
              @dave r said:
              I guess you haven't read through this thread. The correct installation process has been give multiple times here.
              From your description it sounds like you downloaded the ZIP file but it got unzipped automatically by your OS. You really ought to set it so that doesn't happen. It would make things easier.
              Install Extension requires that the extension be packaged as a zip while whose file-extension is changed to .rbz. The reason Install Extension didn't work for you is you have no .rbz file to point it at.
              Try again.
              As for the Plugins folder, in current versions of SketchUp it does exist but it is in a hidden directory. There's no need for you to access it directly if you have files structured correctly and install them properly. Your profile indicates you're still using SketchUp 6. Is that correct?
              I will say there was some amusement to reading through the entire 3 pages of comments.......but it wasn't till this post that I figured out the issue I was running into. Ended up being the auto unzip in safari preferences.
              anyhow thank you everyone for the good laugh and the end result of me finally getting to use this sweet plugin!
                chate
                Just installed HB V1.2 edited and fix by TIG,and it works fine. Thank you very much. The Imperial version can be download from http://rhin.crai.archi.fr/rld/plugin_details.php?id=188
                  No! The imperial version of Housebuilder at the link you provided has not been updated. The updated version is available in this thread right here.
                    No, No. NO !
                    As Dave says get the updated versions from these links http://sketchucation.com/forums/viewtopic.php?p=570235#p570235
                    Or even more directly http://sketchucation.com/forums/viewtopic.php?p=564448#p564448
                    You can take a horse to water but a pencil must be lead...
                      chate
                      Sorry for the confusion!
                        Drumsetc
                        Guys, I followed the above link after assuring I had the up to date version of Sketchup Make.
                        The install extensions link fro "Preferences" found and installed the plugin fine.
                        I'm on a Mac, OSX 10.9.3
                        Thank you for all the help folks...
                        Shawn
                          cedna
                          Hi All,
                          I downloaded tigs version of housebuilder metric works ok for the most part except when i come to build a roof although i specify a size when built it reverts the lumber size back to the lowest size, and one side of the roof is not lined up properly, anyone else had this problem? is there a fix, great program pity if roofs cant be fixed
                          cheers
                            coop500
                            https://scontent-ams2-1.xx.fbcdn.net/hphotos-xpf1/t31.0-8/11202965_10153794512183119_301364504204328817_o.jpg
                            First of all thanks for posting these files. I'm also having the same issue as "cedna". The thickness of the roof beams reverts to the smallest size in one direction, correct size in the other. The center beam is completely the wrong size. The end caps for the roof are the correct size though.
                            This isn't much of an issue I was also just wondering if there was a fix.
                              coop500
                              Also You could use these rb files:
                              http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=26858
                              But it will convert it back to imperial.
                                Those haven't been updated like the files TIG and I corrected. Please don't lead people down the wrong path. There've already been enough problems for users because they are installing the wrong versions. The last thing we need is more of that.
                                  Since the RB files are scrambled, it'll take the original author to fix it. Unfortunately it doesn't appear that he has the time to devote to editing his extensions. You could try contacting him, though.
                                    coop500
                                    It's a shame that the metric files have been scrambled or we could have tried to find the issue.
                                    I guess everyone is having this problem?
                                    One option would be to use the imperial plugin which doesn't seems to.have these issues but create custom imperial sizes to reflect the metric ones.
                                    Using the other.rb files worked for me otherwise I wouldn't have posted them. Sorry to add to the confusion in this thread.
                                      pesca04
                                      Hi !!
                                      thankyou very much for this file.
                                      I installed the metric version in my SU 2015, the first time it worked well, but now when I try to make a wall the progran shoot down inmediatly...... 😞 😞
                                      I don't know if there is something wrong in SU or is the extension.
                                      ¿any body know??
                                      Thankyou
                                        jar80
                                        When I got to download this HouseBuilder_extension.rbz buy clicking on Dave R link it comes up blank white paper looking thing
                                          You don't open the file itself. In SketchUp, go to Window>Preferences>Extensions. Click on Install Extension... Navigate to where you saved the Housebuilder.rbz file. Select it, click Open and any affirmative answers. In the Extensions window make sure the Housebuilder extension is checked to load. After that, you should find the Housebuilder toolbar in View>Toolbars.
                                            luvmybabegirls
                                            I downloaded the Housebuilder but I do not see where to plugin on Sketchup. Please help??
                                            • 5 / 8
