    Is there pluging for expanding/making face along line/edges?
    41 Posts 12 Posters 2.5k Views 12 Watching
    • pbacotP Offline
      I think the use is edges in a face. In particular, edges with two coplanar faces.
      • JQLJ Offline
        JQL
        @tig said:
        @jql said:
        Tig's offset its almost there Dave, but it can't work on an edge alone...
        If you want to offset edges which have no associated faces, then how do 'we' know the plane onto which the offset new-edge is to be positioned ?
        I know it could be on the 'ground-plane' but that is not that useful...
        At least my tool offsets onto the related face.
        If the edges which are to be offset are coplanar why not create a face and use that for the offset edges, you can always delete the faces afterwards...
        πŸ˜•
        You mean it should work on an edge alone if it is associated with a face? I should doublecheck it!
        I use edgetools split edges most of the time for this sort of stuff (and other) as Pixero suggested. Is your offset capable of expanding edges to the end of the associated face too?
        How can I've missed those features!?
        I should triplecheck it!
        www.casca.pt
        Visit us on facebook!
        • N Offline
          namelessone
          Wow, thanks for suggestions! I've tested them and unfortunately haven't found one that makes the desired result in simple, elegant manner πŸ˜„The best what I've found of all suggestions, was TIG's smart offset, but it had 2 problems. 1. Doesn't erase old edges. If you're creating a complex pattern of 'ribs', selecting edges may feel cumbersome. I guess plugins dedicated for selecting edges could help there, but it that would be a little overkill. 2. If you draw circles (for axis hinge, example), the old edge interferences with offseted circle, so you have to erase/smooth/weld to achieve correct result after pushpulling pattern 3. You have to put offset length number manually, requires experimenting/measuring to get right proportions, which sometimes isn't easy if scales of pattern isn't obvious (tldr, I'd love to see visual adjustment like in fredo6' joinpushpull plugin).
          Nonetheless, smart offset is super handy for robotic modelling, I've had a lot of cases where I had to offset weird shapes and I had to clean/correct the result of sketchup's default offset tool πŸ˜„ Not anymore!
          About how 'new' plugin could work there, I've prepared graphic how I imagine the plugin progress
          PS Does anyone know how this kind of structure is called? The flat metal surface strengthened by outer edges and 'ribs' inside? Check the image I've attached, you can see these structures in upper part of model
            Can you put an image of this ?
            • JQLJ Offline
              JQL
              Edgetools split face...
              www.casca.pt
                This sort of things ?
                • JQLJ Offline
                  JQL
                  That sort of things. Thanks Pilou, my gif making abilities were ruined with this 4k monitor.
                  www.casca.pt
                  • pbacotP Offline
                    Edge tools split face is great but what OP is asking for is double offsets and removal of the original edges, also for working on curves which split face can't help with much. The second part--removal of original edge--is not too slow manually.
                    This action seems so common. In making facades, doors, windows cabinets, paneling etc. where all is needed is a "reveal" or joint or, in this case a ridge. So easy to lay out the defining edges, next step is to give those edges "width" for 3d use.
                    I'd leave out the perimeter action as that seems a different action.
                    The last example can be achieved by smart offset. I think it is more difficult to just do the interior edges.
                    So for now smart offset for multiple edges and split faces for single edges...
                    • hdpvH Offline
                      hdpv
                      Hello Namelessone!
                      Try my plugin S4u Frame.
                      http://sketchucation.com/pluginstore?pln=s4u_frame
                      Suforyou
                      http://www.sketchupforyou.com
                      • cottyC Offline
                        cotty
                        @Huynh: very nice plugin! Works great for this example.
                        my SketchUp gallery
                        • cottyC Offline
                          cotty
                          Quick example...
                          my SketchUp gallery
                            French version πŸ˜‰
                            Click image for Animation! πŸ€“
                            s4u_frame.zip
                              PS Seems Triangulated frames must be refined! πŸ˜‰
                                dtrarch
                                Hi All
                                s4u Frame and s4u Slice are just must have plugins.
                                Perfect for this use and ONE click to go. πŸ‘ πŸ‘ πŸ˜„ πŸ˜„
                                Thanks Vi
                                dtr
                                • hdpvH Offline
                                  hdpv
                                  Thank you!
                                  @Pilou: convert lines to curve ,It'll work correct.
                                  Suforyou
                                    Convert line to curves
                                    Very cool trick! πŸ‘ 😎 β˜€
                                    • cottyC Offline
                                      cotty
                                      Can you explain the "trick" a bit more, please?
                                      my SketchUp gallery
                                        The trick! πŸ˜‰
                                        And all will work fine! 😎
                                        • cottyC Offline
                                          cotty
                                          And for my example (e.g. rectangle with diagonal)?
                                          my SketchUp gallery
                                            My original http://sketchucation.com/pluginstore?pln=Latticeizer
                                            Maybe not the best, but you judge...
                                            • 3 / 3
