    "Always Face Camera" behavior
    12 Posts 4 Posters 820 Views 4 Watching
      Place the component axis at the center.
      It determines the pivot
      • hellnbakH Offline
        hellnbak
        Duh! Yep, I are a noob πŸ˜†
        Thanks, Rich
          never too late to learn...
          i'd curve the backplate slightly to prevent hitting model.
          • hellnbakH Offline
            hellnbak
            Thanks for the tip. Only problem now is that when I rotate it to left it becomes very dark
            to the right it's ok
              Set it to not receive shadow in the entity info
              • hellnbakH Offline
                hellnbak
                Already checked that, it's set to neither cast or receive shadows
                  It's the native shading so. which you can't overide.
                  maybe brighten the background a bit more?
                  • hellnbakH Offline
                    hellnbak
                    Let's just chalk it up to another weird hellnbak problem πŸ˜†
                    I'll work around it.
                    Thanks again
                    • BoxB Offline
                      There is an option from memory, shadows face sun, it's a check box on the component itself, that might be what you need.
                      • hellnbakH Offline
                        hellnbak
                        Already tried that one, didn't help.
                        • pbacotP Offline
                          For that scene you can also adjust the light/dark settings in the Shadows window. This will however also affect the shadows on the robot. The curve in one instance gives a nice graduated backdrop, but in the case of the side shot, maybe a flat face is better or curved opposite? (You don't have to use the same object as backdrop in each scene.)
                          The shading feature makes many SU renderings work great and is also good for modelling interface but causes issues, for example when we want to show an elevation of a building and the roof, ground, or ceiling becomes super dark.
