[Plugin] FredoTools - v4.5a - 02 Apr 24
Now it works perfect!
It seems not so perfect. There is a problem when dealing with small faces I guess. Here is the example. Group is a solid, lines are ortho. Geometry is OK. The only thing is there is a small misalignment between the faces. But it could be made on purpose...To fix it I just moved one of the faces to meet another and erased the line, which made volume ok.
Thanks for signaling.
This is actually not related to small faces.I will republsih soon with the fix
NEW RELEASE: FredoTools v2.7d - 28 Apr 15
FredoTools 2.7d is a release for FredoTools::SolidVolume v1.1c, which computes the volume and faces area of solids in the selection. In this third version, the volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner. I also fixed bugs in the calculation of volumes.
Should this appear in your update log?
This should be OK now.
Looks to be operating properly now. Thank you.
NEW RELEASE: FredoTools v2.7e - 29 Apr 15
FredoTools 2.7e is a release for FredoTools::SolidVolume v1.1d, which computes the volume and faces area of solids in the selection. This fourth version includes a fix for the correct display of the main dialog box.
thank you -
great plugin, complete and really functional
NEW RELEASE: FredoTools v2.8a - 09 Jul 15
FredoTools 2.8a is a minor release for:
- SolidVolume, which now accepts solids with holes
- ReportLabelArea, which now computes the correct area removing the space taken by the glued componentss in cut opening mode.
Warning:
Please upgrade to LibFredo6 6.8c if you installed FredoTools v2.8.
There is a bug in FredoTools::Convexify, which is fixed in LibFredo6 v6.8c.
Sorry for inconvenience
Fred
Thanks Fredo!
Hello Fredo, je viens de passer sur skp 2015. J etais sur 2008 et tout allait bien et voici ce qui m'arrive malgré pas mal de tentatives.. ça fait 15 jours que c'est comme ça... et moi SKP sans libfredo, c'est comme si on me coupait un bras...tu saurais ce que je pourrais faire pour telecharger ton plugin et qu il fonctionne ? je suis sous mac yosemite ( non de Dieu que Mavericks me manque!!!)
Merci de tes lumières.... si tu en as !
ElviremErreur de chargement du fichier Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:inmatch' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:716:in
block (2 levels) in load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:ineach' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:715:in
block in load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:inforeach' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:713:in
load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:inblock in load_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:in
each'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1099:inload_all_plugins' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:786:in
load_from_config'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:instartup' /Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:338:in
module:LibFredo6'
/Users/ME/Library/Application Support/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in<top (required)>'
Where downloading Move along ???????
It's part of this collection and you can download it at the first post or with the Plugin store.
Make sure that you have installed LibFredo too.
VOLUME Calculator.
I am getting a very large difference in calculated volumes between what SU displays in the Entity Info and what the volume calculator comes up with. I suspect it is due to a small sized object with many very small facets.
Can I send you the model to look it over?
Model created in SU2015, 64-bit. Windows 7.
Yes. Please send the model.
By the way, do you already know which result is the correct one?
Please see your messages. Thanks.
Is it possible to increase the size of the dialog box? On my screen it is so small it is almost impossible to see the buttons! I wondered whether there was an option but because of the small size I was unable to see it? Thank you
