    [REQ] Proper UV application for sketchup
    14 Posts 9 Posters 1.7k Views 9 Watching
      cuttingedge
      If trimble or this community will find ways, Im sure there's a way to create proper UV functions inside SU overcoming the limitations of the non quad polygons. The limitations of SU I suppose could be attributed to its commitment to " keep it simple " so the wider base of user could stick to SU.
      Maybe less than 10% of SU do things like UV unwrap, do seams and stuff like that that's why the majority doesnt clamor for this function.
      Many of our heroic ruby script authors have overcome too many SU limitations over the years, Im confident this one is no different. Im sure many people would be willing to pay (on top of what they paid for on a Pro license) to have this function.
      • Rich O BrienR Online
        Ultimate Unwrap 3D provides a very robust UV mapping solution at a very low price.
        The workflow isn't too intuitive but it's results are on par with more expensive solution.
        I use Blender because it is much more intuitive. Plus exchanging data between Blender and SU is easy with .dae files
        Strangely our recent work on a webGL viewer has shone more light on SU uv maps so you never know where that may naturally lead. It is something that is needed.
        Best workflow for now is SketchUV export map to .obj then unwrap and re-import.
          roland joseph
          Ngons
          It wasn't only a few short months ago that building watertight models was an excruciating task in SU. You had to find ways to decimate the mesh and plug the holes manually. At that time I looked at the SU mesh and was very disappointed....felt handcuffed by the odd ngon.
          Looked to me as if it would never be fixed. Then out of the blue came some built in SU tools for creating solid models. Now I believe anything is possible.
          • pbacotP Offline
            @roland joseph said:
            Ngons
            In the last few months some new built-in tools have been released?
            • panixiaP Offline
              panixia
              i recently experimented with TT's quadface obj exporter and it's giving consistent results.. i checked it with both 3dsmax and zbrush.. it preserves proper quads and uv's.. can't wait for a qft obj importer..
              I just can't believe sketchup still doesn't integrate brilliant Thomthom quad-system as native feature.. one could still use n-gons if doesn't care about quads but hey, why don' give that option to users who really need it?
              isn't the same way for solids? you got solid support if you need it, but you are not "forced" to model proper manifold models..
                @panixia
                It puzzles me why SU doesn't support obj out of the box.
                Thom's export is good but it needs to import also for a good workflow.
                  Pherim
                  I use Thrupaint (included in FredoTools) and SketchUV and can do almost everything uv-related I want. SketchUV allows export of UVs to edit them with external applications and re-import them, and there also is the already mentioned UV editor by Marginal which is in a very early state but still useful.
                  • silvershadowS Offline
                    silvershadow
                    Won't it be even better to be able to do this all inside Sketchup without exporting this and that, all in one nice interface to work on this. The idea is to cut out all the export and import steps. I also export and import at the current moment.
                    • KrisidiousK Offline
                      Krisidious
                      UV Layout... $300.000 Dayum... Proud of that aren't they? I use AC3D for UV wrapping. 3DMax when I'm working on a game.
                      By: Kristoff Rand
                      • duanekempD Offline
                        duanekemp
                        Only discovering SketchUV now, this post more than becomes relevant. Definitely following.
                        Duane Kemp
                        Kemp Productions
                        Puidoux, Switzerland
                        Gallery:
                        https://duanekemp.artstation.com/
