    [Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.2013
    54 Posts 26 Posters 63.9k Views 26 Watching
    • OxerO Offline
      Oxer
      Thanks Aerilius!!
      I have saw that you have included the line for the Toolbar and spanish language, thanks again.
      • irwanwrI Offline
        irwanwr
        Thank you very much for this plugin.
          slander
          Thanks very much for this. It produces a really lovely result for drawing thin arches.
          I noticed a small problem when I move the endpoints of an existing catenary around - gravity seems to veer away at an peculiar angle. All plan-plane moves seem to work just fine though.
            Aerilius
            the resulting curve is just SketchUp geometry, and does not expose physical behavior of a wire. When moving one end point of an arc, it shows normal SketchUp behavior (ie. SketchUp tries to squeeze or stretch the arc to fit to both end points).
            But a wire that really (physically) moves with attached objects would be a cool feature. The plugin would need observers to watch all the time on all these arcs, and recalculate an arc once an endpoint is changed.
              Ben Ritter
              I cannot get the plugin to work with specific inputs. It creates a the same curve no matter what I enter.
              Can you help?
                Ben Ritter
                Never mind, I figured it out. You have to press Enter after entering the distance, etc.
                • E Offline
                  escufi
                  Nice Plugin Aerilius , very usefull. Thanks a lot
                  • dereiD Offline
                    derei
                    Very nice and useful !
                    One question: shouldn't be better suited under DRAW menu, instead of Extensions?
                    There is a uncanny tendency to put the plugins under Tools or Extensions menus... leaving all others with too little entries, even if the plugin in cause should better fit in other menu.
                    Cheers.
                    DESIGNER AND ARTIST DEREI.UK
                      Nothing is preventing you from editing the .rb file and changing it to appear in the draw menu.
                      • dereiD Offline
                        derei
                        Unless the author comes with a update at one point and the old (modified) script is replaced... that was my point. I already edited several of the plugins I use.
                        • E Offline
                          Einstein
                          I'm confused.
                          I can see this plugin had an update recently [Version Updated: 2021-04-12 09:26:24]
                          but it's been version 1.4.1 since 2013. Why was it updated now while it's still the same version and no changes were introduced?
                            The current version is v1.4.1
                            https://sketchucation.com/pluginstore?pln=ae_WireTool
                            Perhaps the author [ae] finally decided to re-sign it to suit the newer SketchUp versions, but the code was otherwise unchanged ?
                            • 3 / 3
