    [Plugin] Deck Builder (Updated 23-Jun-2015)
    56 Posts 19 Posters 56.5k Views 19 Watching
    • BoxB
      Can you have a look at the toolbar settings, it seems you have it set to open the toolbar every time SU starts. So even if you have closed the toolbar it will reinitialize at the next start up. Slightly annoying.
      • sdmitchS
        sdmitch
        If you don't want the toolbar to show on start up find this line
        	cmd.tooltip="Deck Builder";tb.add_item cmd;tb.show
        and replace it with this line
        	cmd.tooltip="Deck Builder";tb.add_item cmd;#tb.show
        The Toolbar will be created but not automatically displayed.
        http://sdmitch.blogspot.com/
        • BoxB
          Thanks for that, it certainly works. I would have thought it would be the default setting, after all if you turn it off you would expect it to stay turned off.
          • sdmitchS
            sdmitch
            Perhaps, but few things will persist from session to session.
              The "user-friendly" way to have your script's loader setup its toolbar so that it opens when its first installed, and then subsequently so it only opens if the user had it open when they last exited SketchUp, is simply done thus:
              cmd.tooltip="Deck Builder";tb.add_item cmd;tb.show **if tb.get_last_state.abs==1** #TB_VISIBLE/NEVER
              This way, if the toolbar was switched off by the user when they exited SketchUp it will not get re-opened as the plugin loads next time...
              • sdmitchS
                sdmitch
                Thanks for the info. I still have so much to learn.
                  raymondmartin
                  Nice tool for deck builders.
                    Marauderr
                    I am new at this and this is my first plugin i try,
                    I can open the deck builder and select the options i want but i dont understand how to make it happen, there is no OK or Cancel Button to click on? so how to make it happen, what is the secret door i use to get there
                    LOL
                    Thank You
                    N.
                      Try having a look at the author's tutorial which you can find on the page he links at the bottom of his posts. Lots of other very useful plugins with tutorials to be found there, too.
                      • E
                        eddie
                        Great plugin! But why have the geometry be individual groups instead of components? Doesnt this bloat the file size and make revising cumbersome??
                        • sdmitchS
                          sdmitch
                          Based on my tests, there is little difference in the file size groups versus component instances. Since each deck is different, it only made sense to use components for the spindles and group everything else.
                          • naivejoeN
                            naivejoe
                            Nice Plugin. It worked as advertised the first time I used it but then I tested the rotation feature and now it won't change back. All decks are drawn with the joists going parallel to the long direction of the face, the deck boards the short way. I've re-installed, restarted and purged IE.
                            Rotation stays set at 0 no matter which option is chosen, which is how it worked from first install.
                            Any help?
                            • naivejoeN
                              naivejoe
                              Nice Plugin. It worked as advertised the first time I used it and then I decided to test the rotation feature and now it won't change back. All decks are drawn with the joists going parallel to the long direction of the face, the deck boards the short way. I've re-installed, restarted and purged IE.
                              Any help?
                              • sdmitchS
                                sdmitch
                                Any help?
                                Sorry about the delay in responding but I just found your post the morning. After looking at the plugin there was a problem with the Rotation section. It has been corrected and posted so you can download a new copy.
                                  Always magic! 😎
                                  • sdmitchS
                                    sdmitch
                                    @pilou said:
                                    Always magic! 😎
                                    [attachment=0:qjr36ocf]<!-- ia0 -->always_magic.jpg<!-- ia0 -->[/attachment:qjr36ocf]
                                    An always the most bazaar shape.
                                      You didn't actually install the extension. Mike, the file downloads with the extension .rbz. Since you have it downloaded, move it out of the Plugins folder and put it back in Downloads or where ever downloaded files are saved. Then open SketchUp, go to Window>Preferences>Extensions and click the Install Extension button. Navigate to the saved file, select it and choose Open. Click on the affirmative responses after that and close the Preferences file. It should then be available.
                                        mikedd
                                        I downloaded your file and placed it in my plugins folder but it is not showing up in Sketchup anywhere. I have Sketchup 8 on windows 10.
                                        Excuse me I did it been a long time since I used sketchup, time to give it a whirl.
                                          https://s6.postimg.org/dvdk9ehe9/Sans_titre_11.jpg
                                          It's a pity that is not component! πŸ€“
                                          We are obliged to make some acrobatic physic exploit for change something! πŸ˜„
                                          Here SU4 by SUForYou to Components who can apply a "component" (module on the left down) to a selection of faces with automatic scale! 😎
                                          The task is on the selection!
                                          As it's only "Group" the module component must be inside the group
                                          then selection of faces can begin!
                                          something like this: parallal view - side view - XRay - selection left to right ...
                                          Here the view (old conceptual image) is a little cheating! 4 faces was selected : I was speedy! πŸ’š
                                          (visible on the first piece)
                                          https://s6.postimg.org/tzr8uimxd/bidouille.jpg
                                            Seems there is a glitch with the 2017! πŸ˜‰
                                            (works fine in 2016) πŸ‘
                                            Have happy coding! 😎
                                            dech2016.skp
                                            • 2 / 3
