    Place an identical (complex) smaller shape in a larger shape
    17 Posts 5 Posters 941 Views 5 Watching
      matthira
      I'm very new to this so I apologize if this is a stupid question. I'm working on this custom lapel pin 3D print based on my monogram logo (an anchor. I have advanced knowledge of 2D vector work but I've never experimented with 3D.
      Anyway, I got this far:
      http://sketchucation.com/forums/download/file.php?mode=view&id=131339
      But I wanted to spruce it up a little. I was going to add a triangular shaped engraving pattern inside the border, so I thought the best way to go about that would be to scale down the outline of the shape and manipulate it into a triangle to intersect the main body. The problem is when I scale it down, this happens:
      http://sketchucation.com/forums/download/file.php?mode=view&id=131340&sid=e07b1a93d317147c803518d273c03f6a
      It doesn't line up properly.
      Is there a better way I should go about doing this? I'm trying to make it a little more elegant and less plain so I think this would be a step in the right direction.
      Thanks in advance.
      File:
      http://sketchucation.com/forums/download/file.php?mode=view%26amp;id=131341
      File
        Instead of scaling, you might try Offset. It'll take a little clean up but it can be done as shown. I would suggest you first install TIG-Weld from the Sketchucation Plugin Store and use it to weld the edges so the can be selected as one.
          matthira
          Thanks for the reply! Wow, okay I will try that I wasn't aware that was an option. Do you have any suggestions on how to turn that smaller face now into a triangle I could use to engrave the larger anchor? Thanks again!
          I'm not seeing how you used the offset tool on the hole towards the top. It appears it only works on outside edges?
            I'm not sure what you mean by a triangle. Do you want to cut a small V-groove following that offset edge?
            You can offset to the outside of a curve. In this case you'd do that in a separate step.
            As for the V-groove, if that's what you want, use those offset edges as paths for Follow Me. I'd split the anchor in half and work on that. Then copy and flip along the red axis to make the other half.
            For what it is worth, the only plugin I used at all on your model is TIG-Weld. Everything else was done with native tools.
              Maybe it is made in 2 pass ?
              I believe he wants subdivide the surface! πŸ˜‰
                With "a triangle"? One triangle?
                  Not very clear indeed! πŸ˜„
                  • BoxB Offline
                    Pilou, although I speak a variety of languages, I don't answer technical questions in another language unless I really know and understand the nuances of the question.
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi folks.
                      Maybe the triangle is a bevel all around.
                      This can be done using a triangle and the "Follow me" tool.
                      Make sure that the model is large enough to avoid generating very small facets that will not close automatically, leaving holes in the model.
                      Just ideas.
                        matthira
                        Hello all yes sorry for the confusing question but I did mean a triangular bevel tracing the interior of the shape.
                          matthira
                          You have all really helped me a lot. I've made a lot of progress for someone who just started this yesterday. I made it to here:
                          http://sketchucation.com/forums/download/file.php?mode=view&id=131354&sid=0be67faf1c4e57049f335d6549bf9fb9
                          I assume there is a way to create a bevel from those faces I've made? Would it be best to make the large anchor one face, and to use the smaller lines to intersect it and make a bevel from that?
                          Many thanks again!
                            I'm still not understanding what you want exactly. Do you want the V-groove like I showed? Or maybe a recessed center area with a bevel around the edges? Is there any chance you can find a picture of something that has a similar detail and share that?
                              matthira
                              Yes a V-shaped groove is all I'm looking for. I'm sorry I'm complicating it so much!
                                So just what I drew and showed in my previous image?
                                  Draw a triangular profile and use Follow Me to extrude it along the offset edge. As I mentioned before, divide the anchor and the path in half since they are symmetrical. After you've made the V-groove in the half, copy and flip to make the other half.
                                  It would be wise to make the triangle a fair amount larger than the desired V-groove and then only push the bottom "point" into the anchor as far as you need. this will leave some faces extending above the surface of the anchor which will make Intersect Faces work better and make it easier to clean up.
                                    matthira
                                    Wow that's exactly what I'm trying to accomplish. I don't understand what you mean by draw a triangle profile but I will look into the "Follow Me" feature now. Thanks!
                                      I think you'd be smart to start with something considerably more simple than this anchor and learn the basic tools such as Follow Me. You need to have these fundamentals down so you can actually understand what it is that you're doing when you work on this model. The profile is the shape you'll extrude along a path with the Follow Me tool.
