    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 313.9k Views 135 Watching
    • cottyC Offline
      cotty
      A little one...
      I've had problems with drag&drop of images from the web browser to SU. No I've found the reason: I've changed the startup rights for SU to "always start as administrator". After changing this for the browser too (or both without these rights), drag&drop is back again...
      my SketchUp gallery
      • piratebrianP Offline
        piratebrian
        When taking one surface and copy pasting it into an unrelated group, if you click on the destination surface before you do the control-v paste you newly placed surface will auto align. Found this one by accident, it is probably page 2 of the instructions, But bahhh instructions.
          Thx to JQL πŸ˜„
          Move Copy a group
          if you double-click it, you edit it, andeven if you do nothing on it, it is made into a different definition, therefor "unique".
          Not sure that was on the manual ? πŸ˜„
          • AureusA Offline
            Aureus
            I forgot what this tread is about but no doubt - it's a record breaking thread: probably the longest living thread here.
            Like a submarine. Just when you think it's down it goes up to the surface. Over and over again. πŸ˜„
            • JQLJ Offline
              JQL
              @pilou said:
              Thx to JQL πŸ˜„
              It's the second time I make one of you hotshots have a duh moment! First it was Bob!
              www.casca.pt
              Visit us on facebook!
              • cottyC Offline
                cotty
                Followme: path and shape in different context
                I've always copied a path into a group to do a followme, but you can enter that group after you have selected the path with the followme tool...
                my SketchUp gallery
                • BoxB Offline
                  But be aware Cotty,that doing it with the path in a group will give you strange results.
                  • JQLJ Offline
                    JQL
                    Box, those strange results are only due to geometry. Your two circles are not orthogonal to each other so the start and ending are not coherent with the rest of the path. That's what that message means and it's not related to the path's/profile context.
                    www.casca.pt
                    • BoxB Offline
                      I beg to differ. The circles are set to make a sphere.
                      • cottyC Offline
                        cotty
                        I think the reason is the different axis for the group (you can see both in BOXs gif). the follow me uses the path circle, but with the global axis.
                        my SketchUp gallery
                        • BoxB Offline
                          I thought the same Carsten but the torus created isn't centered on the origin, certainly influenced by but not centered on.
                          • JQLJ Offline
                            JQL
                            That is true! And that is why the circle's profile is not orthogonal with the path and the result is an elliptical profile donut with strange endings...
                            Seems sketchup is picking the circle path and use it's context axis to place it relatively to the profile's context's axis.
                            If the path's componentΒ΄s axis would be centered with the circle and if the profile was centered in it's context axis, then the sphere would be created.
                            If the profile had been drawn along the X axis a circular profile donut would have been created instead of an elliptical one.
                            What also happened here is that Box grouped the path while you grouped the profile.
                            I also bet things will work differently if using a group or component...
                            www.casca.pt
                            • BoxB Offline
                              Talk about missing the point.
                              • JQLJ Offline
                                JQL
                                LOL! That's cool! But you missed the point for most of it... πŸ˜†
                                I think... πŸ˜•
                                I'll try it in a minute but my gif creating capabilities are messed up since I got a 4k monitor... licecap doesn't work well nor other stuff I tried...
                                www.casca.pt
                                • BoxB Offline
                                  I am preparing my eggs for the sucking lesson.
                                  • JQLJ Offline
                                    JQL
                                    You have to center the axis inside the circle group prior to follow me.
                                    www.casca.pt
                                    • JQLJ Offline
                                      JQL
                                      Sh** I'm doing it right now in several ways, but can't gif it!!!!
                                      www.casca.pt
                                      • JQLJ Offline
                                        JQL
                                        wait a moment... changing computer!
                                        www.casca.pt
                                        • BoxB Offline
                                          I think you have made my point for me. If the profile is in a group it causes a different result because it relates the group axis to the global axis. But if the profile is in a group it simply uses the group Axis.
                                          QED
                                            #handbags
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 34
                                            • 35
                                            • 16 / 35
