    What's the best way to learn SketchUp Shortcut Keys?
    38 Posts 18 Posters 7.2k Views 18 Watching
    • JQLJ Offline
      JQL
      @aureus said:
      "Ctrl+h" - Hide/Unhide the rest of the model (a very useful command - I recommend this to everyone)
      So useful, in fact, that "H" without CTRL is much faster to use. Who cares for "H" as pan? That's why you have your mouse for!
      www.casca.pt
      Visit us on facebook!
        Calstock
        I think the only "muscle memory" that's involved is the brain ! If I want to draw a circle, my finger goes to "C" not because my hand automatically goes there, (in a typing / Typist sort of way), but because my brain has learned the shortcut. I guess you could say I automatically then select C without looking down at the keyboard, but that's missing the point.
        I'm not sure I've made my point clearly but I think typing is true muscle memory in that you don't even consciously think about where the letters are on the keyboard - you just type ! Shortcuts are different in that you DO think about it, (for a split second granted), and then you type the letter.
        • emerald15E Offline
          emerald15
          Funny you should ask... about a week ago I finally (after 2-3 years with SU) decided to start using keystrokes. I found a list of the basics... & already I've almost forgotten using the icons. I guess it was just time!
          • BoxB Offline
            Just to make it all the more confusing, because I work in several languages I have a blind keyboard. Meaning there are no markings, so I simply know the relevant key depending on which language I am in. The keys I most often screw up are Z and y as they are the most often used but reversed in so many layouts.
            • JQLJ Offline
              JQL
              Bah, seems like you're a genius!
              www.casca.pt
                along with his blind keyboard he has three blind mice.
                • BoxB Offline
                  What a silly bunt I am.
                    I was kidding. You're a good lad to have the place.
                    As for shortcuts...
                    I keep all app keys the same or close to the same.
                    Don't forget that SketchUcation Tools has a shortcut list tool under SketchUcation Tools > My Shortcuts
                    • AureusA Offline
                      Aureus
                      How do you pan with your mouse?
                      What kind of mouse do you use?
                      With mine I can only zoom in, zoom out and orbit (scroll wheel).
                      Also, in my case the 'h' keyboard is reserved for "Hide". Here I made an exception - I changed an originally assigned shortcut for a SU native tool - Pan.
                      By the way, 'Pan' is also useful from time to time.
                      But I use 'Hide' more often.
                      One more thing - if you assign a shortcut to some tool that is reserved for Windows commands (Ctrl+P, Ctrl+V, Ctrl+A...), you'll be able to use it untill you restart SketchUp.
                      Pan or Orbit?
                        Middle Mouse down + left mouse down
                        • AureusA Offline
                          Aureus
                          Thanks.
                          One needs to press them one after another and not in the same time. Then you hold them both.
                          This topic encouraged me to make one more shortcut.
                          • JQLJ Offline
                            JQL
                            If you're a shortcut guy yourself, you'll probably use both hand for fast working on Sketchup.
                            I know I do...
                            Use shift while holding middle button and pan away. It's more stable than left click+middle button.
                            www.casca.pt
                            • AureusA Offline
                              Aureus
                              I know I do...
                              You read my mind.
                              I just wanted to say: "Ok, scroll wheel and left mouse in the same time does the job, but it's somehow...unstable..." πŸ˜„
                                there's also the double click middle mouse that centres to clicked area
                                • Mike LuceyM Offline
                                  Mike Lucey
                                  I only learned recently that I can pan by pressing forward my scroll wheel on my Elecom Scope Node mouse. It was available on Amazon but any longer, here, http://www.amazon.com/Elecom-Wireless-Sensor-3-button-M-sn2dlsv2/dp/B00B08P934/ref=cm_cr_pr_pb_opt?ie=UTF8
                                  It might be possible to get one here, Special order anything from Japan.
                                  http://whiterabbitexpress.com/scope-node-mouse-elecom/
                                  Mike
                                  • AureusA Offline
                                    Aureus
                                    I can't imagine work without shortcuts.
                                    On the other hand, it seems there are people who are real SketchUp masters able to model excellent things in Sketchup by - clicking on tools.
                                    This person needs only three and half hour to model a good looking car, yet he or she doesn't use shortcuts (at least not in this video).
                                    He or she picks even the 'Select' tool from the toolbar. The 'Line' and 'Move' tool also...
                                    However, this may has been done just for the sake of this video, so that people can see what's happening...
                                    • AureusA Offline
                                      Aureus
                                      Mike
                                      I've been using the same mouse for 10.5 years already.
                                      Whenever I have to use someone other's mouse it feels strange...
                                      This Microsoft baby is precise and reliable.
                                      • cottyC Offline
                                        cotty
                                        Print the Quick reference card and start with the most used tools ((l)ine, (r)ectangle, (c)ircle, (p)ushpull, ...).
                                        my SketchUp gallery
                                          Mike Lucey
                                          Does anyone remember the plugin that produced a disk shaped floating menu containing the main SU icons along with pop out sub menus. I've tried searching but have had no luck.
                                            Does Sketchup has this sort of thing ?
                                            (here the free DesignSpark Mechanical) A Sketchup on SteroΓ―ds πŸ˜„
                                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/_7165628_orig.jpg
                                            • 2 / 2
