    Storage
    23 Posts 17 Posters 2.5k Views 17 Watching
    • hellnbakH
      hellnbak
      Flawless and beautiful
        rodman100
        A different course of stone is not at all unusual in traditional housing. Walling materials will vary as it is usually sourced locally but not always from the same quarry. The house may have been a single story cottage originally and later extended upwards. Or indeed the house may have bee build on the site of a demolished smaller house where the bigger stone was used for the ground floor and the upper floor stone sourced elsewhere! Walls ofter get thinner as the house goes up as the upper walls have to carry less of a load so the stone may be smaller! Truly a great rendering as good as ant I've seen. Well done!
        • JQLJ
          JQL
          @box said:
          Lovely piece of work as usual! πŸ‘
          The only tiny flaw I see in it is created by the excellent quality of the stone texture itself. The image you have used is so well constructed and beautifully layered that it's very uniqueness makes it stand out.
          This very distinct course of stones draws my eye and unfortunately for me flags the tiling.
          [attachment=0:2ygmsbjc]<!-- ia0 -->stones.JPG<!-- ia0 -->[/attachment:2ygmsbjc]
          Maybe it's because I live in a house built this way and I have spent months resetting the stones and know them all as individuals that I'm a bit too anal. πŸ’š
          Sorry box, but in that particular crop I see no tiling... I see a lot of similar stones but none of them is the same...
          www.casca.pt
          Visit us on facebook!
          • JQLJ
            JQL
            There is some texture repetition in the image wich is showing up and it is a good advice to disguise textures that are more notoriously standing out. But you're still being a bastard in a box! πŸ˜„
            www.casca.pt
            • jo-keJ
              jo-ke
              brilliant!
              http://www.zz7.de
              • pbacotP
                I'm afraid you have more details about the building than most construction drawings. Very observant and an intriguing result. Thanks for sharing!
                • leedeeteeL
                  leedeetee
                  John, brilliant, superb stuff. The smaller building would make a perfect micro brewery!
                    It is a brilliant model/render [as always].
                    It's somewhat disingenuous to pick out any very minor texture pattern repetitions !
                    There are only a handful... and a little simple smudging/dodging etc in post-pro would stop even those being noticeable to the overly inquiring eye πŸ˜’
                    Well done !
                    • JQLJ
                      JQL
                      Well I liked the kind way Box referred to those repetitions. It was a very shy way of saying that he had found out a flaw in this awesome work. I hope you felt I was picking on you on a light way Box, I was playing but I might have taken it too far...
                      www.casca.pt
                      • BoxB
                        I fail to see how constructive criticism of a beautiful piece of work and the use of it as a learning experience for many could be construed as disingenuous.
                        It's a great example of how the very uniqueness of the texture can be a disadvantage.
                        For example, you find a fantastic wood grain or a lovely blank bit of concrete with a rust stain, if you use them too close together or too often they form a recognisable pattern. A more bland grain or clean concrete slab mightn't cause the same problem.
                        I'll go away now and roll my eyes quietly in private.
                        As I said before, an excellent rendering!
                        • omiKronO
                          omiKron
                          Fantastic work for real! It's like a picture from the past.
                          • DanielD
                            Daniel
                            Excellent job, John.
                            Even after it's been pointed out, the repetitive use of the same texture still doesn't jump out at me. By changing its scale and using it on different planes, I think he did a great job of doing a lot with the same texture.
                            My avatar is an anachronism.
                            • hellnbakH
                              hellnbak
                              While I too noticed some repetition in the stone textures, I didn't feel the need to say anything about it because I don't feel they detract in any way at all from John's consistently amazing work (which nobody here can come close to touching).
                              And I noticed them only because I was specifically looking for them, and the only reason I was looking for them is because John's creations are so perfect I always feel the need to try and find something a little less than perfect. Just to make myself feel a little better about my inadequacies. Perhaps that is also why others scrutinize John's work so hard.
                              I very rarely find anything.
                              Please keep the masterpieces coming, John!
                              • Bryan KB
                                Ha! I knew it! You've been posting photographs all this time! πŸ˜†
                                Incredible as always. πŸ‘ Each one better than the last.
                                • marked001M
                                  marked001
                                  i think this might be the best one yet, john.
                                  http://www.revision21vis.com
                                  instagram: revi21on
                                  • tademaT
                                    tadema
                                    Thank you everyone for your comments I'm humbled by them 😳
                                    The model is too big to be covered in a single stone texture ~ 138m visible, but could easily have been fixed as TIG rightly pointed out with a little PP. To borrow a word he often uses but is very apt here.. it's "sloppy" PP.
                                    @ rodman100 your correct recycling was here long before the plastic bottle, I often use several textures to covey this.
                                    Whoever gave TIG's comment/opinion the thumbs down needs to take a look at themselves...childish.
                                    Once again thanks for the comments
                                    John
                                    • andybotA
                                      andybot
                                      wow, I had to do a double take that it's not a photograph! Great job πŸ˜„
                                      • BoxB
                                        • BoxB
                                          Sorry I should have kept my mouth shut.
                                          It's only me being sad bastard recognising the patterns in a brilliant rendering.
                                            Brightened my day nicely, thanks John. Bloomin' marvellous.
