    How do I extrude this?
    16 Posts 4 Posters 1.3k Views 4 Watching
      kitweb
      OMG sorry thats the wrong pic.
      This is the one.
      heres the link https://drive.google.com/open?id=0B-WGyti8iPA0Qmp0SVFIbjgzTTA%26amp;authuser=0
        You're not having a good day. πŸ˜•
        That's an enoermous DWG, not a SKP.
        It also contains lots of complex parts - you might go mad trying to make it into a solid.
        You image shows a screen-shot from a SKP !
        That looked like a mesh of edges that'd be possible to work with to get a solid.
        Use AddFaces on the edges, then use Joint-PushPull plugin to give thickness ? ...
        What are you wanting to do ?
          kitweb
          Ahh not my day, here it is - >
          Error 404 (Not Found)!!1
          (drive.google.com)
          How do I install plugins for 2015 mac??
            SketchUp > Preferences > Extensions > Install button...
            Find the downloaded RBZ file and OK.
            Answer 'yes' to all prompts.
            Almost all plugins [and extensions, which are actually just a sub-set of all plugins - which can be separately activated/deactivated in the Preferences/Extensions panel...], will come as RBZ archives and are auto-installed into your own default-plugins folder.
            RB files in there are automatically loaded as SketchUp starts.
            Auto-installing has been available since v8.2 !
            Make sure you have the latest versions of any plugins - since v2014 a lot has changed, and most plugins have been rewritten to be compatible with v8 through to v2015.
            If you come across a ZIP format plugin archive just rename it with .RBZ at the end - an RBZ is just a renamed ZIP. Then install it as outlined above.
            If you find a lone RB file, ZIP it then rename it .RBZ etc...
            An alternative to all of this faff is to get the SketchUcation PluginStore Toolset RBZ and install that - see the Resources menu above.
            Thereafter you can install from a dialog browser directly, without needing to manually download any RBZ files. The SCF PluginStore dialog lets you browse the hundreds of plugins available, Auto-Install selected ones etc.
            It also has Update reminders [including Batch-Updating], Bundles to assist in installing Plugin sets across versions and computers, Managers to enable/load/disable Extensions AND vanilla-Plugins - including making Sets for quickly swapping between set ups, and other several tools - to Uninstall/Reinstall Plugins, Install Plugins from archives [RBZ OR ZIP], open your Plugins folder directly, list your shortcuts and so on...
              You can attach a SKP direct to your post.
              There is a 4Mb limit.
              The SKP download linked is enormous - 48.6Mb, but Purges to 3.8Mb !
              Learn to use Model Info > Statistics > Purge Unused etc...
              Even smaller - you could have done a 'save_as', on what I assume to be the component in question, then it's a mere 37kb !
              Reload that after editing it...
              Observations...
              The component has been scaled.
              The component is drawn upside down.
              I edited it using a Add-Face Plugin - there are several - e.g. mine http://sketchucation.com/pluginstore?pln=addfaces
              I then used Fredo's JointPushPull to thicken the surface... http://sketchucation.com/pluginstore?pln=JointPushPull
              Also note it needs his Lib installing too http://sketchucation.com/pluginstore?pln=LibFredo6
              I realize it's probably upside down, but that's a feature of your SKP/Component modelling... πŸ˜’
                kitweb
                Hi TIG,
                Thanks for the instructions about purging and installation extensions!
                In regards to the mesh I actually dont want to add faces but I want to just thicken the mesh into tubes, leaving the faces open. Is this possible?
                  That is a completely different thing ! πŸ˜’
                  Use lines to tubes on the selected edges.
                  http://sketchucation.com/pluginstore?pln=lines2tubes
                  However, neat 'node' connectors need adding manually... make a sphere compo with its origin in the center and snap instances to nodes, then do the tubes...
                  If you leave the tubes in a group you can edit it, select all and intersect with model, to make cuts at the nodes interfaces.
                  Size/color the nodes and set the tube diameter etc as desired...
                    kitweb
                    Thanks TIG!!!!
                      kitweb
                      Does lines2tubes work in sketchup 2015? I cant seem to see it in the Extensions list.
                        Does lines2tubes work in sketchup 2015? I cant seem to see it in the extensions list.
                        Yes works fine! πŸ€“
                        Menu Tools / Convert arcs Circles...Lines to Cylinders
                          Yes - I did my example in v2015.
                          As Pilou explains...
                          That plugin appears under the 'Tools' menu.
                          Read the plugin's instructions...
                          Not all plugins appear in the 'Plugins' menu [which is now confusingly renamed as 'Extensions' in v2015!]
                          Some plugins may appear in 'Draw', 'Tools' or even 'File' menu - it just depends on the plugin .
                          Some plugins only run from a Toolbar.
                          Some plugins only run from the right-click context-menu, and then only appear if a suitable selection exists.
                          A few more-rarely-used plugins are run by typing commands into the Ruby Console.
                          Read each plugin's instructions...
                          • BoxB Offline
                            Think about it, what do you get if you only use four sides?
                              kitweb
                              Thanks TIG, is there a plugin to also convert lines to square tubes?
                              I am trying the pipealongpath plugin but it is only converting some of the lines.
                                or Three ? πŸ˜„
                                Click Image for animation!
                                http://imworld.aufeminin.com/dossiers/D20120801/9-Toblerone-D-AFsuisse-104459_L.jpg
