    [Plugin] Hide Overlapping Geometry (Updated 20150511)
    29 Posts 10 Posters 9.0k Views 10 Watching
      CAUL
      Hide Overlapping geometry is a script that, well, hides overlapping geometry. It works as follows:
      1) Overlapping faces are always hidden. Two faces overlap if they have exactly opposite normals and share an interior point.
      2) If two faces overlap, the script will check their edges for overlap. An edge will be hidden if it overlaps another edge and A) is connected to only overlapping faces, or B) is connected to overlapping and non overlapping faces where the latter have an angle between the normals < 22.5 degrees.
      The problem is somewhat subtle and it's not always obvious what to hide. The script works best with solids. If a face or edge is hidden, it will be hidden in all group and component instances.
      Usage
      Select one or more groups or components and run the script. The script appears as "Hide overlapping" in the Extensions menu. If only one group or component is selected the option
      "Hide within nesting" has to be true.
      v0.0.2
      Interface added with four options:
      1. The smooth angle can be explicitly defined
      2. The geometry can be transfered to a specific layer
      3. Groups and components can be made unique
      4. Groups and component can be compared within the same nesting
      v0.0.2
      • TIGT Online
        Please always attach your Plugin's RB [without versioning in its filename] as an RBZ [edit your post accordingly] - so then it might then be considered for inclusion in the SCF PluginStore.
        Contact Rich O Brien by PM, asking to become registered as an 'SCF PluginStore Author' so that you can publish your Plugin[s] there...
          DOD3R
          wow, yes yes yes,
          dream come true.
          Thanks for such a great plugin.
          D.
            I don't very well understand that this script must do! ๐Ÿ˜„
            overlap.skp
              CAUL
              In your example the faces intersect. Overlap is when the faces are aligned (and have exactly opposite normals) and occupy the same space. In the image below there are 16 instances of a solid group. For visual reasons the seams between the groups should be hidden, and the way to do this is to hide the overlapping faces and edges. If you select two adjacent groups and run the script the seams disappear.
              Before
              After
                This works great, CAUL! Thank you!
                  Ok! But seems there is a little glitch! ๐Ÿ˜‰
                  A simple copy box (Group)
                    AAAAAAAAAAaaaaaaaaaaahhhhh! ๐Ÿ˜„
                    But this is curious!
                    Better if that work in any positions! ๐Ÿ˜„
                    Now seems that is a glitch inside the "gifcam" ! ๐Ÿ˜’
                    Seems it don't like the rotations! ๐Ÿ’š
                      Why don't you use Flip Along instead, Pilou? ๐Ÿ˜’
                      • JQLJ Offline
                        JQL
                        [attachment=0:1tsgra7o]<!-- ia0 -->overlap1.gif<!-- ia0 -->[/attachment:1tsgra7o]
                        I bet if you double click edit any of the two groups, prior to running the script, you will get the result you expect.
                        www.casca.pt
                        Visit us on facebook!
                          YEP! Excellent! ๐Ÿ‘
                          What make exactly this double click ?
                          I take always the bad color anytime the first time! ๐Ÿ˜„
                          I prefer mirror ๐Ÿ˜„
                            Mirror is nice but Flip Along can be done in a single key stroke.
                            • JQLJ Offline
                              JQL
                              When you create a group and copy it, it is just like any component, and you get duplicate instances of the same definition (duplicate groups behaving like duplicate components).
                              However, if you double-click it, you edit it, and even if you do nothing on it, it is made into a different definition, therefor "unique".
                              What happened is that the plugin hide the face of a group behaving as a component and in doing so it hid the face of both components. If you'd flipped it like Dave suggested, you wouldn't see the problem.
                              www.casca.pt
                                I don't believe that many people knows that! ๐Ÿ˜ฎ
                                (maybe in the manual but don't have the luck to see it! ๐Ÿ˜„
                                It's the Dohdoh Duh of the day! ๐Ÿ‘
                                • tt_suT Offline
                                  tt_su
                                  This isn't documented well in the API either. Something we need to improve. Developers need to call group.make_unique to ensure groups are unique before modifying them.
                                  • JClementsJ Offline
                                    JClements
                                    I noticed that if the normals of the two overlapping faces are the same (both are "pointing" in the same direction), then the script fails.
                                    Overlapping Fail.skp
                                      CAUL
                                      This is not really a bug (nor a feature). It's mentioned in the initial post. The reason for this behaviour is that it's a very convenient simplification from a developers point of view. The extension is centered around solids with consistently oriented faces so it's a reasonable simplification.
                                      • PixeroP Offline
                                        Pixero
                                        Thanks for version 2. That seems to work well now. ๐Ÿ‘
                                        Would you please also add a "Show overlapping edges"?
                                        When for example designing a multi floor facade it would be great to hide the edges to see how the whole facade looks and then it could be useful to turn the edges back on for viewing the different floors.
                                          CAUL
                                          Maybe the possibility to move the geometry to a specific layer is enough? Then you can turn the visibility of the layer on and off.
                                          • PixeroP Offline
                                            Pixero
                                            Yes that would do. ๐Ÿ˜„
