[Plugin] Simple Building Generator
Generate As You WantOverview :
This plugin generate textured building from marked floorplan(face).
The texture applied to building is chosen by user, therefore user have freedom to choose what building style suits best for their location.Purpose :
Help urban planner or anybody that need textured building with different simple shape to reduce worktime.Mass Building Placement
@thomthom said:
Would be useful for quick massing for larger areas, urban planning where you're not too concerned about the exact look of the building - just as long as it looks representative of the area.
Game Development
@krisidious said:
Could be very useful for game building...
Especially flight sims where you could trace out a rough draft over sat images.Usage :
- Mark face with some material
- Select the face
- Run Simple Building Generator (refer to manual)
*** make sure to save your setting otherwise you have to reinput each time you want to generate buildings** - Enjoy your generated buildings
- In order to use the quick generate building you must at least create one building and save all the setting
Manual :
General Setting :
Floorplan material name
The floorplan material name is the material name used for marking the target faces. -
Erase floorplan face when done?
If you set this to yes, after the building is generated the marked faces you've select before will be erased. -
Ground floor height (in m)
This is the ground floor of your building, the units is in metre. If you set it to 0 then the ground floor menu will be disabled. -
Floor height (in m)
This is the core of your building, the units is in metre. This setting define the height of each floor in your building (not the height of your building). Setting it to 0 will disable it.
*** currently each floor generated only have the same height, but in the future (if this project continue) there will be a feature to have different height. As I saw on CGTextures some textures have varies floor height** -
Randomize rooftop floor material
When this is set to "Yes" the generated buildings will have a randomized rooftop floor based on "Rooftop floor material" input.
*** please read about random mode for further details** -
This is your rooftop material (or list of your rooftop material). Possible inputs are single name of your material (if you don't randomize your rooftop floor material) or several name of your materials (separated by comma).
Rooftop edge height (in m)
This is the height of your rooftop edges, the units is in metre. Setting it to 0 will disable it.
*** currently there is no random height features, but in the future (if this project continue) the rooftop edges will be randomized according to the building styles** -
Fit texture? (Introduced in v1.02)
If you set this option to "Yes" then the texture (if material have texture) applied to the building will be fitted to the faces.
*** in the future (if this project continue) there will be fit texture based on material info to solve the stretched/shrinked texture problem** -
Random texture mode? (Introduced in v1.03)
The "Individual" mode will randomized the list of available material in each setting (General Setting/Ground Floor Setting/Floor Setting/Rooftop Edges Setting) without needs of input equality between each randomized material (ex. : If your rooftop has 4 materials in random list, other randomized materials shouldn't have 4 materials in random list).
The "Set" mode will randomized the list of available material globally, therefore you should have an equal input to each randomized materials (ex. : If your rooftop has 4 materials in random list, other randomized materials should have 4 materials in list).
You can increase the rate of building appearance by inserting over and over again (ex. : "rooftop_1,rooftop_1,rooftop_2" with this the "rooftop_1" will have twice the chance of appearance).
The "Set" mode can be use to create a style of random building (which will be replaced in the future), example is like below :
If you want to have :"Building Type 1" with ground floor material "GR1", floor material "FL1", rooftop floor material "RF1", rooftop edges "RE1"
and
"Building Type 2" with ground floor material "GR1", floor material "FL2", rooftop floor material "RF1", rooftop edges "RE1"then you can insert the setting like this :
Rooftop floor material : RF1,RF1
Ground floor material : GR1,GR1
Floor material : FL1,FL2
Rooftop edges material : RE1,RE1
*** current random system mode is absolutely not user friendly, but it is very versatile and powerful if you willing to learn about it**-
Save current setting? (Introduced in v1.05)
This save the current general setting, if you quit SketchUp the setting will be lost.
*** I don't plan to have any save to file features as I don't want to touch any part of your disk, instead in the future I will give you one-liner option that you can use to save and load by yourself.** -
Use previous setting? (Introduced in v1.05)
This load the previous general setting saved, if you quit SketchUp the setting will be lost, therefore there is no previous saved setting. -
Ground Floor Setting :
Randomize ground floor material?
When this is set to "Yes" the generated buildings will have a randomized ground floor based on "Ground floor material name" input.
This is your ground floor material (or list of your ground floor material). Possible inputs are single name of your material (if you don't randomize your ground floor material) or several name of your materials (separated by comma).
This save the current ground floor setting, if you quit SketchUp the setting will be lost.
This load the previous ground floor setting saved, if you quit SketchUp the setting will be lost, therefore there is no previous saved setting. -
Floor Setting :
Randomize floor material?
When this is set to "Yes" the generated buildings will have a randomized floor material based on "Floor material name" input.
Floor material name
This is your floor material (or list of your floor material). Possible inputs are single name of your material (if you don't randomize your floor material) or several name of your materials (separated by comma).
Floor level
This will be the amount of levels your building will have, if "Randomize floor level" is set to "Yes" this setting will be overrided. -
Set this to "Yes" so that the generated buildings will have different amount of levels. -
Floor level (min)
This will be the minimum amount of levels your building will have, if "Randomize floor level" is set to "No" this setting is disabled. -
Floor level (max)
This will be the maximum amount of levels your building will have, if "Randomize floor level" is set to "No" this setting is disabled. -
This save the current floor setting, if you quit SketchUp the setting will be lost.
This load the previous floor setting saved, if you quit SketchUp the setting will be lost, therefore there is no previous saved setting. -
Rooftop Edges Setting :
Randomize rooftop edges default material?
When this is set to "Yes" the generated building edge sides which doesn't use different material will be applied by this default material based on "Rooftop edges default material name" input.
This is your rooftop edges default material (or list of your rooftop edges default material). Possible inputs are single name of your material (if you don't randomize your rooftop edges material) or several name of your materials (separated by comma).
Different outer faces material?
When this is set to "Yes" the outer faces of generated building edges will have a different material based on "Outer faces material name" input. If not outer faces of the rooftop edges will use default rooftop edges material. -
Randomize outer faces material?
When this is set to "Yes" the outer faces of generated building edges material will be overridden by material based on "Outer faces material name" input. If "Different outer faces material?" set to "No" this option will not have any effect.
This is your outer rooftop edges material (or list of your outer rooftop edges material). Possible inputs are single name of your material (if you don't randomize your outer rooftop edges material) or several name of your materials (separated by comma). If "Different outer faces material?" set to "No" this option will not have any effect.
Different top face material?
When this is set to "Yes" the top face of generated building edges will have a different material based on "Top face material name" input. If not top face of the rooftop edges will use default rooftop edges material. -
Randomize top face material?
When this is set to "Yes" the top face of generated building edges material will be overridden by material based on "Top face material name" input. If "Different top face material?" set to "No" this option will not have any effect.
This is your top rooftop edge material (or list of your top rooftop edge material). Possible inputs are single name of your material (if you don't randomize your top rooftop edges material) or several name of your materials (separated by comma). If "Different top face material?" set to "No" this option will not have any effect.
* please read about random mode for further details -
Different inner faces material?
When this is set to "Yes" the inner faces of generated building edges will have a different material based on "Inner faces material name" input. If not inner faces of the rooftop edges will use default rooftop edges material. -
Randomize inner faces material?
When this is set to "Yes" the inner faces of generated building edges material will be overridden by material based on "Inner faces material name" input. If "Different inner faces material?" set to "No" this option will not have any effect.
This is your inner rooftop edges material (or list of your inner rooftop edges material). Possible inputs are single name of your material (if you don't randomize your inner rooftop edges material) or several name of your materials (separated by comma). If "Different inner faces material?" set to "No" this option will not have any effect.
This save the current rooftop edges setting, if you quit SketchUp the setting will be lost.
* I don't plan to have any save to file features as I don't want to touch any part of your disk, instead in the future I will give you one-liner option that you can use to save and load by yourself. -
This load the previous rooftop edges setting saved, if you quit SketchUp the setting will be lost, therefore there is no previous saved setting.
Release :
- 05/08/2015 : Simple Building Generator v1.00
- 06/08/2015 : Simple Building Generator v1.01
- 08/08/2015 : Simple Building Generator v1.02
- 09/08/2015 : Simple Building Generator v1.03
- 11/08/2015 : Simple Building Generator v1.04
- 12/08/2015 : Simple Building Generator v1.05
- 12/08/2015 : Simple Building Generator v1.06
- 14/08/2015 : Simple Building Generator v1.07
simple_building_generator.rb
After submitting the questionnaire the download link will appear
Release Notes :
=== v1.00 ===
Initial release
=== v1.01 ===
Fix :-
Bug rooftop edges is reversed
=== v1.02 ===
New Feature : -
Option to fit the texture to face
=== v1.03 ===
New Feature : -
Option to randomize the building texture based on an input set.
=== v1.04 ===
New Feature : -
Option to apply different texture for each side of the rooftop edges.
=== v1.05 ===
New Features : -
Option to save configuration for each setting.
Option to use previous saved configuration for each setting.
Fixes : -
The process check message get so long when inserting many building style that made the confirmation button difficult to click(even can't see them).
Now the target also check the backface material(some people doesn't care front or back they just apply the material and found that my plugin doesn't work).
=== v1.06 ===
New Features : -
Quick Building Generation.
=== v1.07 ===
New Feature :- Added option to override the erase floorplan setting in the quick building generation
- No more annoying message
Excellent for a second post! Contact the moderators and get it published to the pluginstore, it also affords you a new "badge" below your handle...
If I recall correctly, something similar was done by one of the other plugin authors, Julia Cristina Eneroth, however I can't seem to find it.
Thank you very much juju, I really appreciate your comment
How to contact the moderators?
I don't know that, all I know when I google "SketchUp Building Generator" these two topics showed up :
http://sketchucation.com/forums/viewtopic.php?f=314%26amp;t=19410
http://sketchucation.com/forums/viewtopic.php?f=314%26amp;t=19524
That's why when I first post in this site I add remus name to my post
http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=62713Anyway, have you tested my plugin? Did it work as you or I expected?
Please share if there's any problem
very nice... now all I need is a city to map.
I found the extension, strange that it wasn't on her site, from I could tell...
SketchUp Extension Warehouse
Your library of custom third-party extensions created to optimize your SketchUp workflow.
(extensions.sketchup.com)
Probably not quite the same as what you're doing, but not too dissimilar either.
This is looking very nice!
CityGen faded away because none of us had time to continue it.
Always felt bad about that one as it felt like a good collaboration project. -
Thank you very much kris
Yes, it's sad that the major problem is this plugin is useless without any city map
Do you know any site that provide 2D city map?
If you do, I will create tips section for that and put it in the first post.
I'm sure that it'll help a lot people
That plugin is awesome
Both are "Building Generator" and aim to reduce worktime.
Her plugin create a house, mine create a skyscrapper
And judging by how her plugin work I bet it's far more harder to create than this one
Always felt bad about that one as it felt like a good collaboration project.Thank you very much thom...
Having a predecessor says something about what I'm working on is a morale boost
Sad to know that CityGen was never complete, but I'm glad CityGen dev team have a better job
Wow. This is an excellent plugin. The great thing about this is that the shapes are simple rectangular volumes which lend better for urban landscapes as opposed to pitched roofs. Well done!
Hi, rizkynggakool.
Nice script, but i canยดt get it work. Iยดm running on SU2015, and i got a big errormessage with a lot of content. It seems to expect something. In the description
you mentioned a dependencie with "offset.rb" - incuded. I can not find it anywhere.
May be that this is my problem ??Greetings ...
Thank you very much Elibjr, I really appreciate that
I'm sorry for the late reply, I've been busy with my college for a few days
Anyway, have you tried the new v1.07 ?
I'm pretty sure it'll reduce your worktime even more
@ralle said:
Hi, rizkynggakool.
Hi Ralle, thank you for contacting me and for the feedback.
What kind of error message?
Could you provide some screenshot?Yes, it's using offset.rb by Rick Wilson from smustard.
but that shouldn't be problem anymore since I already included the offset.rb inside this plugin. -
i guess i got the same message on the ruby console u_u itยดs this one:
i hope it has an easy fix!Error Loading File simple_building_generator.rb
Error: #<SyntaxError: C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ',', expecting ')'
...arch_floorplan (arr_main_input, arr_gf_input, arr_f_input, a...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ')', expecting '='
...put, arr_f_input, arr_re_input)... ^
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ',', expecting ')'
...on_material (ground_floor_face, arr_ground_floor_pts_down[in...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ')', expecting '='
...ex], ground_floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ',', expecting ')'
..._position_material (floor_face, arr_floor_pts_down[index - 1...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ')', expecting '='
...own[index], floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ',', expecting ')'
...n_material (rooftop_edges_face, arr_rooftop_edges_pts_down[i...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ')', expecting '='
...oftop_edges_outer_mtl, mtl_fit)... ^
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ',', expecting ')'
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ')', expecting '='
...[0], ground_floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ',', expecting ')'
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ')', expecting '='
...ts_down[0], floor_mtl, mtl_fit) # ===== UPDATE [08/08/2015] ...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ',', expecting ')'
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ')', expecting '='
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ',', expecting ')'
...terial (rooftop_edges_top_face, arr_rooftop_edges_pts_top[0]...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: Can't assign to false
..., rooftop_edges_top_mtl, false)... ^
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ')', expecting '='
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ',', expecting ')'
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: Can't assign to false
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ')', expecting '='
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ',', expecting ')'
...rial (rooftop_edges_inner_face, arr_rooftop_edges_offset_pts...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ')', expecting '='
...oftop_edges_inner_mtl, mtl_fit)... ^
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ',', expecting ')'
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ')', expecting '='
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ',', expecting ')'
...osition_material (rooftop_face, arr_floor_pts_top[0], arr_fl...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: Can't assign to false
...pts_top[1], rooftop_mtl, false) # ===== UPDATE [08/08/2015] ...
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ')', expecting '='
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ',', expecting ')'
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: Can't assign to false
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ')', expecting '='
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2246: class definition in method body
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2303: class definition in method body
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2312: syntax error, unexpected keyword_do_block, expecting keyword_end
0.upto(verts.length-1) do |a|^C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2319: void value expression
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2361: syntax error, unexpected keyword_do_block, expecting keyword_end
0.upto(verts.length-1) do |a|^C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2382: class definition in method body
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2392: class definition in method body
C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2401: syntax error, unexpected keyword_do_block, expecting keyword_end
0.upto(verts.length-1) do |a|^C:/Users/JC Workstation/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2454: syntax error, unexpected end-of-input, expecting keyword_end>
i hope it has an easy fix!Hi nektares,
thank you for reporting this problem.
May I know what version do you use? -
Iยดm using 64 bit SketchUp 2015 on windows 7
Errore di caricamento del file simple_building_generator.rb
Error: #<SyntaxError: C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1463: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1872: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1882: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1893: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1904: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1914: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1925: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: Can't assign to false
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1948: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: Can't assign to false
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:1978: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2012: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2021: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: Can't assign to false
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2041: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ',', expecting ')'
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: Can't assign to false
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2057: syntax error, unexpected ')', expecting '='
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2246: class definition in method body
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2303: class definition in method body
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2312: syntax error, unexpected keyword_do_block, expecting keyword_end
0.upto(verts.length-1) do |a|^C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2319: void value expression
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2361: syntax error, unexpected keyword_do_block, expecting keyword_end
0.upto(verts.length-1) do |a|^C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2382: class definition in method body
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2392: class definition in method body
C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2401: syntax error, unexpected keyword_do_block, expecting keyword_end
0.upto(verts.length-1) do |a|^C:/Users/PC/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/simple_building_generator.rb:2454: syntax error, unexpected end-of-input, expecting keyword_end>
hello, someone explain me why plugin's malfunctioning. I do like to buy programa does not operate. help me please ..... thanks.
Hi guys i have the same problem , is there any one found a fix for this problem?
Hello there.
Well, I having the same error of nektares and menelao47. I'm using Sketchup 2015 and trying the Simple Building Generator v1.07 in Windows 7 64 bit. -
This plugin seems to work with Sketchup 2013, but not with Sketchup 2015.
These tools are so useful for urban modelling. Thanks to all you developers who have put a lot of time into coding these plugins.
ThomThom mentioned above that he has felt bad about the CityGen project coming to a standstill. What a pity it's not continuing. I have been hunting for months for SKU plugins and other software that can export to SKU (eg in Collada format) to assist with street / city modelling and in a number of places I have looked I find projects partly finished and discontinued. City Engine is great but it's huge bucks when you come to add the plugins in to export in, say, Collada format.
So, to encourage all you coders - there are many of us, I'm sure, who would love to see a comprehensive urban modelling addition for SketchUp. Don't stop the coding please.
Best regards,
Garth -
Can anyone help me get this extension to work. It installs Ok on SU 2013 but I don't think i understand the workflow properly as I get 'material cant be found in library' messages
An idiots guide or run thro would help me a lotThanks
