    Context Menu Confusion
    12 Posts 6 Posters 689 Views 6 Watching
    • KrisidiousK Offline
      Krisidious
      So I'm a little lost in the mess I call a Context Menu... I swear I used to have some nice select similar groups, convert groups to comps, selection toys etc types of commands and now, with my plugin folder bloat I find that the bottom has run off the screen and some things are missing. I've checked on thomthom's selection toys ui settings for things being turned off and it seems like everything is check marked. Is there a way to ensure the Context menu folds on the screen or allows full viewing?
      Here's what I'm dealing with. You can see at least one thing below that is not shown fully.
      By: Kristoff Rand
        Krisidious
        Gave myself a work around by seeing my own screenshot. I enabled autohide on the taskbar and it showed what I figured was going on... Missing buttons below. Now how do I force the Context Menu to stay in viewable area?
        Here's the missing commands.
        By: Kristoff Rand
        • TIGT Online
          I have every Plugin known to man πŸ˜‰
          BUT I don't have this issue...
          This is because I have many of them disabled under the SCF Plugins Manager, I only enable them [temporarily for that session == Orange button] and thus the main-menu AND context-menu lists are much shorter.
          I cannot believe you need every single one loading each time you start SketchUp.
          If nothing else trimming what loads speeds things up considerably.
          You can enable/disable your Plugins individually or by picking multiple entries [with Ctrl/Shift key modifiers]...
          OR you can make Sets [Blue button] so you can have varying lists of ALL, Site, Modeling, Detailing, Rendering etc - that way you don't even need to think about it after the initial sorting session...
            Krisidious
            I need all of them... Always... ALWAYS!
            By: Kristoff Rand
              Maybe you should turn your monitor 90Β° then.
              • pbacotP Offline
                You need a bigger screen--or another screen that is mapped to below the main screen (is that possible?)
                  Krisidious
                  you mean like this?
                  By: Kristoff Rand
                  • TIGT Online
                    Seek therapy...
                    πŸ˜‰
                    • FrederikF Offline
                      Frederik
                      @tig said:
                      Seek therapy...
                      πŸ˜‰
                      Cheers
                      Kim Frederik
                        Krisidious
                        I did... They told me to seek a programmer... 😐
                        By: Kristoff Rand
                        • cottyC Offline
                          cotty
                          my SketchUp gallery
                          • TIGT Online
                            http://mfgblog.maryjanesfarm.org/Uploads/Image/Does Not Compute/confused smiley face.jpg
