    [Plugin] Simple Building Generator
    22 Posts 15 Posters 22.3k Views 15 Watching
    • jujuJ
      juju
      Excellent for a second post! Contact the moderators and get it published to the pluginstore, it also affords you a new "badge" below your handle...
      If I recall correctly, something similar was done by one of the other plugin authors, Julia Cristina Eneroth, however I can't seem to find it.
        rizkynggakool
        Thank you very much juju, I really appreciate your comment 😄 😄
        How to contact the moderators?
        And what is the benefit by having badge?
        I don't know that, all I know when I google "SketchUp Building Generator" these two topics showed up :
        http://sketchucation.com/forums/viewtopic.php?f=314%26amp;t=19410
        http://sketchucation.com/forums/viewtopic.php?f=314%26amp;t=19524
        That's why when I first post in this site I add remus name to my post
        http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=62713
        Anyway, have you tested my plugin? Did it work as you or I expected?
        Please share if there's any problem 💚
        • KrisidiousK
          Krisidious
          very nice... now all I need is a city to map.
          By: Kristoff Rand
          • jujuJ
            juju
            I found the extension, strange that it wasn't on her site, from I could tell...
            ERROR: The request could not be satisfied
            (extensions.sketchup.com)
            Probably not quite the same as what you're doing, but not too dissimilar either.
              This is looking very nice!
              CityGen faded away because none of us had time to continue it. 😞 Always felt bad about that one as it felt like a good collaboration project.
                rizkynggakool
                Thank you very much kris 😄
                Yes, it's sad that the major problem is this plugin is useless without any city map 😢
                Do you know any site that provide 2D city map?
                If you do, I will create tips section for that and put it in the first post.
                I'm sure that it'll help a lot people 😄
                That plugin is awesome 😮
                Both are "Building Generator" and aim to reduce worktime.
                Her plugin create a house, mine create a skyscrapper 😄
                And judging by how her plugin work I bet it's far more harder to create than this one 😕
                Thank you very much thom...
                Having a predecessor says something about what I'm working on is a morale boost 😄
                Sad to know that CityGen was never complete, but I'm glad CityGen dev team have a better job 😄
                • ElibjrE
                  Elibjr
                  Wow. This is an excellent plugin. The great thing about this is that the shapes are simple rectangular volumes which lend better for urban landscapes as opposed to pitched roofs. Well done!
                    Ralle
                    Hi, rizkynggakool.
                    Nice script, but i can´t get it work. I´m running on SU2015, and i got a big errormessage with a lot of content. It seems to expect something. In the description
                    you mentioned a dependencie with "offset.rb" - incuded. I can not find it anywhere. 😕
                    May be that this is my problem ??
                    Greetings ...
                      rizkynggakool
                      Thank you very much Elibjr, I really appreciate that 💚
                      I'm sorry for the late reply, I've been busy with my college for a few days 😄
                      Anyway, have you tried the new v1.07 ?
                      I'm pretty sure it'll reduce your worktime even more 💚
                        rizkynggakool
                        @ralle said:
                        Hi, rizkynggakool.
                        Greetings ...
                        Hi Ralle, thank you for contacting me and for the feedback.
                        What kind of error message?
                        Could you provide some screenshot?
                        Yes, it's using offset.rb by Rick Wilson from smustard.
                        but that shouldn't be problem anymore since I already included the offset.rb inside this plugin.
                        • N
                          nektares
                          i guess i got the same message on the ruby console u_u it´s this one:
                          i hope it has an easy fix!
                          Error Loading File simple_building_generator.rb
                          Error: #<SyntaxError: C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ',', expecting ')'
                          ...arch_floorplan (arr_main_input, arr_gf_input, arr_f_input, a...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ')', expecting '='
                          ...put, arr_f_input, arr_re_input)
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ',', expecting ')'
                          ...on_material (ground_floor_face, arr_ground_floor_pts_down[in...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ')', expecting '='
                          ...ex], ground_floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ',', expecting ')'
                          ..._position_material (floor_face, arr_floor_pts_down[index - 1...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ')', expecting '='
                          ...own[index], floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ',', expecting ')'
                          ...n_material (rooftop_edges_face, arr_rooftop_edges_pts_down[i...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ')', expecting '='
                          ...oftop_edges_outer_mtl, mtl_fit)
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ',', expecting ')'
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ')', expecting '='
                          ...[0], ground_floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ',', expecting ')'
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ')', expecting '='
                          ...ts_down[0], floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ',', expecting ')'
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ')', expecting '='
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ',', expecting ')'
                          ...terial (rooftop_edges_top_face, arr_rooftop_edges_pts_top[0]...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: Can't assign to false
                          ..., rooftop_edges_top_mtl, false)
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ')', expecting '='
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ',', expecting ')'
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: Can't assign to false
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ')', expecting '='
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ',', expecting ')'
                          ...rial (rooftop_edges_inner_face, arr_rooftop_edges_offset_pts...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ')', expecting '='
                          ...oftop_edges_inner_mtl, mtl_fit)
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ',', expecting ')'
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ')', expecting '='
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ',', expecting ')'
                          ...osition_material (rooftop_face, arr_floor_pts_top[0], arr_fl...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: Can't assign to false
                          ...pts_top[1], rooftop_mtl, false) # ===== UPDATE [08/08/2015] ...
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ')', expecting '='
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ',', expecting ')'
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: Can't assign to false
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ')', expecting '='
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2246: class definition in method body
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2303: class definition in method body
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2312: syntax error, unexpected keyword_do_block, expecting keyword_end
                          0.upto(verts.length-1) do |a|
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2319: void value expression
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2361: syntax error, unexpected keyword_do_block, expecting keyword_end
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2382: class definition in method body
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2392: class definition in method body
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2401: syntax error, unexpected keyword_do_block, expecting keyword_end
                          C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2454: syntax error, unexpected end-of-input, expecting keyword_end>
                            rizkynggakool
                            Hi nektares,
                            thank you for reporting this problem.
                            May I know what version do you use?
                            • N
                              nektares
                              I´m using 64 bit SketchUp 2015 on windows 7
                                menelao74
                                Errore di caricamento del file simple_building_generator.rb
                                Error: #<SyntaxError: C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: Can't assign to false
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: Can't assign to false
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: Can't assign to false
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ',', expecting ')'
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: Can't assign to false
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ')', expecting '='
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2246: class definition in method body
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2303: class definition in method body
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2312: syntax error, unexpected keyword_do_block, expecting keyword_end
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2319: void value expression
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2361: syntax error, unexpected keyword_do_block, expecting keyword_end
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2382: class definition in method body
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2392: class definition in method body
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2401: syntax error, unexpected keyword_do_block, expecting keyword_end
                                C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2454: syntax error, unexpected end-of-input, expecting keyword_end>
                                hello, someone explain me why plugin's malfunctioning. I do like to buy programa does not operate. help me please ..... thanks.
                                  alnahrini
                                  Hi guys i have the same problem , is there any one found a fix for this problem?
                                  • MidgeUreM
                                    MidgeUre
                                    Hello there.
                                    Well, I having the same error of nektares and menelao47. I'm using Sketchup 2015 and trying the Simple Building Generator v1.07 in Windows 7 64 bit.
                                    • T
                                      typhoon1969
                                      This plugin seems to work with Sketchup 2013, but not with Sketchup 2015.
                                      • C
                                        Citelum
                                        These tools are so useful for urban modelling. Thanks to all you developers who have put a lot of time into coding these plugins.
                                        ThomThom mentioned above that he has felt bad about the CityGen project coming to a standstill. What a pity it's not continuing. I have been hunting for months for SKU plugins and other software that can export to SKU (eg in Collada format) to assist with street / city modelling and in a number of places I have looked I find projects partly finished and discontinued. City Engine is great but it's huge bucks when you come to add the plugins in to export in, say, Collada format.
                                        So, to encourage all you coders - there are many of us, I'm sure, who would love to see a comprehensive urban modelling addition for SketchUp. Don't stop the coding please.
                                        Best regards,
                                        Garth
                                          Angel
                                          Can anyone help me get this extension to work. It installs Ok on SU 2013 but I don't think i understand the workflow properly as I get 'material cant be found in library' messages
                                          An idiots guide or run thro would help me a lot
                                          • sdmitchS
                                            sdmitch
                                            I have been trying this plugin and the biggest problem with it is the materials and material names. You can't use the Sketchup name or display_name. You have to paint a face in the model with any materials you want to use and then rename them and use those names.
                                            As for the plugin code, to make it Ruby2.0 compatible, you will need to remove the space in front of the opening parentheses,"(", on all the method call statements.
                                            http://sdmitch.blogspot.com/
