    Windowizer3
    19 Posts 9 Posters 3.3k Views 9 Watching
    • FrederikF
      Frederik
      @ntxdave said:
      Problem with that one is that it only creates single pane windows.
      That's actually not true...
      It creates a double plane window...
      Cheers
      Kim Frederik
      • C
        cadmunkey
        Windowizer 4 does exactly what you are looking for. I'd suggest getting it as the low price is worth it.
        • F
          faust07
          Frederik is a little bit stoned... What is a double plane window? πŸ˜‰ I would prefer the old free Plugins "Lattice-izer" and "Lattice Maker" - belief both by TIG.
          • KrisidiousK
            Krisidious
            double plane window
            http://www.mattosco.com//wp-content/uploads/2010/08/double-pane-window.jpg
            By: Kristoff Rand
            • KrisidiousK
              Krisidious
              @jql said:
              Try Pixero's window generator it might be more what you're looking for.
              can you link it?
              Or do you mean 3 point window?
              404 Not Found
              (sketchucation.com)
              By: Kristoff Rand
              • FrederikF
                Frederik
                Say what...?!? 😲
                Exactly what Krisidious have shown...
                Thanks, Kris! πŸ‘
                Cheers
                Kim Frederik
                • BoxB
                  Yeah, but it's the spelling, Double Pane not Double Plane.
                  But then if you want to get picky, it's Believe not Belief.
                  • JQLJ
                    JQL
                    @krisidious said:
                    can you link it?
                    404 Not Found
                    (sketchucation.com)
                    That's the one...
                    www.casca.pt
                    Visit us on facebook!
                    • FrederikF
                      Frederik
                      Well... A little room for spelling mistakes would be in order here...
                      English is not my native tongue, but if people don't like a few spelling errors from non native English speakers/writers, then I'm out of here... πŸ‘Ž
                      Cheers
                      Kim Frederik
                      • BoxB
                        I thought it was funny that a German was correcting a Danes English and then making a spelling error while doing it.
                        • F
                          faust07
                          Excuse Frederik. That was not meant so seriously. Have too much cigarette smoke breathed so ... please do not go out off the forum!
                          • Bob JamesB
                            Bob James
                            [One last Off Topic]
                            I, for one, am immensely impressed with anyone who can be even reasonably articulate in more than one language, let alone in a technical field. There are a LOT of American/English speakers who make much more egregious errors.
                            Back on topic
                            Maybe ntxdave was referring to windows with mullions rather than a single sheet of glass
                            • ntxdaveN
                              ntxdave
                              Back on topic
                              Well, mullions would certainly produce the results I am looking for. However, the original post was because of the "back" side of the window. The "Hole Punch" plugin has helped some as well. If I want a "simple" window, I use the 3-point plugin. If I want something more elaborate, I use the Window Tools to add the other features.
                              Press F1...thank me later
                              • KrisidiousK
                                Krisidious
                                http://www.bopparchitecture.com/wp-content/uploads/2012/02/windowparts1.jpg
                                By: Kristoff Rand
                                • ntxdaveN
                                  ntxdave
                                  Thanks for sharing. Nice to have a source for correct nomenclature of parts like this one.
                                  Would be neat for those of us who do not have an engineering or architecture background to find sources like this one. Sometimes I see things in posts and do not have a clear understanding of what people are talking about.
                                  Would be interesting if someone like yourself could build a guide/library of information like this.
                                    Kris's illustration shows many 'window' related terms.
                                    A few observations...
                                    A 'sill' - in the UK it might be alternatively called a 'cill'...
                                    All of the parts around the edges of the opening are called the 'frame'.
                                    The inner thinner section 'glazing-bars' [horizontal or vertical] are often called 'muntins', but a bigger section - e.g. something more like a side frame's profile - is called a 'mullion' if it's vertical, and a 'transom' if it's horizontal...
                                    At the bottom it's the 'sill/cill'.
                                    At the top it's the 'head'.
                                    The projecting part of the 'sill/cill' that throws water away from the wall is usually called the 'drip'.
                                    If the opening is actually a 'doorway', then the terms like 'sill/cill' change to be 'threshold'.
