    Code correction
    7 Posts 3 Posters 733 Views 3 Watching
      kmk111890
      Hello, I'm practicing making code by myself and got stuck on error. I can connect arc with a line from 0,0,0. but can't add one more line that connects between 0,0,0 and the other side of arc. I wish one icecream cone shape will show up after executing codes.
      ents = Sketchup.active_model.entities pt0 = [0,0,0] pt1 = [0, 0, -5.cm] pt2=pt1.transform(Geom::Transformation.rotation(pt0,[0,0,1],30.degrees)) arc = ents.add_arc [0,0,0], [0,0,-1],[0,-1,0], 5.cm, 0, 30.degrees g=ents.add_group() ge=g.entities ge.add_cpoint(pt0) ge.add_cpoint(pt1) ge.add_cpoint(pt2) ents.add_line pt0, pt1 ents.add_line pt0, pt2 face = ents.add_face pt0, pt1, pt2 path = ents.add_circle [0,0,-5.cm], [0,0,1], -5.cm face.followme path ents.erase_entities path
        slbaumgartner
        In the future, please enclose your code in
        • make it easier for others to copy.
        You try to rotate pt1, which is on the blue axis, using a rotation also about the blue axis. This has no effect, since pt1 has no x or y value to rotate. Hence pt2 is the same as pt1 and this causes a duplicate points error when you try to add a face using them as two corners. Try using [0,-1,0] as the vector instead of [0,0,1].
          kmk111890
          Thanks you, slbaumgartner. Now its working well πŸ˜„
          However, this is the first step for drawing cone. The main goal is to draw cone freely.
          I'm trying to add inputbox with the corrected code you gave, and have already made codes that can draw various shape with inputbox, but it didn't work again. In my view, there is no problem. Could you please look over it again?
          require 'sketchup.rb'
          class Cone
          @@Length = @@angle = nil
          def create_cone
          @@Length = 0.mm if not @@Length
          @@angle = 0.degrees if not @@angle
          prompts = ["Radius","Angle"]
          values = [@@Length, @@angle]
          results = inputbox prompts, values, "Fire sensor"
          if results
          @@Length, @@angle = results
          model = Sketchup.active_model
          model.start_operation "Fire sensor"
          compdef = Sketchup.active_model.definition.add
          ents = compdef.entities
          @Length = @@Length
          @angle = (@@angle)/2
          @pt0 = [0,0,0]
          @pt1 = [0, 0, -@Length]
          @pt2=@pt1.transform(Geom;;Transformation.rotation(@pt0,[0,-1,0],@angle))
          arcarray = ents.add_arc [0,0,0], [0,0,-1],[0,-1,0], @Length, 0, @angle
          arc = arcarray[0]
          arccurve = arc.curve
          verts = arccurve.vertices
          a = ents.add_line @pt0, @pt1
          b = ents.add_line @pt0, @pt2
          face = ents.add_face @pt0, @pt1, @pt2
          path = ents.add_circle [0,0,-@Length], [0,0,1], -@Length
          face.followme path
          face2 = ents.add_face verts
          path2 = ents.add_circle [0,0,-@Length], [0,0,1], -@Length
          face2.followme path2
          ents.erase_entities path2
          group=ents.add_group ents.to_a
          trans = Geom;;Transformation.new
          status = model.place_component(compdef)
          Sketchup.active_model.active_entities.add_instance(compdef, trans)
          model.commit_operation
          end #if
          Sketchup.send_action 'selectSelectionTool;'
          end #def
          end #Class
          if( not file_loaded?(__FILE__) )
            UI.add_context_menu_handler do |menu|
            dir=File.dirname(__FILE__)
            	cmd_array = []
             cmd = UI;;Toolbar.new "sphere"
             # Create the Command object
             cmd = UI;;Command.new("Cone") {Sketchup.active_model.select_tool Cone.new.create_cone}
             # Configure the Command's appearance
             cmd.small_icon = cmd.large_icon = dir+"/FGmanual/images/cone.png"#<--
             cmd.tooltip = "Cone"
             cmd_array.push(cmd)
             tb=UI;;Toolbar.new("Creating tools")
             cmd_array.each {|i| tb.add_item(i)}
             	tb.show if tb.get_last_state == -1
          file_loaded(__FILE__)
          • TIGT Online
            @@angle = **30.0** unless @@angle
            @angle = (@@angle**.degrees**)/2
            The various parts of the API accepting angles needs them in radians.
            If the user inputs a float as 'degrees' you need to tell SketchUp it in 'radians' by using the converter .degrees
            You do NOT want the angle to be 0.0 as that does nothing so trap for wrong inputs.
            Also the length should never be 0.0 so trap for that too - perhaps with defaults of say 30.0 and 50.mm ?
              kmk111890
              Thanks you for a kind comment, TIG, but it's not still working now. There is no problem until adding numbers in the inputbox. The problem is nothing shows up after clicking 'ok'.
              • TIGT Online
                Sorry, but your code is full of issues...
                Can I suggest you temporarily add a few Sketchup.active_model.active_view.refresh;UI.messagebox('?') into your code, then run it with the Ruby Console open, and see what happens, when you see it fails you can see what's made at that step.
                The length/angle need fixing as I said before, but also...
                I see is that you attempt to add a group from an array of entities that are NOT in the active_entities context - this will often fail - even splat! I don't see why you do this anyway ?
                Also its model.definition**s** - you missed off the 's'.
                Also consider naming the component definition ?
                Also why place an instance and then also add one - why ?
                  kmk111890
                  Hi, TIG. Finally, Its working as I have hoped. This is the corrected code. I needed not use 'group'. The cone shape is created after I deleted the line. Thank you!
                      class Cone
                      @@Length = @@angle =@@x=@@y=@@z = nil
                      def create_cone
                      @@Length = 100 if not @@Length
                      @@angle = 30.0 if not @@angle
                      @@x = 0.mm if not @@x
                      @@y = 0.mm if not @@y
                      @@z = 0.mm if not @@z
                      prompts = ["Radius","Angle", "x", "y", "z"]
                      values = [@@Length, @@angle, @@x, @@y, @@z]
                      if results
                      @@Length, @@angle, @@x, @@y, @@z = results
                      compdef = Sketchup.active_model.definitions.add
                      @Length = @@Length.mm
                      @angle = (@@angle.degrees)/2
                      @pt0 = [0,0,0]
                      arc = arcarray[0]
                      face.followme path
                      trans = Geom;;Transformation.new([@@x.to_i, @@y.to_i, @@z.to_i])
                      status=model.place_component(compdef)
                      end #if
                      end #def
                      end #Class
                           cmd_array = []
                         cmd_array.push(cmd)
