    [Plugin] ImageTrimmer
    364 Posts 58 Posters 357.7k Views 58 Watching
    • B
      bitslapped
      It was a compromise between VRay and Sketchup.
      I ended up exporting the transparency selection path from photoshop to illustrator to dwg then overlaying the outline onto the image in sketchup. It meant I could use the antialiasing in the images for vray renders (where they do catch shadows) and produce quite smooth shadows in sketchup.
      The hope is that in future versions of sketchup, png with alpha will catch shadows.
      https://3dwarehouse.sketchup.com/model.html?id=uff66f099-c698-496c-b131-c13c1e197243
      Thanks for your work TIG. I will keep trying this one as new releases come out.
        rv1974
        ❓ Nothing happens after 'making edges' stage.
        Ruby console message:
        Error: #<Errno::ENOENT: No such file or directory - C:\autosave\TrimmedImages\uuu[Edges].dat>
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:264:in readlines' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:264:in make_edges'
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:196:in process_image' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:165:in initialize'
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:818:in new' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:818 C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/SKMtools/ImageTrimmer.rb:264:in call'
        P.S. If I run che check mentioned above I have this:
        UI.openURL("file:///"+"../full/path/to/EdgeDetector.jar")
        false
        the png I tried to get trimmed
          Here's a PNG I reprocessed... BUT the original works as it uploaded anyway, and a v8 SKP showing that Image and ImageTrimmed Cutout...
          SSO it works fine for me. πŸ˜•
          Do you have Java installed/enabled and .jar files set to open with Java ?
          Some decompression apps hijack that file suffix and stop them executing properly...
          As outlined more fully here... http://sketchucation.com/forums/viewtopic.php?p=518232#p518232
          uuu.skp
            manifestphoto
            Hi there, I'm new to sketchup and glad I found your plugin, however it keeps crashing the application when I try to trim an image. If I do anything else with my computer at all, even resizing the Sketchup window or typing in this box, while it is running, the program hangs. If I leave it focused on Sketchup and do not use my PC at all, it gets through the "scanning pixels" function, but hangs during the "processing edges" operation, never getting past about 15%.
            My PC is not brand new, but it's also not that old and is fairly capable . . . so I don't think it's a processing issue. Are other people experiencing this? Is there a fix?
            Thanks.
              Read back through the posts...
              Sticking at around 15% is indicative of a failure in the image-processing...
              It is hanging not crashing, as it never completes its processing.
              ImageTrimmer uses .jar files to process some aspects of its image-files etc.
              These are small executable Java apps that come with the toolset.
              Sometimes a compression exe will hijack that .jar file-type suffix and thereby prevent them 'running'.
              So ensure that you have Java installed and activated, and that .jar is a file-type which will 'open' with Java etc...
              Also the PNG file needs to be a reasonable size - the number of pixels will obviously influence the time to process it, but a minute or so should suffice.
              Also crop the PNG so that the number of 'background' pixels is minimized - every pixel is considered, even those that will eventually be removed.
              Also remember that ALL transparent pixels will be removed - even slightly transparent ones - so ensure that the PNG consists of opaque pixels where you want to keep the face and transparent ones for the 'background' you want to remove...
              If you still have issues please post the PNG you are trying to trim, and a screen-shot of your Java setup...
              • H
                hendrygunawan
                I have the same problem too, and I try something funny. Just make sure your extensions in preferences got checked all. It solved my problems.
                Just want to share. πŸ˜„
                • deaneauD
                  deaneau
                  @TIG 1 picture tell more than 100 words
                  1 movie tell more than 10[sup:36t5zafz]10[/sup:36t5zafz] words
                  a movie with some subtitles would be good,too.
                  TIG you must know...programmer have more logic cells in the brain than other.
                  some people try to intuit (me,too) and would understand this in the first time more intuitive.
                  logic =/= intuition ( Logic is not equal to Intuition)
                  Thank You Dean
                  • P
                    PickyBiker
                    I'm having trouble with the imagetrimmer not finding transparent pixels that can form faces. The image certainly does have a large transparent area.
                    I included the error message and the image file.
                    Error Msg
                      You didn't supply the PNG file.
                      It needs to have an alpha-channel of transparent pixels.
                      Any degree of transparency assumes those pixels are to be ignored.
                      The usual issue is the other way round - too many pixels going as some are slightly transparent !
                      If you see the Image in SketchUp can you see through portions of it ?
                      With the PNG itself I might be able to comment more constructively...
                      PS: Are you getting the processed files made ?
                      Is .far file-type associated with Java - some compression tools hijack that type and stop ImageTrimmer working properly...
                      • P
                        PickyBiker
                        Sorry about the missing png file... Here it is
                          Do you have th latest version installed [ http://sketchucation.com/pluginstore?pln=SKMtools v20140207 ]
                          Your PNG works fine for me - see the screenshot - so I suspect something is adrift in the way the .jar files get processed...
                          See the earlier comment about the file-type association etc...
                          Do you get a folder made with the SKP that includes various files ?
                          If so zip it and post it...
                          PS TIP:
                          Auto-Crop the PNG image to remove the redundant transparent pixels - it'll speed up the processing, because every pixel gets inspected, and all of the extra transparent ones get ignored anyway !
                            davecoopstl
                            Can someone please explain to me how to use TIG's Image Trimmer (part of his SKMtools package)?
                            I'd love to be able to quickly and easily trim my PNG files, so they cast shadows correctly.
                            TIG, I'd love some advice.
                            Thanks.
                            Dave.
                            • pbacotP
                              there's a good explanation here: http://sketchucation.com/forums/viewtopic.php?t=33445
                                @dave
                                I have merged your post with the base thread.
                                Pointless in splitting...
                                If you read the initial instructions and resultant clarifications that are listed here, then it should suffice.
                                PrΓ©cis:
                                Ensure Java is enabled.
                                Ensure JAR files are NOT associated with another app - some compression tools might unexpectedly hijack that file extension. They always need to be set up as small executables, associated with Java.
                                Make a PNG file with transparent pixels, which you want to remove later.
                                Any pixels with even a slight transparency will be removed, so flatten the image and then re-add an alpha-layer and delete the 'background' pixels you want to lose.
                                Also crop the image as tightly as possible - every pixel will be considered, so it's pointless having hundreds of transparent pixels surrounding what you want to keep - it just extends the processing time...
                                Run the tool and it should make what you want after a minute or so.
                                The finalizing dialogs are self-explanatory...
                                The 'smoothing' defaulting at 2.0 is usually sufficient to resolve jagged 'pixelated' edges in the final 'cutout'...
                                  davecoopstl
                                  TIG, I got it working. I think I know what was wrong: My PNG file was almost 28 Megabytes!
                                  I reduced the resolution from 300 to 100, cropped it tight, and the file went down to about 1 Meg.
                                  Image Trimmer worked like a charm!
                                  Thanks for the advice.
                                  Dave.
                                    AGiam9
                                    Hi TIG,
                                    I'm having some trouble getting the image trimmer to work on the below logo. I'm not all that familiar with programming and have tried to follow previous advice given in this forum but it is likely I am missing something. When I use the trimmer it starts loading and then suddenly stops and nothing happens. According to the guide on how to use this means there are no useable transparent pixels but I do not think that should be the case. I created two different versions of the PNG file, one with the logo as transparent and one with the logo filled with the outside transparent. From my understanding, the first one should work. So far I have troubleshooted by ensuring the EdgeDetector.jar file is executed by Java (it was not when I started, had to set it up). Not sure what the next step may be or if it is just the file. Can you please advise?
                                    File to be trimmed
                                      If you look closely at the PNG, you'll see there is a huge number of pixels to work through for creating the edges. You might just need to wait longer. SketchUp will show (Not Responding) in the title bar while it is processing. Maybe go for a walk or eat a meal or something.
                                      Do you know what fonts were used? It might make sense to use 3D text instead of Image Trimmer if you can get those fonts.
                                        With patience and a walk of the dog...
                                        I used 0 for the simplification factor.
                                          It's just been reported that ImageTrimmer is broken with SketchUp v2019.2
                                          There seems to be a 'reversion' in SketchUp's core code and now an Image's face's material can no longer be referenced for use in the rest of the model.
                                          However, ImageTrimmer still works fine in all earlier versions of SketchUp.
                                          Once v2019 is debugged it might work again - if not I might have to invent a workaround πŸ˜’
                                          It'll also impact on all of the related SKM tools involving Images' materials 😲
                                            Here's an updated version of SKMtools.
                                            It fixes the glitch found with ImageTrimmer, introduced with SketchUp's v2019.2 new API restrictions on directly using the material from an Image in the model's entities.
                                            There was already a SKMtools method to make a new material from an Image [leaving the Image intact], and add that material to the model's materials; this is now utilized to copy the Image's material into the model for reuse on the trimmed-component's faces...
                                            https://sketchucation.com/pluginstore?pln=SKMtools
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 14 / 19
