    [Plugin] Simple Building Generator
    22 Posts 15 Posters 20.9k Views 15 Watching
    • N Offline
      nektares
      i guess i got the same message on the ruby console u_u it´s this one:
      i hope it has an easy fix!
      Error Loading File simple_building_generator.rb
      Error: #<SyntaxError: C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ',', expecting ')'
      ...arch_floorplan (arr_main_input, arr_gf_input, arr_f_input, a...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ')', expecting '='
      ...put, arr_f_input, arr_re_input)
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ',', expecting ')'
      ...on_material (ground_floor_face, arr_ground_floor_pts_down[in...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ')', expecting '='
      ...ex], ground_floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ',', expecting ')'
      ..._position_material (floor_face, arr_floor_pts_down[index - 1...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ')', expecting '='
      ...own[index], floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ',', expecting ')'
      ...n_material (rooftop_edges_face, arr_rooftop_edges_pts_down[i...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ')', expecting '='
      ...oftop_edges_outer_mtl, mtl_fit)
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ',', expecting ')'
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ')', expecting '='
      ...[0], ground_floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ',', expecting ')'
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ')', expecting '='
      ...ts_down[0], floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ',', expecting ')'
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ')', expecting '='
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ',', expecting ')'
      ...terial (rooftop_edges_top_face, arr_rooftop_edges_pts_top[0]...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: Can't assign to false
      ..., rooftop_edges_top_mtl, false)
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ')', expecting '='
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ',', expecting ')'
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: Can't assign to false
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ')', expecting '='
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ',', expecting ')'
      ...rial (rooftop_edges_inner_face, arr_rooftop_edges_offset_pts...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ')', expecting '='
      ...oftop_edges_inner_mtl, mtl_fit)
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ',', expecting ')'
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ')', expecting '='
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ',', expecting ')'
      ...osition_material (rooftop_face, arr_floor_pts_top[0], arr_fl...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: Can't assign to false
      ...pts_top[1], rooftop_mtl, false) # ===== UPDATE [08/08/2015] ...
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ')', expecting '='
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ',', expecting ')'
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: Can't assign to false
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ')', expecting '='
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2246: class definition in method body
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2303: class definition in method body
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2312: syntax error, unexpected keyword_do_block, expecting keyword_end
      0.upto(verts.length-1) do |a|
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2319: void value expression
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2361: syntax error, unexpected keyword_do_block, expecting keyword_end
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2382: class definition in method body
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2392: class definition in method body
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2401: syntax error, unexpected keyword_do_block, expecting keyword_end
      C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2454: syntax error, unexpected end-of-input, expecting keyword_end>
        rizkynggakool
        Hi nektares,
        thank you for reporting this problem.
        May I know what version do you use?
        • N Offline
          nektares
          I´m using 64 bit SketchUp 2015 on windows 7
            menelao74
            Errore di caricamento del file simple_building_generator.rb
            Error: #<SyntaxError: C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: Can't assign to false
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: Can't assign to false
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: Can't assign to false
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ',', expecting ')'
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: Can't assign to false
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ')', expecting '='
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2246: class definition in method body
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2303: class definition in method body
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2312: syntax error, unexpected keyword_do_block, expecting keyword_end
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2319: void value expression
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2361: syntax error, unexpected keyword_do_block, expecting keyword_end
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2382: class definition in method body
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2392: class definition in method body
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2401: syntax error, unexpected keyword_do_block, expecting keyword_end
            C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2454: syntax error, unexpected end-of-input, expecting keyword_end>
            hello, someone explain me why plugin's malfunctioning. I do like to buy programa does not operate. help me please ..... thanks.
              alnahrini
              Hi guys i have the same problem , is there any one found a fix for this problem?
              • MidgeUreM Offline
                MidgeUre
                Hello there.
                Well, I having the same error of nektares and menelao47. I'm using Sketchup 2015 and trying the Simple Building Generator v1.07 in Windows 7 64 bit.
                  typhoon1969
                  This plugin seems to work with Sketchup 2013, but not with Sketchup 2015.
                    Citelum
                    These tools are so useful for urban modelling. Thanks to all you developers who have put a lot of time into coding these plugins.
                    ThomThom mentioned above that he has felt bad about the CityGen project coming to a standstill. What a pity it's not continuing. I have been hunting for months for SKU plugins and other software that can export to SKU (eg in Collada format) to assist with street / city modelling and in a number of places I have looked I find projects partly finished and discontinued. City Engine is great but it's huge bucks when you come to add the plugins in to export in, say, Collada format.
                    So, to encourage all you coders - there are many of us, I'm sure, who would love to see a comprehensive urban modelling addition for SketchUp. Don't stop the coding please.
                    Best regards,
                    Garth
                      Angel
                      Can anyone help me get this extension to work. It installs Ok on SU 2013 but I don't think i understand the workflow properly as I get 'material cant be found in library' messages
                      An idiots guide or run thro would help me a lot
                      • sdmitchS Offline
                        sdmitch
                        I have been trying this plugin and the biggest problem with it is the materials and material names. You can't use the Sketchup name or display_name. You have to paint a face in the model with any materials you want to use and then rename them and use those names.
                        As for the plugin code, to make it Ruby2.0 compatible, you will need to remove the space in front of the opening parentheses,"(", on all the method call statements.
                        http://sdmitch.blogspot.com/
                          bboZ
                          Sketchup 2019 cannot use this plugin?? pleas help me cause this plugin is so good 😞(
                          • 2 / 2
