    How to Make a Bowl of Random Components
    29 Posts 6 Posters 3.3k Views 6 Watching
      Note: This plugin will not work with SU2015 64bit!
      Yes but...
      As you have a PC you can load a 2015 32 bits! πŸ˜‰
      http://www.sketchup.com/download/all
      • Mistro11M
        Mistro11
        I got Sketchy Physics installed in my 2014 version. I am having some trouble getting my groups/components to fall in Sketchy Physics. The shapes that come with the plugin work fine. The bowls I made act correctly as containers and catch the capsules. But when I make my own items to drop in, they do not move. What did I miss?
        Structural Integrity is Not Just Physical...It's in the Design and Purpose
          Have you followed my little tutorial and aespecially the last line of the point C ?
          • jeff hammondJ
            sketchy physics.. and i don't really know what happens with it and su2015.. haven't used it for a while..
            'my PC eats mac pros for breakfast'
            did this with sketchy physics too:
            • Mistro11M
              Mistro11
              Yes I used that as a guide. Thanks. I made a small rectangle and pulled it out to a flat box for testing. I then made it into a group and clicked on "show collision" for that object. When you say make it with thickness, is it more than just pulling out to a box? I'm at a loss here.
              Also the SP control panel is blank. Don't know if that means anything.
                a component with a thickness = a volume
                but you can also take a simple plane! πŸ˜‰
                as in the end of the Jeff video! πŸ’š
                But if you have only planes as cards not many chance that you can obtain a montain! πŸ˜„
                And I believe that your problem is
                Right click / Sketchyphysics /Shape
                Seems I remember that you must enter something like "convex" if it's be...(the nature of the volume)
                http://www.keris-studio.fr/blog/wp-content/clip_image041_thumb7.jpg
                • cottyC
                  cotty
                  Is that Bryce flying by? πŸ˜‰
                  The new version (modified by Anton) of SketchUp works great in 2015 (only 32bit) as mentioned before.
                  my SketchUp gallery
                    @Mistro
                    Seems you must post your skp file for someone can examine it! πŸ˜‰
                    • Mistro11M
                      Mistro11
                      When I select convexhull my cube falls but is triangulated. Seems like something happens to the geometry. Earlier I loaded the box that comes with SP. It fell as expected. Then I used round corner on the cube to modify it. After that, it stays in the air but the mesh face is distorted.
                      Here's my skp file. I hope SU version 2014 is ok. That's what I'm using for this. The bowl is made shallow so not to need too many components.
                      Cereal_Bowl.skp
                      • cottyC
                        cotty
                        Your geometry is too small, if you scale it 10x, it will work.
                        Edit: little animation...
                        [screenr:vp66j6ey]qEvN[/screenr:vp66j6ey]
                        my SketchUp gallery
                        • jeff hammondJ
                          it's been a while since i did that and i can't find the file.. i think it might be Sang doing the fly by though ?
                          oh, right.. i forgot windows sketchup still has a 32bit version.. 2015 for mac is 64bit only
                          • Mistro11M
                            Mistro11
                            Thank you so much Cotty! That worked. It plays slow but it works. What SU version did you use? The cereal triangulated on the way down for me but renders fine.
                            • cottyC
                              cotty
                              SU 2014, I use that version to play with SP since I normally use the 64bit SU2015.
                              Is your "show collision" still active?
                              You can record the animation and watch it faster afterwards as a playback.
                              my SketchUp gallery
                              • Mistro11M
                                Mistro11
                                Show collision is still active. I just got a bugsplat halfway through the animation after multiplying the cereal. What kind of optimizations should I be aware of? I'm thinking my cereal have too many faces. Yeah, I wish I could use this in 2015 64bit.
                                • cottyC
                                  cotty
                                  For my animation, I only have deactivated the show collision setting without changing your geometry of the cereal.
                                  my SketchUp gallery
                                  • Mistro11M
                                    Mistro11
                                    I figured out why my scene was so heavy. I didn't make the cereal into a component. After making it into a component, it runs much smoother. Thanks again.
                                      i think blender will serve you better in this instance. without suffering from crashes
                                      click image to view gif...
                                      set the bowl as a collision object
                                      set a plane to emit your cereal shape
                                      after simulating you can export to SU....
                                      • Mistro11M
                                        Mistro11
                                        Thanks Rich. Yeah, Blender is my other workhorse. I do want to make my cereal with more complex shapes without worrying about crashes so I will try that next.
                                          of course! πŸ˜‰
                                          • Mistro11M
                                            Mistro11
                                            One more question...Is it possible to tweak the scene after pausing the simulation? The cereal fell in a perfect way but I want to tweak the materials and export the scene to Thea Studio. Any attempt to select anything outside SP tools results in a reset of the simulation.
